Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Brake fluid reservoir full
  1. #11
    Regular
    Join Date
    15th October 2008
    Location
    West Yorkshire
    Posts
    235
    Bleeding brakes on the Corrado is same as any car of the era mate, so a quick interwebs search will tell you all you need to know. I think what you're getting is a general reluctance for people to retype the same info that is all over the web.
    Anyway, yes, start with caliper furthest from the master cylinder, clamp open the rear bias valve, there is a bleed nipple on the master cylinder, two on the ABS unit, one on each caliper. I use an easy bleed kit and also do the clutch at the same time as the feed for this is off the reservoir - the bleed nipple for the clutch is on the slave cylinder on the gearbox.
    I've never tried a 'gravity feed' method, sounds like you'll need a week to do it that way!
  2. #12
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,785
    That's pretty much it as above - some clutch masters will have a bleed nipple on them as well, but most just have the one on the slave. I use one of the Sealey pressure bleeders that you pump up by hand, and they work a treat and also meant that you don't need to mess around with a spare tyre.
    I can't see the gravity method working too well as all the fluid needs to get through the ABS pump to get to the callipers.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
Similar Threads
  1. non abs brake fluid reservoir
    By mimjed in forum Wanted
    Last Post: 21st August 2014, 9:37 PM
  2. brake fluid reservoir
    By chopper666 in forum Drivetrain
    Last Post: 30th July 2013, 7:20 PM
  3. Brake fluid reservoir or cap
    By NewbridgeJob in forum Wanted
    Last Post: 27th June 2012, 11:51 AM
  4. wanted: brake fluid reservoir
    By DuBSterVR in forum Wanted
    Last Post: 9th March 2012, 4:57 PM
  5. changing brake fluid reservoir
    By fla in forum Engine Bay
    Last Post: 8th March 2012, 3:46 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
