Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Clutch low bite point and now cannot select gears
  1. #1
    Since getting the vr6 back on the road the pedal has never felt normal, only having pressure halfway down and a low bite point, have managed for the last month though.
    Took it down to a pals garage last night and we put a power bleeder on the slave and master which brought the pedal back a bit but this morning i couldn’t select 1st?
    I’ve ordered a slave for £35 from heritage so hoping this fixes the problem as prices for the master are near £200 unless anyone has a link to a better buy?
    Also the pipe which goes from fluid reservoir to master doesn’t look the best but there are no leaks anywhere?
    We did try bleeding it by pumping the clutch pedal to start but it kept wanting to drop to the floor when doing up the bleed nipples?
    92 VR6
  2. #2
    Enthusiast
    Join Date
    23rd April 2017
    Location
    Liverpool
    Posts
    382
    Had this fault on mine (only 2.0 16v)Replacd the clutch master clylinder.Bleeded the system by gravity did not pump the padal.Just fit a clear tube to the nippel crack off and gravity will do the work.
    This is how bleed the brakes and clutch system on mine
  3. #3
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,944
    My bet is on the clutch slave - and it's also the cheaper and easier option to replace - sometimes you won't see it leaking as it collects inside the bell housing.
    The only problem is that if the slave is on it's way out the master won't be far behind, so it's often a good idea to do both at the same time if they are original ones.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  4. #4
    ⋆⋆ CF Member ⋆⋆ Jim Bowen's Avatar
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,960
    Clutch fork bent?
    Just like a golf................But better!!!
  5. #5
    I’ve ordered a slave from heritage as the masters are for left hand drive cars but fit apparantly? hopefully the slave fixes it..
    So i need to look under the clutch pedal for a bent clutch fork correct?
  6. #6
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,960
    Nah the clutch fork is within the gearbox/clutch area, quite hard to check
  7. #7
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,848
    When the slave seals go you'll find a puddle of fluid under the car
  8. #8
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,944
    Only when it dies completely - before that you will get difficulties getting into gear, slow pedal return or "jump" to at rest or pedal to the floor. They can show all these symptoms with no visible signs of leaking until you take it out - I had one where the rubber boot on the push rod was leaking very slightly.
    It's easy enough to replace the slave anyway and they are not that expensive, being a thankfully common part.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  9. #9
    Quote Originally Posted by fendervg View Post
    For sure. You use the thing enough, you want it to feel good, and not do damage to the clutch, so a new slave cylinder is a good idea. I bleed the clutch with a large syringe and hose, and pull fluid from both the master and slave, only pumping the pedal a few times between pulls. Seems to have worked the best for me.
  10. #10
    Had the slave delivered but also ordered a master and the hose form the reservoir, hopefully this will sort it
Similar Threads
  1. Clutch biting point low, is there adjustment?
    By g60rc in forum Drivetrain
    Last Post: 20th April 2019, 6:49 PM
  2. Gears crunching AND clutch slipping
    By wormy in forum Drivetrain
    Last Post: 21st November 2010, 9:13 PM
  3. cant select gears
    By fla in forum Drivetrain
    Last Post: 20th August 2009, 11:23 PM
  4. Low bite point on clutch - why?
    By Alexander in forum Drivetrain
    Last Post: 9th November 2007, 5:48 PM
  5. Replies: 7
    Last Post: 2nd January 2007, 10:11 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
