Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Sunroof internal cover/blind
  1. #1
    Newbie
    Join Date
    22nd May 2008
    Location
    Derbyshire
    Posts
    14
    Right, my sunroof is fully functional, it tilts and slides.
    When it tilts, the internal cover doesn’t lift with the roof. Presumably it should?
    If so, what’s likely to be broke or damaged?
    Cheers
  2. #2
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,944
    There are two little silver "S" shaped pivot bars that lift the internal cover, one on each side near the front of the mechanism - check that these are present on both sides and correctly located.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  3. #3
    Newbie
    Join Date
    22nd May 2008
    Location
    Derbyshire
    Posts
    14
    Quote Originally Posted by fendervg View Post
    Thanks for replying, I'll check this later :-)
    Edit. Cant see an S at all. See pic. Where does it attach?
    Attached Images Attached Images
  4. #4
    Newbie
    Join Date
    22nd May 2008
    Location
    Derbyshire
    Posts
    14
    Anyone?
  5. #5
    Enthusiast 1xshaunx1's Avatar
    Join Date
    14th December 2010
    Location
    near sheffield
    Posts
    410
    From the photos it looks like your trim isn’t attached to the sunroof. You should be adle to pull it forward into postition not sure how it attaches to the sunroof panel though, think there are a couple of fasteners and the slide bit pushes into a lock at the front, you may have take the roof liner out.
    4th one surely the last
  6. #6
    Join Date
    14th December 2010
    Location
    near sheffield
    Posts
    410
    These photos of mine in tilt might help
  7. #7
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,944
    Yeah, it's in the second picture - you can't see the other part that hooks under the trim, but that's the it you're looking for. It might be the case that someone fitted a mechanism from a moonroof onto your car as a replacement and then put the metal panel back on instead of the glass one to keep it looking original from the outside.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  8. #8
    Newbie
    Join Date
    22nd May 2008
    Location
    Derbyshire
    Posts
    14
    I can’t find the item circled on the pic below. Is this the part that lifts the internal cover when tilting?
    What does the item attach to?
  9. #9
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,944
    Yes, that's the part - one on each side. I'd say it's possible either the mech was repaired and they were not put back in, or you have a moonroof type mechanism with the original roof panel on it instead of the glass.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  10. #10
    Join Date
    14th December 2010
    Location
    near sheffield
    Posts
    410
    When you remove the cassette from the car the centre cloth bit comes out with it but I can’t remember how it comes to bits once on the bench. I’m inclined to agree with fend that you have a different cassette with a Corrado sunroof panel in it because the bits you’ve circled aren’t visible in your photos and it needs them to slide:tilt as when they are broken the sunroof won’t drop down properly, I think because yours works as it should without them yours is off something different. That sunroof cover thing you can see the end of I bet that’s not the right part either, can you pull it forward and take a picture.
Similar Threads
  1. I never learn.... Blind purchased corrado VR6
    By Keyring in forum Members Gallery
    Last Post: 27th February 2019, 12:55 PM
  2. WTB: 93+ Sunroof Motor Cover
    By inkarnata in forum Wanted
    Last Post: 5th March 2016, 12:06 AM
  3. Replies: 0
    Last Post: 8th May 2012, 10:20 AM
  4. Replies: 9
    Last Post: 14th June 2011, 4:28 PM
  5. Blind people reversing into VR6's get's !!Funnier!!
    By phaserno1 in forum General Car Chat
    Last Post: 26th April 2004, 7:27 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
