Page 1 of 10 123 ... LastLast
Results 1 to 10 of 91
Thread: Black magic returns home
  1. #1
    ⋆⋆ CF Donator ⋆⋆ Keyo's Avatar
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    682
    Black Magic VR6 Shrick VGI
    After several weeks my car has returned from Stealth Racing in Southam Warwickshire. The car has still got some body work but has now completed it's suspension,subframe,engine and interior renovation
    Last owner a year before I purchased the car had fitted a new Aluminuim radiator and heater matrix, also had a spray job 4 years previous. Timing chains seals and guides at a VW specialist down South 2 months before purchase. New battery, upgraded headlight loom, new passat sunroof, spoiler fully operational. Lupo wipers.
    The works carried over the last 6 months by myself and Stealth.
    Orignal air box souced from Amos, radiator warning trim panel.
    Bonnett insulation from Germany, ebay
    Front fender panel bolts
    Bonnett strut powder coated
    Rear oe VR6 badge VW Heritage
    Warning radiator sticker- VW stickers
    Bonnett earth strap
    BBS Anniversary RS177 16"- Ebay
    X4 Avon tyres
    Milltek Stainless steel catback exhaust
    EEC Catalytic exhaust + gasket
    Exhaust manifold gasket
    Bosch o2 sensor
    Front and rear brake backing plates and bolts
    Brembo front and rear pads and discs on all corners
    Brake calliper
    brake callipers sprayed red
    front wishbones febi
    Oil sump and rubber gasket and bolts
    Bilstein B4 shocks on all corners
    Eibach lowering springs
    Lemforder strut top mounts
    Bump stops, gators and bearings
    Rear febi axle bushes
    Febi track rod ends and drop links
    JP Mass air sensor
    JP Tailgate struts
    Castrol Transmission fluid
    Oe power steering fluid
    Oe Coolant
    Oe Brake fluid
    Quantum oil and Mann filter
    Mann air filter
    Rear Bosch wiper blade
    Sourced a black unmolested parcel shelf
    Parcel shelf straps
    PCV Valve
    PCV breather hose and secondary brach hose
    EVAP Solenoid
    Engine and transmission mounts
    New steering rack
    New power steering pump
    Stainless steel 70L tank straps ebay uk
    Alpine stereo
    Cat 1 immoboliser
    OE First Aid kit and triangle
    Binnacle corner trims Poland ebay
    Leather handbrake handle
    Demister switch
    Light switch
    Seat heating switch
    Door striker pins
    Door screw caps
    A pillar and lower pillar trim caps
    Rear registration light trim
    X3 temp sensors/senders
    x3 oil pressure/temp senders
    Camshaft sensor OE
    Crank sensor OE
    Cig lighter and ashtray housing bulb, glove box
    Bosch 4 bar Fuel Pressure regulator
    Bosch HD leads
    Audi TT Quattro MK1 spark plugs
    Beru Coil Pack
    Fuel and ECU relay
    OIl cooler and gaskets
    Coolant reservoir hose
    Battery cover/bag
    Heated aftermarket wing mirrors
    Fuel filter
    OE engine bay fuel hoses from Germany
    Cluster binnacle surround trim Germany
    Shrick gaskets Bar Tek Germany
    JP Starter Motor
    Subframes , radiator shroud, anti roll bars powder coated
    Eibach anti roll bushes
    Tailgate seal and push rod
    Seat lever trims from GER Ireland
    Airbox rubber ring feet and original o clamps .
    x4 front subframe bushes
    Brake pipes
    Various interior trims and grommets
    Handbrake cable and clips
    Engine HD lead trim panel and star bolts
    Four wheel allignment
    The gear changes are so less notchy after the the transmission change what a difference!
    The spark plugs reccomended by stealth that are used on a Audi TT, must be Bosch ones not the NGK Part number FR7KPP33+
    So been a hell of lot research but happy to report the car drives wonderful and tight,bit of a beast to with the Shrick. Many thanks to Vince at Stealth Racing the Corrado King Pin and his mechanics, VW Heritage and Corrado Forum and members.
    Look forward to catching up with some of you guys at the car shows.
    Cheers.
  2. #2
    car looks fantastic keyo - must be interesting to drive with the shrick - how different does it make the vr6 engine?
  3. #3
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    682
    Quote Originally Posted by ger040 View Post
    Thanks GER040.
    Have to be honest I have never driven a VR6 without one as it's my first ever VR6, my older VW's have been from the Golf MK2,4,7 GTI range. I would say plenty of low down torque and pick up , there is actually a trader in Birmingham that has several of these as he use to import cars from Germany but he wont let them go for no money or kind words .
  4. #4
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    682
    Perfect combination of 90s German V8 + V6 muscle to put two fingers up at the tubo and electric generatiom.
    Attachment 96693
  5. #5
    Enthusiast 1xshaunx1's Avatar
    Join Date
    14th December 2010
    Location
    near sheffield
    Posts
    407
    Very nice.
    4th one surely the last
  6. #6
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    682
    Thank You Shaun.
  7. #7
    CF-oholic! fla's Avatar
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,528
    impressive work there Keyo, must drive like new! Enjoy. And i agree the schrick makes a huge difference to the drive. Have you had yours remapped as well?
    Hasan
    VR6 Auto to manual conversion, beige leather, aircon, TT comps, blue dash lights & switches, Koni TA/Nothelle springs, OBD2, 264 cams, Schrick
    my car
  8. #8
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    682
    Quote Originally Posted by fla View Post
    Thanks fla it does drive like a new car really enjoying it.
    It has had a remap but this was done when the Shrick was fitted in 2003 so not to clued up on the specification/data sheet. However I did track down the owner of the car when it got re mapped from a old receipt and I asked him what are the figures and he said 210 - 220BHP but I cannot clarify this without putting it on a rolling road . I think you have to remap your ECU with a Shrick because it may lead to pinking if left as stock.
    I didnt even know what a Shrick was it just so happens the car I purchased had it fitted so a bit of a bonus really .
  9. #9
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    682
    For those considering changing their temp/oil sensors/senders the picture below might sway you into decision, parts removed from my car. The far right is the only one that has been changed since leaving the factory.
    Attachment 96697
  10. #10
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,848
    Good work there - what a lovey pair!
    How do you find the brakes?
Similar Threads
  1. FOR SALE - Black Magic Pearl Corrado VR6
    By 24V Renshaw in forum Cars for Sale [Corrado]
    Last Post: 28th August 2017, 6:19 PM
  2. Black Magic VR6 - Turbo shopping list started...
    By harryc in forum Members Gallery
    Last Post: 15th March 2011, 6:47 PM
  3. Jamie's Magic Black VR6 - New plans
    By yorkshireone in forum Members Gallery
    Last Post: 21st January 2010, 9:16 PM
  4. Home refurbing A8 'fat fives' black
    By yeti in forum Exterior
    Last Post: 1st July 2008, 8:00 AM
  5. Did they do a Black Magic VR6?
    By Rory in forum Archive
    Last Post: 13th August 2003, 6:37 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
