Results 1 to 9 of 9
Thread: Cooling Radiator rewire guys
  1. #1
    Hi all
    Is there anywhere in the Midlands area that can rewire the entire wiring for the cooling system on a vr6 as mine does whatever it wants
    Cheers
  2. #2
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,893
    What is happening exactly? Check out the definitive VR6 cooling thread stickied in the engine section of the forum for plenty of helpful info - I can't think of a reason why you would need to rebuild the entire loom unless it was butchered or damaged in the past.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  3. #3
    Fans only work on full speed. Both fans come on.
    Sometimes come on when you turn ignition off and take key out. Put key in. They go off
    Today turned car off. Went to shop. Came back and fans had turned themselves on
    Replace temp sensor in rad and large relay by header tank
  4. #4
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,893
    Ok - still worth going through the steps in the guide. Which speed are they coming on at? I presume speed 3 since you say full in your post? The two fans are linked by a belt and the motor only drives one, so both will always spin together unless the belt breaks.
    Have you replaced the temp senders in the thermostat housing at the front of the engine block?
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  5. #5
    CF-oholic! fla's Avatar
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,510
    Sounds like the full speed relay in the fan control unit is stuck. Might be worth removing and dismantling to clean the contacts. I've not taken one apart so cant really suggest any pointers there unfortunately although I'm sure someone can advise.
    Hasan
    VR6 Auto to manual conversion, beige leather, aircon, TT comps, blue dash lights & switches, Koni TA/Nothelle springs, OBD2, 264 cams, Schrick
    my car
  6. #6
    It's the third one and still the same.
    2 used 1 brand new
  7. #7
    Regular
    Join Date
    3rd July 2017
    Location
    Warwickshire
    Posts
    175
    It's worthwhile removing the little fuse strip at the top of the fan module and giving it and the contacts a clean if there is any corrosion forming.
    Fans coming on some minutes after a car has been switched off is a normal occurrence as far as I'm aware.
  8. #8
    Enthusiast 1xshaunx1's Avatar
    Join Date
    14th December 2010
    Location
    near sheffield
    Posts
    357
    Have you tried hot wiring the fan from the battery to see if it will produce all three speeds, I’m wondering if the fan is goosed and will only work on speed 3. If the fan works correctly chase the wires from the fan plug to the controller ( big black relay near expansion tank) the positive feed wires from it to the fan maybe joined together so always sending power for speed 3
    4th one surely the last
  9. #9
    ⋆⋆ CF Donator ⋆⋆ swiftkid's Avatar
    Join Date
    24th May 2007
    Location
    Near Hull
    Posts
    2,810
    Radiator fan speed 3 is the black sensor in thermostat housing not in the radiator, thats stage 1 & 2 I think. I'd start with the basics, unplug fan & bridge contacts to check 12v on each of the speeds (see million page discussion thread). If they all check out then it's likely your actual fan is packing in. If not maybe try another fan control module as they have been known to pack up, I don't know for sure but you might be able to try any fan controller of that era instead of corrado with scene tax added.
    The way the system works is that you have 3 x 12v feeds to the fan (stage 1,2 & 3), stage 1 goes through 2 resistors, stage 2 goes through 1 and stage 3 is direct feed.
    Red 16v gone
    Red VR32.. WIP
Similar Threads
  1. Replies: 18
    Last Post: 23rd February 2015, 3:47 PM
  2. G60 guys...
    By vw_john in forum Engine Bay
    Last Post: 22nd September 2012, 11:31 AM
  3. vr6 dashboard rewire and it doesn't start
    By ryanmac in forum Engine Bay
    Last Post: 16th June 2011, 9:07 PM
  4. Replies: 0
    Last Post: 12th April 2007, 4:39 PM
  5. need a little help guys..
    By tango in forum Drivetrain
    Last Post: 24th January 2007, 10:46 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
