Page 1 of 7 123 ... LastLast
Results 1 to 10 of 65
Thread: 2.0 16v. 1993. Already mostly stripped. Everything must go. Based in Essex.
  1. #1
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st September 2018
    Posts
    51
    Post 2.0 16v. 1993. Already mostly stripped. Everything must go. Based in Essex.
    DICLAIMER!
    Most parts have been off the car for a while and stored in a dry shed. A lot of parts/ components I am yet to organise, so may take a couple days to locate.
    I drove this car for 2 years before I started stripping it. Everything worked as it should, as far as I could tell.
    I am not a mechanic. I have worked with machines, but not cars, so all this info is to the best of my knowledge.
    Some parts are in great condition.
    Most parts have slight wear and tear.
    Some parts have a fair bit of wear and tear.
    I will add more photos in the very near future. Any questions please PM me. If any parts don't have a price, make me an offer.
    If anything is purchased and either does not work properly, or just not be in the condition assumed, I will arrange full refund inc postage.
    I am also listing a lot of parts on Ebay on 7 day listings. If you want a part, I am happy to go direct through here, and I will take down the Ebay listing where possible.
    BIG BITS
    Shell and panels available. Please see my previous posts in the forum and PM me for details.
    VW Estoril, 4 stud, re sprayed in Suzukagru pearl (I cannot currently remember colour code) £100 - Collection. - Chelmsford, Essex. Delivery can be arranged at cost. Tyres thrown in, look good, but need to be checked by a professional as been off the road a few years!
    Attachment 96802
    Engine. Partly disassembled. (intake, rocker cover and camshafts removed but included.) Worked perfectly fine before removal, but been sitting around for a couple years. Some hoses and parts still attached - £100 - Collection. Chelmsford, Essex. Delivery can be arranged at cost.
    20190426_183226.jpg20190426_183659.jpg20190426_183734.jpg20190426_183647(0).jpg20190426_183600.jpg20190426_183511.jpg20190426_183435.jpg20190426_183250.jpg20190426_183714.jpg20190426_183746.jpg20190426_183605.jpg20190426_183545.jpg20190426_183447.jpg20190426_183401.jpg
    Gearbox + driveshafts still attached. (Bolts are a bit rounded)- £60 - Collection. Delivery can be arranged at cost.
    Attachment 96804
    ORIGINAL FACTORY REPAIR MANUAL - £80 posted
    WIRING!
    All wiring looms available. I'm not 100% sure what is what, but 70% of the wiring has been cleaned and cable tied for future ease. PM me to order certain looms and offer me a price.
    Panel strips/ Exterior protective moulding full set - £35 posted
    Attachment 96805
    Attachment 96806
    Headliner control panel trim. Re-trimmed. £20 Posted
    Attachment 96807
    Attachment 96808
    Can't think of the proper part description... £20 posted
    Attachment 96809Attachment 96810
    Coolant reservoir - £20 posted
    Attachment 96815
    Attachment 96814
    Gearstick cover/ gaiter (Karmann) £20 posted
    Attachment 96813
    Attachment 96812
    Attachment 96811
    Bumper location brackets - £15 posted
    Attachment 96816
    ECU - £50 posted
    Steering rack to column joint - £40 posted
    Wiper full set. No blades - £15 posted
    Instrument cluster - £50 posted
    Rear wiper motor - £30 posted
    Steering wheel - £50 posted
    Glove box lid - £20 posted
    Fan control unit module - £20 posted
    ECU - £50 posted
    Fusebox - £60 posted
    Steering column assembly - £60 posted
    Fuel tank cover - £10 posted
    Engine bay plastic cover - £15 posted
    Air filter and housing etc - £35 posted
    Front light units. A couple cracks. - £80 posted
    MORE TO COME VERY SOON
    Last edited by Micky Blue; 27th April 2019 at 12:46 PM. Reason: More information to add
  2. #2
    hi l am looking for a drivers side headlight. All the bits, unit and glass. Do you still have it available? thanks Claire
  3. #3
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st September 2018
    Posts
    51
    Quote Originally Posted by cmk View Post
    I do. They are on ebay also as a pair, but I can revise the listing if you want one.
    Have you checked the pictures? The drivers side is the one that has the fair sized crack in the rear side of the housing. The glass and plastic surrounding the glass looks good. The metal clips have a fair amount of surface rust.
    Would you still be interested even with the crack in the plastic?
  4. #4
    ⋆⋆ CF Donator ⋆⋆ Keyo's Avatar
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    728
    Hi Mick,
    Do you have,
    Part number 535867602 in black
    I'm after the horizontal upper trim panel on top of the inside of the tailgate, the one that has the sliding C shaped plastic clips either end.
    To remove this you must slide the clips back and pull the trim upwards, if pulled outwards or down it will snap the rear clips. It should have five slanted clips on the back built into the trim , I have the C shaped clips all ready.
    Part number 3 in diagram in 4fb(black)
    http://www.oemepc.com/vw/part_single...0/lang/e#sec_3
  5. #5
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st September 2018
    Posts
    51
    Quote Originally Posted by Keyo View Post
    Hi Mick,
    Do you have,
    Thanks for the detailed description. I do have that part somewhere, I am yet to take pictures of every part. Won't take me long to find though, but I will have to get back to you tomorrow I'm afraid. Won't be sure on the condition till then also.
    Thanks
  6. #6
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    728
    Cheers Micky touch base tomorrow.
  7. #7
    Hi
    does the damage affect the moisture resistance of the unit? mine is damaged and the reflector has had water damage. If its only cosmetic l would still be interested. Also do you have the rubber straps for the parcel shelf? mine are perished and l need new ones.
    thanks
  8. #8
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    728
    Does the mfa fully/display work in the cluster binnacle ?
    Does anyone know if this 16v MFA would work correct in a late VR6 as Im sure there are different part numbers for the MFA.
    Cheers.
  9. #9
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st September 2018
    Posts
    51
    Hi
    thanks
    I never had a problem with moisture/ condensation in the unit, but it is a concern as the crack could definitely let moisture in. Where the crack is, it should definitely be fully protected by the bonnet from rain water. I may take the unit to work Monday and do a plastic repair. I still can't promise 100%, but that's the best I can do I'm afraid. If you are worried, maybe shop around some more and give it a couple days thought.
    I do have those parcel shelf straps. They are in good condition as well as far as I can remember. PM me with an offer as I haven't got a price for them as yet.
  10. #10
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st September 2018
    Posts
    51
    Cheers.
    I wouldn't know if it's compatible with the VR6, but the MFA display fully worked that last time I drove it 3 years ago. If someone purchased the cluster, tests it and the display has stopped working, even partially, full refunds and returns will be arranged. I'm just not in the position to test it is all.
Similar Threads
  1. 1993 Corrado VR6 Midnight Blue based in Northern Ireland
    By GusNI in forum Cars for Sale [Corrado]
    Last Post: 7th June 2019, 9:28 PM
  2. For those with MK5 based dailys
    By Dox in forum General Car Chat
    Last Post: 19th January 2019, 7:37 PM
  3. I am new, South Coast based
    By StFoulis007 in forum Newbies Hangout
    Last Post: 28th June 2016, 2:26 PM
  4. Essex Retro Car Show - Battlesbridge, Essex 15/07
    By martinb in forum Event Announcements & Discussion
    Last Post: 15th July 2012, 6:47 PM
  5. ABF without ancilliaries £85 (based in Devon)
    By boost monkey in forum Ebay and Misc
    Last Post: 5th September 2011, 1:17 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
