Results 1 to 10 of 10
Thread: Teves 20 abs wiring loom and abs light
  1. #1
    Regular
    Join Date
    10th May 2007
    Location
    Eire
    Posts
    219
    hi.
    looking for Teves 20 abs wiring loom and abs light.
    \Paddy
  2. #2
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,969
    Best would be to find a Mk3 Golf or a Passat at a breakers and take the whole system - or have you got most of it already?
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  3. #3
    Regular
    Join Date
    10th May 2007
    Location
    Eire
    Posts
    219
    Hi fendervg. I have bracket, pump, a damaged loom with missing light. Have new sensors and rings. All local breakers have no pre2000 vag cars so I'm widening the search and hoping something comes up. I'd take a full system if someone had one and didn't want to split it.
    \Patrick
  4. #4
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,969
    Are you on the Irish Autostadt.ie forum? There's a lad called Niall on there, username SolidOak, who trades as Retrospares, and he was breaking a Mk 3 recently and a couple of others and always has a fair bit of stuff - worth giving him a shout I'd say.
    What part of the country are you in? He's near Longford I believe.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  5. #5
    Regular
    Join Date
    10th May 2007
    Location
    Eire
    Posts
    219
    Thanks fendervg. I'm in the midlands so not far from Niall. I'll pm him. Most of autostadt have moved to Facebook which I'm not on so I miss out on a lot now.
    \Paddy
  6. #6
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,969
    Yeah, not much on the forum any more unfortunately (I hate FB for these kind of things as you can't search and it's too reptitive and of the moment) but Niall is still on there and checks in regularly and lists any new stuff he has.
    What's wrong with your existing system? Is it a G60/16v or VR - I have two VR pumps here in unknown that could probably be tested and refurbished.
    I had the dreaded outlet valve errors and fixed them eventually by replacing my pump unit.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  7. #7
    Regular
    Join Date
    10th May 2007
    Location
    Eire
    Posts
    219
    Hi fendervg. It's a 16v converted to 1.8t. The abs was acting up before I restored it and I removed it as part of the restoration a few years ago. Currently running brembos with a manual brake bias valve for the rear but looking to add back abs now and taking the opportunity to upgrade to the more reliable teves 20 system. Niall has just got back to me and he has a loom so hopefully I'm sorted now.
    Thanks again for the lead.
    \Paddy
  8. #8
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,969
    Ah, good stuff - hope that gets you sorted. That should allow you to get rid of the rear axle bias valve as well.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  9. #9
    ⋆⋆ CF Donator ⋆⋆ swiftkid's Avatar
    Join Date
    24th May 2007
    Location
    Near Hull
    Posts
    2,826
    I presume with you running a 1.8t you've already changed to a stubby/cupra master cylinder? I'm just changing mine over at the moment as I've heard it makes quite a difference. Also doing the teves20 as well so hopefully have decent braking after.
    Red 16v gone
    Red VR32.. WIP
  10. #10
    Regular
    Join Date
    10th May 2007
    Location
    Eire
    Posts
    219
    I didn't have any clearance issues with the master cylinder but I did upgrade to a focus master cylinder when I installed the brembos.
    \Paddy
Similar Threads
  1. Teves 20 ABS warning light
    By Louis in forum Wanted
    Last Post: 19th July 2018, 4:03 PM
  2. Teves 20 upgrade - Wiring help...
    By P3rks in forum Drivetrain
    Last Post: 6th May 2013, 11:25 AM
  3. Uprated Headlight Wiring Loom (...and there was light)
    By Madjackal in forum Suppliers Forum
    Last Post: 11th January 2012, 4:31 PM
  4. Uprated h/light wiring loom
    By faz in forum Exterior
    Last Post: 3rd December 2007, 7:37 PM
  5. Uprated Light Wiring Loom
    By G60Dan in forum General Car Chat
    Last Post: 6th February 2004, 1:15 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
