Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Fuel pump cap inside of boot removal .
  1. #1
    ⋆⋆ CF Donator ⋆⋆ robrado974's Avatar
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,335
    I know your supposed to use the correct tool , but can I get away with putting a cloth over a large flat head screwdriver or blunt chisel?,and tapping it loose ? Iíve tried it by hand but I canít shift it . I presume it isnít a left hand thread ?.
    Kind regards
    Rob
    92 VR6 . DBP. She will never be a show car ..... But will be up there with the best of em .
    The bmw seems invincible in isolation . But along side the corrado - a modern classic , we think- it has its work cut out . Autocar 1992.
  2. #2
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,951
    Yeah, screwdriver and a rubber mallet is how I've always done it - same when tightening - I guess that's what the plastic ridges on the ring are for!
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  3. #3
    standard thread - just chisel it to the left
    some come off easy
    some are tight to the last thread
  4. #4
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,951
    righty tighty, lefty loosey
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  5. #5
    ⋆⋆ CF Donator ⋆⋆ tonedef's Avatar
    Join Date
    4th October 2006
    Location
    Cuckney
    Posts
    993
    And if it’s anything like mine, it’s really easy to cross thread and almost impossible to fit right when refitting it. Of course when it’s not right it leaks fuel all over the floor when I fill up so I can tell straight away!
    95 Classic Green VR6: Climatronic & OBD2, Grey Leather Recaro Interior
    CCGB No. 058
  6. #6
    ⋆⋆ CF Donator ⋆⋆ Keyo's Avatar
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    728
    I would say my fuel pump has def never been changed as the screw cap looks absolutely brand spanking new in my car !!!
  7. #7
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,951
    Yeah, it's usually lovely and clean under there, especially if it's leaking petrol. The reason it's hard to refit is that the seal on the lid with the hoses is really hard to get on properly - I found the easiest way was to dunk it in petrol, then fit it to the lip of the tank opening, and then gently push on the lid until it sits snugly - if done right, the lock ring will go back on easily with no bother.
    You can tell I've been there done that a few times before when it comes to the fuel pump!
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  8. #8
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st December 2004
    Location
    Roma,Italy
    Posts
    2,041
    Also spraying the lockring's threads with silicone spray is another way to avoid cross threading it.
  9. #9
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,335
    Thanks chaps, much appreciated info . I will take a look on Sunday.
  10. #10
    Enthusiast
    Join Date
    23rd April 2017
    Location
    Liverpool
    Posts
    382
    You can make one,flat bit of metal thar fits into the ribs then bend over to fit the rid ring ,fit a large nut bolt in the middle then undo the rib ring they are not that tight
Similar Threads
  1. VR6 fuel pump removal problem
    By DC3 in forum Engine Bay
    Last Post: 27th May 2017, 9:21 AM
  2. Inside boot trim
    By Cressa in forum Interior
    Last Post: 28th December 2016, 3:14 PM
  3. trim inside the boot
    By fonzooorooo in forum Parts for Sale
    Last Post: 20th April 2015, 2:25 PM
  4. Corrado 16v fuel pump and Golf Mk2 16v fuel pump....
    By alackofspeed2 in forum Engine Bay
    Last Post: 21st March 2006, 6:15 PM
  5. Fuel Pump Removal
    By robbo101 in forum Engine Bay
    Last Post: 13th January 2005, 8:27 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupť! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
Follow us
advertising & sponsorship
