Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
Thread: 263 cams + remap or stainless exhaust
  1. #21
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,849
    Multi Layer Steel head gasket, reputed to raise compression
  2. #22
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,980
    Quote Originally Posted by tonedef View Post
    Wish it was, I'd have bought one.......been on the lookout for one at what I'd consider the right price (or more importantly what SWMBO would consider the right price) for almost twenty years!
    Every VSR I'd seen until the last couple of years has been around the £1200 mark.
    95 Classic Green VR6 - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  3. #23
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,980
    Quote Originally Posted by Keyo View Post
    I'm a bit bias because I have a Shrick but I actually think it looks better then a VSR , the Shrick manifold sort of looks like a fist grasping on to the engine , showing my arty farty side there ha ! Totally understand why the VSR has more appeal though as it is VW Motorsport so has heritage.
    There are ways and means gentlemen , I purchased my car for 3k with a Shrick, you could always by a Rado on the market with a Shrick and source a stock Mani and then flip the car . I saw a couple with a Shrick for around 4-5 k , they probably sold for a lot less.
    Ah but the VSR was designed to be on the VR6 as standard and as such, you don't need to remove it to replace the spark plugs like you do the Schrick! Granted, its not particularly difficult to do but thats a poor design feature in my opinion.
    CCGB #3982
  4. #24
    ⋆⋆ CF Donator ⋆⋆ Keyo's Avatar
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    694
    Quote Originally Posted by Geeba View Post
    cant wait to one day finish mine... all those goodies are sat in this... cams, gas flowed head, MLS, high compression wiseco pistons, over-bored, ported manifolds all matched, shrick manifold and new everything... all I need is the most precious thing.... time!
    This looks mint.
  5. #25
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    694
    Quote Originally Posted by seanl82 View Post
    I wouldn't let that put you off a Shrick it's nothing major and sparks don't get changed that often.
    One thing I do wonder about though, what if the piggyback ECU failed would it be possible to replace this.
  6. #26
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,849
    The Schrick tried to balance the inlet runners front and back, big banana, smaller banana etc
    Attached Images Attached Images
  7. #27
    ⋆⋆ CF Donator ⋆⋆ Jamie's Avatar
    Join Date
    22nd February 2006
    Location
    Farnborough
    Posts
    1,363
    Really? Bloody hell I was hoping there’d have gone up a lot more than that. I’ve had mine about 6-7 years and I paid £900 (which was a bargain back then) so just assumed they’d be worth a fair bit by now. Then again it seems like nothing I own has gone up in value, everything I want has rocketed
    There used to be a company in America that made replacements, weren’t cheap but they were available. I don’t actually think there’s that much to them though, just a voltage trigger at a set RPM I think, so someone fairly clued up on electronics should be able to knock something up I would have thought.
  8. #28
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,849
    I can't ever remember VSRs being that low, do you mean VGIs?
    Quick google search
    http://the-corrado.net/showthread.ph...ld-for-the-VR6
    https://forums.vwvortex.com/showthre...otorsports-VSR
  9. #29
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    694
    Quote Originally Posted by Jamie View Post
    Yes It just controls the valve that triggers the round solenoid on top/middle of the Shrick that opens the flap that changes over on 4000 revs I believe , must also get the information from the ECU of the rev measurement, I believe you can program it to trigger the flap on certain rev readings, also the light changes colour on the piggy ecu when you hit the rev trigger for the flap.
    Here is a good thread of someone who just managed to buy the Shrick Manifold without auxiliary components, the flap was broken and he manufactured a new one and managed to source the Solenoid and valve off Ford I think .
    https://forums.mwerks.com/showthread...ICK-VGI-guru-s
    Another great thread on the Shrick.
    https://forums.vwvortex.com/showthre...nd-Information
  10. #30
    ⋆⋆ CF Member ⋆⋆ loepan's Avatar
    Join Date
    15th September 2013
    Location
    devon
    Posts
    486
    Not a chance in hell your seeing a vsr shy of the £1500 mark.....If you do more luck to you
Similar Threads
  1. remap for schrick, cams, obd2 recommended?
    By fla in forum Engine Bay
    Last Post: 5th July 2018, 2:53 PM
  2. Sold Stainless exhaust
    By odub in forum Parts for Sale
    Last Post: 9th January 2017, 9:50 AM
  3. 263 Cams and Remap opinions please
    By Goldie in forum Engine Bay
    Last Post: 16th September 2012, 7:38 PM
  4. stainless exhaust
    By carrots in forum Wanted
    Last Post: 1st May 2011, 11:34 AM
  5. Replies: 9
    Last Post: 22nd May 2006, 9:02 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
