Results 1 to 8 of 8
Thread: Gearbox clatter
  1. #1
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    11th July 2009
    Location
    Leeds
    Posts
    940
    Gearbox clatter
    Started the car this weekend after the first time in a few months. The idle was rough and the car was a bit shaky once the revs dropped, but the biggest worry was when this happened, there was an occasional clattering noise coming from the gearbox. The noise seemed to go away when I raised the revs (or perhaps I couldn't hear it?), and also disappeared when I dipped the clutch, so it's definitely gearbox related. Car is SORN and in pieces (interior, wings and bumpers have been removed as it's going to the bodyshop for new sills next month), so I can't drive it other than a little bit in first and reverse.
    The noise sounds maybe like a marble shaking in there when the whole car shudders.
    I sense a big bill coming. Any ideas?
    2004 Skoda Fabia VRS (daily)
    1995 VW Corrado VR6 Classic Green - Koni T/A + H&R springs, BMC CDA, Climatronic, BBS RCs, 288mm brakes
  2. #2
    Enthusiast Keyo's Avatar
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    798
    Quote Originally Posted by tony_ack View Post
    If it as VR6 are you Sure this is not the timing chain clattering because the guides have failed , if so do not drive the car or could lead to catastrophic engine failure.
  3. #3
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    11th July 2009
    Location
    Leeds
    Posts
    940
    Quote Originally Posted by Keyo View Post
    My initial instinct was it was coming from the gearbox, with the wing off I can reach through and touch the gearbox end plate without getting under the car, and you can feel the rattle (appreciate that it will travel pretty far through metal regardless) Chains did cross my mind, but the noise completely disappears when the clutch is pressed, and returns as soon as I lift it.
    The tensioners and chains were replaced about 50k ago, also had it open about 2k miles ago to install the original cams, primed the tensioner bolt correctly and car ran fine afterwards.
  4. #4
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    11th July 2009
    Location
    Leeds
    Posts
    940
    Regardless, it's going nowhere either way!
  5. #5
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    798
    OK it;s just when you said like marbles shaking, that is the exact description I have seen before for a failing timing chain.
  6. #6
    CF-oholic! Jon_vr6's Avatar
    Join Date
    18th September 2006
    Location
    Cheadle Hulme, Stockport
    Posts
    4,619
    Could be clutch release bearing
  7. #7
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,891
    Quote Originally Posted by Jon_vr6 View Post
    I think so too
  8. #8
    Enthusiast pfnsht's Avatar
    Join Date
    2nd February 2018
    Location
    Herts
    Posts
    434
    Clutch release bearing if it goes when you depress the clutch. May as well do chains at the same time if no history....
    1995 White VR6 CCGB Member 4303
    263 Cams & head refurb | 220 BHP Stealth remap| Miltek non res | Bilstein B12 | R32 Wishbone bushes | VT Mount
Similar Threads
  1. Gearbox Oil and how much?
    By Oldtax in forum Drivetrain
    Last Post: 5th December 2012, 1:58 PM
  2. 16v gearbox
    By Lukasem in forum Wanted
    Last Post: 23rd September 2012, 8:16 AM
  3. VR6 Temporary Death Clatter!!??
    By Fanjita in forum Engine Bay
    Last Post: 9th November 2010, 7:46 AM
  4. Replies: 92
    Last Post: 9th October 2010, 9:02 PM
  5. Gearbox Oil Help Please
    By Blue_Joe in forum Engine Bay
    Last Post: 30th December 2004, 4:14 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
