Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: car failed its mot on brakes
  1. #1
    Sorry i have to start this again as i cant get back into my last post
    I have got a new mot date for a retest on Saturday so have to get this sorted
    i ordered new rear calipers and new handbrake cables (correct length 1015mm as stated on etka)
    So this evening i got them all fitted bled etc but still a problem exists and i am afraid it will fail its mot again
    the handbrake cables are still at slightly different lengths upon entering the handbrake tunnel - not as bad as previous
    Adjusting the cables makes the problem worse the nearside requires more - about 6mm difference with the adjustment
    and lock nuts fitted - surely these should pull up square?
    At one click of the handbrake lever the handbrake begins to bite but there is a difference on the rear wheels i can rotate them with a bit
    of force and the nearside wheel has less resistance easier to turn!
    am i reading to much in to this and once this is on the rollers with the handbrake fully engaged all should be fine?
  2. #2
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    2,213
    I can't say much about the cable length - common sense would say that they should be the same length - unless one of the stub axles, calliper bracket/hub were damaged or out of alignment, or the rear beam itself was aligned incorrectly off to one side - but I'm not even sure how any of that is possible.
    I'd say once the brake lever is fully up and engaged, both wheels should lock and it should pass. Over here in Ireland the NCT tolerance allowed for handbrake imbalance is much more generous than for the foot brake.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  3. #3
    interesting thoughts Fendervg!
  4. #4
    CF Nutter James.'s Avatar
    Join Date
    7th August 2007
    Location
    West Lancashire
    Posts
    1,476
    Check the mounting/welding where the hand brake lever is mounted to the centre tunnel is in good shape. After years of being wrenched at their max, I’ve seen them become detatched before today.
    James likes Corrados. Although he wishes the feeling was reciprocated occasionally.
  5. #5
    Enthusiast
    Join Date
    15th October 2008
    Location
    West Yorkshire
    Posts
    319
    Doesn't matter if they don't pull up square, that's why the linkage bar is there, just adjust till there's even tightness on the wheels at 3 notches.
  6. #6
    ⋆⋆ CF Member ⋆⋆ vw rule's Avatar
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,524
    I've looked on both websites VW Classic Parts and also VW Heritage, both say handbrake cable length 1613mm
    Pattern cables vary in length from 1605mm, 1613mm, 1616mm, 1620mm, 1624mm and 1640mm for the Corrado, which is why I've never bought cheap pattern parts for my Corrado as they don't always fit correctly.
    I was under the impression that the Corrado handbrake cable is the same length both sides, and for all variations ?
    The early Corrado's were based on the A2 platform including front and rear brakes 1989 to roughly 1992
    The slightly later Corrado's including the VR6 had possibly a slight change to the rear brakes more like the MK3 Golf rears 1993 to 1995
    Like I say I thought all Corrado's had the same handbrake cable length 1613mm.
    It's possible the early MK1 Corrado's may have had a very very slight difference in cable length compared to the later MK2 Corrado's, but I've never seen it myself.
    ger040 are you sure you've typed the correct cable length of 1015mm and not 1615mm ??
    Si
    Had MK2 1.8 Scirocco Scarla 1998 to 2002
    had it lowered on original wheels,
    K&N air fitler and Janspeed exhaust system.
    Now have 94 M reg Corrado 2.0 16v since 2002 still got it, been off the road now since early 2015
    hoping to get it finished this year.
    Also have a 2015 Seat Ibiza TSI i-tech as my daily driver. Plus I'm on The SEAT Forum.
    Link to 16v torque settings & ECU pin locations.
    http://the-corrado.net/showthread.ph...fuel-pressures
  7. #7
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,524
    I'd definitely check the welding as James has mentioned, also Simeon is correct that you won't get much of a bit from the handbrake with just one click, plus the biting point isn't always even on 1 click,
    3 to 4 clicks is normally good standard operation for the handbrake with rear disks, and it's 2 to 4 clicks when the handbrake is really biting tight.
    If your getting 5 to 7 clicks before the handbrake bits, then the cables are too slack or the brake calipers are not set up correctly.
    Some people think you can just pump the brake pedal to pump out the caliper pistons on rear brakes, actually this works but not always, sometimes you have to use the piston winding tool, to wind the piston out so it's close to the brake pads, then you can adjust the handbrake cable.
    It's rare but sometimes if you don't wind the piston out evenly on both rear brake calipers it can give problems when adjusting the handbrake.
    Also double check that the cables are located correctly
    where they pass through brackets and tubes.
    Si
  8. #8
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    2,213
    All Corrados use the A2 platform as a base, so the chassis dimensions didn't change over the length of the model run. The main difference was that the VR6 ran 5-stud wide-track "Plus" suspension, so the geometry there is different - maybe the rear callipers sit a few mm further out due to the wider rear beam? Hence there might be two lengths of cable - one for G60, 16v and 8V, exactly the same as the Mk2 Golf, and one slightly longer one for the wide track VR.
    But the rear calliper and handbrake set-up would have been standard across all A2 platform cars and many other VWs of that vintage. ETKA lists 2 different part numbers and a chassis number break, but they are both shown as being the same length at 1613mm, so it's probably just a super-cession to a later revision part - the base part# is the same.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  9. #9
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,977
    ReAr axles are the same, only the front went wide track, rear arches are the same as early and late.
    Set the brakes with the handbrake disconnected using the pedal, short strokes are the best way for this not pedal to be floor - keep the master cylinder in its normal range of movement.
    Then attach the cables making sure the brake levers on the callipers return to there stops. Adjust the handbrake so the brakes bind on two clicks, this should then hold firm on 4-5 clicks
  10. #10
    To my knowlage there is two different cables.
    All G60 and early Corrado models, my guess is before facelift, have shorter cables 1604mm.
    And later Corrados have 1613mm.
    I think there is a misstype in etka, would not be the first time.
    1H0609721A short
    1H0609721E long
    Google the OEM part numbers and you'll see the lengths.
    And you can adjust the cable a few mm at the caliper where the spring sits if needed but be careful it's easy to brake it and it could snap off. Would go for calipers from Golf MK4 instead as the original seems to lock up sometimes.
    -93 Moonblue Pearl VR6 2.9 OEM+
Similar Threads
  1. car failed its mot on brakes
    By ger040 in forum Drivetrain
    Last Post: 26th July 2019, 2:50 PM
  2. 288 front brakes and standard rear brakes
    By lilfuzzer in forum Parts for Sale
    Last Post: 20th April 2015, 7:28 PM
  3. Brakes failed help
    By chopper666 in forum Drivetrain
    Last Post: 18th March 2013, 1:27 PM
  4. Failed MOT on brakes :-(
    By krishen in forum Drivetrain
    Last Post: 23rd October 2012, 5:54 PM
  5. 312mm front brakes and 256mm vented rear brakes
    By Dox in forum Parts for Sale
    Last Post: 1st March 2012, 1:01 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
