Hi folks, seem to have an issue with my Corrado,
last week the ignition switch packed in, got a new one fitted went out a run and it cut out and hasn't run since, with ignition on there is no power at the coil, I disconnected the hall sensor and it primed the fuel pump, its getting fuel to the point I get a very raw smell of fuel.
is there a crankshaft sensor as I cannot find one apart from the two knock sensors on the front of the block. iam no electritian so any help from you guys would be great.
