Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Drivers side Door handle, urgently required.
  1. #1
    Hi there,
    Does anyone have a drivers side Door handle with the butterfly washer (- that sits inside the door behind the lock)???
  2. #2
    ⋆⋆ CF Member ⋆⋆ vw rule's Avatar
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,391
    Hello there,
    I think the Passat B3 1988 - 1991 door handles fit the Corrado, but you'll have to change over the lock barrel so you can still use your own key, and of course the butterfly washer thing might be different, but a part from that it's basically the same handle I think.
    I think possibly the right hand side repair kit for the door handle, is still available at VW Classic Parts, but the left side repair kit isn't.
    I'll see if I can find it and post up a link for you.
    Si
    Had MK2 1.8 Scirocco Scarla 1998 to 2002
    had it lowered on original wheels,
    K&N air fitler and Janspeed exhaust system.
    Now have 94 M reg Corrado 2.0 16v since 2002 still got it,
    been off the road now since early 2015
    hoping to get it finished this year.
    Also have a 2015 Seat Ibiza TSI i-tech as my daily driver.
  3. #3
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,391
    Here's the link
    https://www.volkswagen-classic-parts...tz-fb24a5.html
    Says repair kit for right outer door handle, part number 535 898 084
    €6.99 in stock at VW Classic Parts.
    Speak to VW Heritage first to be 100%
    The left door handle repair kit is still obsolete I think.
    Part number 535 898 083
    Hope this helps
    Si
  4. #4
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,391
    Unbelievably looks like there's the right handle repair kit on EBay.
    Ebay item number 192872547443
    Cost is roughly £12 including shipping from Latvia.
    I think the kit should consist of the following:
    1 Small circlip
    1 spring
    1 rubber seal
    1 Locating washer
    1 butterfly or wing washer
    Si
  5. #5
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    2,002
    Are these repair kits different to the striker repair kits for a broken handle? I thought that was the most common way for them to break.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  6. #6
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,391
    Quote Originally Posted by fendervg View Post
    I think the striker arm as you say can be replaced by the stronger stainless ones,
    I think Dave16v is or was making the stainless replacements.
    The actual repair kit from VW Classic Parts, is what used to be available from VW Main Dealers years ago.
    Sometimes the small round spring can break or the butterfly/wing type contact washer thing can break.
    These are basically two different repair kits, as there's more then one part of the door handle that can break over time.
    Si
  7. #7
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,391
    This link might work,
    it should show the right side repair kit for door handle.
    Part number 535 898 084
    https://images.app.goo.gl/sP4rBSqd1FULzxEq6
    The Passat and Corrado handles are pretty much the same, but the repair kits are different, which is why you have to change over your lock barrel as that is keyed to match your own key, and the butterfly/wing type connector washer arm is different,
    a part from that it's the same door handle I think.
    I think the butterfly/wing type arm thing is connected to the back end of the lock barrel, so basically when you lock the door via your key, I think it rotates round so the striker arm can't connect, but when unlocked the striker arm can then make contact allowing you to open the door.
    I think the butterfly/wing type arm is fairly deep/ tall on the Corrado.
    Whereas on the Passat it's shallower/shorter, I think that's right anyway.
    Si
  8. #8
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    2,002
    Ah ok - yes, that's a different part of the mechanism.
    From what I remember, a common mod was to use Passat rear handles on a Corrado, to effectively de-lock it.
    Not really sure about the front handles - I'm thinking if it was easy as simply substituting them, it would be widely documented, and an easy fix as the Passat ones would be easily available. I think the mechanism is considerably different - some of the instructions for the rear handle retrofit involve a fair bit of modification - but I haven't seen a Passat handle in the flesh to be able to compare.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  9. #9
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,391
    That's what I recall I'm sure there's a thread about that somewhere, which is why I thought about the front Passat handles, unless no one has tried them.
    Anyway I've ordered a Passat handle and will try it and see how it goes,
    surely it can be done especially like you say the rear ones fit with slight tweaking.
    Si
  10. #10
    Hi All,
    Thanks for the info.
    It has been a bit of a nightmare tbh. The car failed its mot on a light (aimed up), rear shocks and springs, and the door not opening from the outside.
    (its been like that for a few months, its a bit of an inconvenience but less so than not having use of it at all like now).
    All the rest has been fixed but the door. The rear suspension was surprisingly easy - I was bricking attempting it & for the 1st drive afterwards, but was straight forward...
    With the handle.
    When you pull the handle there is a hammer piece (with the round white plastic end bit, which had snapped apparently that is the common fault, I got the upgraded stainless steel hammerer looking piece, but when I got the lock/handle out, the butterfly bit that goes behind the lock barrel just fell into about 20 pieces in my hands hahaha.
    VW Rule, many thanks for the link. :-)
Similar Threads
  1. VR6 drivers side door handle
    By crazycarlsworld in forum Cars for Breaking
    Last Post: 14th December 2017, 6:41 PM
  2. Drivers side door handle VR6
    By apeks in forum Wanted
    Last Post: 28th February 2015, 11:21 AM
  3. Drivers side door handle
    By twinny in forum Wanted
    Last Post: 23rd June 2014, 8:13 PM
  4. Door handle for drivers side
    By alanholden in forum Wanted
    Last Post: 15th December 2011, 11:37 PM
  5. Drivers side door handle
    By sam2.0 in forum Wanted
    Last Post: 3rd December 2011, 5:21 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
