Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: Another Oil Sensor Thread!
  1. #1
    Gents,
    I know this has been asked before but i cant seem to find a decent answer....
    Does anybody know parts number or have links to the oil sensors that go into the housing on a abf or 9a?
    I have 3 spaces for sensors and i would like to buy new parts. I dont have the old sensors for reference anymore.
    Thanks in advance!
  2. #2
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    2,003
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  3. #3
    Enthusiast Keyo's Avatar
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    835
    I renewed all my sensors /switches on my MK2 golf 16V kr recently. Part number 049 919 501 its the same as on the KR engine, I also changed the one at the rear of the block, the 2 pin brown thermal switch(yours will be white) and the two above the oil cooler.
    They are now obsolete from VW , the best you can get are Beru ST053, Thats if its the three on the right side of the block your after under the distributor.
    There are other aftermarket ones available but Beru you got to go with IMO. Quality !
    https://www.ebay.co.uk/itm/Beru-ST05...QAAOSwh8NbSNn8
  4. #4
    Wow, I forgot how responsive you guys are on this forum, I always get some good advice quickly on here!
    Keyo, im replacing the ones on the oil cooler housing , the beru looks good , do you have a link for the correct ones for the front of the block?
    FenderVg, I did have a quick look on parts cat but when trying to order there are lots of variations now , I will try again, thanks for the link.
  5. #5
    ⋆⋆ CF Member ⋆⋆ vw rule's Avatar
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,396
    From what I can remember and what I've found in my service history going back to 2009, I think these are the original part numbers for the 9A engine, possibly similar or the same for the ABF & KR
    High pressure oil sensor switch
    (white 1.8 bar)
    Part number 056 919 081
    Oil pressure secondary switch
    (brown 0.3 bar)
    Also you can get the blue one below.
    (Blue 0.4 bar)
    Part number 028 919 081H
    Oil temp sender
    Part number 049 919 563A
    Normally fits in back of head on 9A & ABF
    the KR might be on the oil filter housing.
    Si
    Had MK2 1.8 Scirocco Scarla 1998 to 2002
    had it lowered on original wheels,
    K&N air fitler and Janspeed exhaust system.
    Now have 94 M reg Corrado 2.0 16v since 2002 still got it,
    been off the road now since early 2015
    hoping to get it finished this year.
    Also have a 2015 Seat Ibiza TSI i-tech as my daily driver.
  6. #6
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    835
    Quote Originally Posted by vw rule View Post
    (white 1.8 bar)
    (brown 0.3 bar)
    (Blue 0.4 bar)
    Oil temp sender
    Si
    I fitted the white oil switch to my Mk2 golf this weekend above the oil cooler , I tightened it then it seemed to loosen a bit and then go to the same tightness again which is pretty sturdy , hope I have not threaded it. Also fitted one of The Buri coolant sensors, the one that the spade ends fit on to on the side of the block KR engine , learning quickly one snapped off whilst tightening , these things are pretty damn fragile but look like a solid nut. Managed to tap an oversized flat head screwdriver into the bit left in the block and it bite enough so I could screw it out, came out in one piece thank god. Had to order a new sensor grrrr !
    What would be folks tighten on these , say tighten in till stiff then half a turn ? , am I the only buffon that has snapped one of these !
    Another thing is I would get some new female brass spade ends if doing this job as the end of the cables were pretty rotten and the spades literally fell off the end when dislodged with the rotten end of the fragile electric cable. I stripped back and made a nice thresh bit of end cable and put the new spade on.
  7. #7
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,396
    Quote Originally Posted by Keyo View Post
    I've just had a quick read through the Bentley Manual for the (9A) 16v engine,
    it'll be similar for the (KR) 16v.
    Basically it doesn't give any torque settings for the oil pressure switches.
    The OEM switches from new normally had a small amount of red or yellow thread lock on the centre of thread, you normally screw the oil pressure switch in by hand until it stops on the front edge of thread lock, you possibly might be able to just still turn it by hand another 1/4 or 1/2 turn, then it'll be too tight to turn by hand, so you'll need a spanner or ratchet and socket to tighten up properly,
    when using the spanner or ratchet it should start of really easy to turn the oil pressure switch, then as soon as you feel any slight resistance go easy.
    For me personally I'd say (12 to 15 ft.Ib) max for the oil pressure switch, do not tighten anymore then that.
    Oil filter housing bolts
    25 Nm (18 ft.Ib)
    Oil cooler retaining nut
    25 Nm (18 ft.Ib)
    Also says on the 16v engines that they have extra oil pray nozzles attached to base of cylinder bores, these nozzles open up at oil pressure above 3.5 bar (50 PSI)
    Regarding the oil filter, make sure both surfaces are clean on oil filter housing face and oil filter sealing rubber ring,
    then smear small amount of oil or grease over oil filter sealing rubber ring,
    when refitting oil filter screw on by hand gently until it stops, then grip oil filter tightly and turn 3/4 to 1 full turn max, don't tighten anymore then that.
    REMEMBER to smear a small amount of oil or grease on the oil filter sealing rubber ring, or you'll never be able to remove your filter next time.
    Si
  8. #8
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,897
    I doubt the sensors - especially the brass ones will take half a turn, 10mm x 1mm pitch, so essentially you’re trying to stretch the threaded part 0.5mm or crush the copper washer similar. I’d go finger tight and a nip and monitor for seepage.
  9. #9
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    835
    Thanks for the advice guys, I should of posted this before fitting them , didn't help my old ones were very old that they took quite a bit of pressure to release and assumed the new ones must be the same . When I fit my new fuel injector lines and start the engine i'll be be examining the engine bay for leaks , knowing my luck it will be like Niagra falls in there.
    Anyone know what the torque is for the Banjo bolts on the injector lines.
    Cheers,
  10. #10
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,396
    Cheers,
    According to the Bentley Manual,
    the 4 Banjo bolts for the injector pipes in the fuel distributor are:
    10 Nm (7 ft.Ib)
    Large Banjo bolts around metering head are 20 Nm (15 ft.Ib)
    Small Banjo bolts around metering head are 10 Nm (7 ft.Ib)
    Plus are the same torque settings for large & small Banjo bolts on the fuel pressure regulator that's bolted to front of engine block on (KR) 1.8 16v
    Large Banjo 20 Nm (15 ft.Ib)
    Small Banjo 10 Nm (7 ft.Ib)
    Also the same torque settings for both fuel pipes on the fuel pressure regulator on (9A) 2.0 16v this one is bolted to side of metering head.
    Large pipe 20 Nm (15 ft.Ib)
    Small pipe 10 Nm (7 ft.Ib)
    But this doesn't have Banjo bolts.
    Hope this helps
    Si
Similar Threads
  1. OBDII lambda sensor thread
    By p0l1wrath in forum Engine Bay
    Last Post: 14th August 2014, 10:08 PM
  2. Crankshaft Position Sensor/Engine Speed Sensor
    By oneohtwo in forum Engine Bay
    Last Post: 22nd January 2014, 11:29 PM
  3. Blue Sensor? Yellow Sensor? Thermostat?
    By jpowell79 in forum Engine Bay
    Last Post: 14th March 2010, 9:41 PM
  4. VR6 oil temp sensor thread size?
    By schrickvr6 in forum Engine Bay
    Last Post: 18th July 2005, 6:46 PM
  5. The Thread In My Head Is Cross Threaded...Thread
    By Walesy in forum Engine Bay
    Last Post: 16th July 2005, 8:38 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
