Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Stumped by the stereo wiring
  1. #1
    ⋆⋆ CF Member ⋆⋆
    Join Date
    19th March 2009
    Posts
    879
    Question Stumped by the stereo wiring
    Hi there,
    I've recently tried to tackle my lack of a stereo, it works as I tried it my other car.
    I've traced and the switch ignition (red/brown) all the way to the ignition switch and it buzzes out ok.
    I've done the same with the red/white to the back of the fuse box. Ground buzzes out on other grounds too.
    So I'm a little stumped what to do, when lights are on it lights up (grey/blue illumination), when battery is connected security light flashes.
    Anything I'm not doing that I should be? I've used this wiring diagram https://imgur.com/Q7rOWsk
    16v Moonlight Blue
    1994 VR6 Green Pearl
  2. #2
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    2,212
    What make stereo is it? IGN+ and BATT+ usually need to be reversed to work an aftermarket unit properly.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  3. #3
    ⋆⋆ CF Member ⋆⋆
    Join Date
    19th March 2009
    Posts
    879
    Quote Originally Posted by fendervg View Post
    VW Gamma from a mk4 golf
    16v Moonlight Blue
  4. #4
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    2,212
    Have a look at these and see if they help...
    I'll also try and PM you another PDF I have with more details on the Gamma in English - it's too large to attach here.
    Actually, PM me with an email address if you need it - can't attach files to PMs.
    Attached Files Attached Files
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  5. #5
    ⋆⋆ CF Donator ⋆⋆ swiftkid's Avatar
    Join Date
    24th May 2007
    Location
    Near Hull
    Posts
    2,875
    That PDF doesn't seem to work fender.
    Try this: https://pinoutguide.com/Car-Stereo-V...H_pinout.shtml
    If it's lighting up, powered up etc. I'd hazard a guess and say the pins are wrong on the plug into the head unit itself. Even if ignition live & permanent were mixed up it would still fire up.
    Red 16v gone and long forgotten
    Red VR32.. Always a work in progress
  6. #6
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    2,212
    Yeah, I don't think the attach feature is working properly since the last set of forum issues - it also won't let me upload a jpg, keeps complaining that it's not a valid file, even though I know I have attached the self-same image to another post before.
    I sent culshaw another doc I have, so hopefully that might help with the pinout. One thought I had - is it possible that it's code disabled? In that case you need to leave it powered on for a long time before it resets itself.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  7. #7
    ⋆⋆ CF Member ⋆⋆
    Join Date
    19th March 2009
    Posts
    879
    Quote Originally Posted by swiftkid View Post
    It lights up as in if you turn on your lights, it'll illuminate.
    It doesn't get backlit, the only indication it's receiving power is a flashing security light
    I think it's definitely getting power, because i've blown a fuse when two wires touched, after that. I've disconnected the battery like a good boy
    16v Moonlight Blue
  8. #8
    Join Date
    24th May 2007
    Location
    Near Hull
    Posts
    2,875
    See in the link I attached, I'm betting you've got the first 2 wires on top row connected and 1st wire on second row connected. Check the 3rd wire along on top row as that's your ignition live
  9. #9
    ⋆⋆ CF Donator ⋆⋆ ben_wooduk's Avatar
    Join Date
    23rd November 2005
    Location
    Hednesford, Staffs
    Posts
    658
    I've recently fitted a gamma myself but it started doing some funky stuff first, try my thread here, someone helped me crack it my changing one wire
    http://the-corrado.net/showthread.ph...-K22-BRW/page8
    Ben Wood
    CCGB #3443
    1993 Black VW Corrado 2.9 VR6
    Previous:
    1994 Aqua Blue VW Corrado 2.0i 16v
    1995 Sherry Pearl VW Corrado 2.0 8v
  10. #10
    ⋆⋆ CF Member ⋆⋆
    Join Date
    19th March 2009
    Posts
    879
    Thanks guys,
    I've followed that pinout guide to no avail. I did some more voltmeter investigations.
    ignition to stereo buzzes out (i expect this is normal) - reading of around 0.07
    ignition to r/wh (perm live) when turned to accessory position buzzes out - reading of -0.05
    ^ I have a feeling this is not normal
    Also switched the wires around between perm live and ignition to see if security light flashes when key in accessory position, it didn't flash.
    Could something be shorting?
    16v Moonlight Blue
Similar Threads
  1. Stereo wiring
    By NWDSdax in forum ICE 'n' Secure
    Last Post: 15th January 2019, 10:32 PM
  2. Stereo wiring help please :)
    By Hairyarse in forum ICE 'n' Secure
    Last Post: 10th September 2014, 5:01 PM
  3. Replies: 1
    Last Post: 21st May 2013, 7:09 AM
  4. Stereo Wiring
    By petemcr in forum Interior
    Last Post: 24th May 2011, 10:59 AM
  5. stereo wiring, whats what?
    By dubburke in forum ICE 'n' Secure
    Last Post: 10th October 2006, 10:12 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
