Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Abs pump 358614217 :)
  1. #1
    Hi guys Iím looking for an abs pump to get my Corrado back in business!! Thank you
  2. #2
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    2,041
    What type of engine C is it for as they are different - G60/16v/VR?
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  3. #3
    Ooo not sure I will check.. I know itís the 2.9 vr6 and itís L reg. the part number as in the title. 358614217
  4. #4
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    2,041
    ABS pumps for VR6 have been extensively discussed, and are sadly hard to source in good working order. What do you believe is wrong with it? Have you pulled the fault codes from the ABS control unit?
    Only asking this as there are plenty of other parts that can fail in the system that are cheaper.
    If you've just won the lottery, VW are still selling them new for just over £1000. Other options are a second hand one, but many of those are also fauly, or some have had luck getting a company called BBA-Reman to chekc them over and refurb. however the feedback seems to be mixed. This will still cost you a couple of hundred with no guarantee that the donor unit is repairable.
    Some have opened them up and noticed that bad solder joints on the PCB on the bottom could be causing the problems and have had these repaired.
    Or, ever more popular, is to do an ABS delete, or upgrade to a later more modern system from the Mk3/Passat, but this is not a two spanner job and you need to source the parts.
    Hope this helps a little with the options, you might get offered a part on here, or other helpful info.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  5. #5
    Thanks for all the info.
    I just had a reply from a company called ďEcu testingĒ they are sending mine back just saying they canít do anything with it. Do you think I should give BBA a call?
    The fault codes are as follows:
    00280 valve 2 for differential lock -N126-lost23
    00279 valve 1 for differential lock -N125-lost23
    Thanks.
  6. #6
    ⋆⋆ CF Donator ⋆⋆ Keyo's Avatar
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    983
    Yes or upgrade your abs system to Teves20 , can be found on the forum if you use search function.
    I do have an abs ECU available but I dealt this would solve your problem but I'm no expert on the system, maybe others could advise.
  7. #7
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,918
    Quote Originally Posted by Jonnyo View Post
    I just had a reply from a company called “Ecu testing” they are sending mine back just saying they can’t do anything with it. Do you think I should give BBA a call?
    Thanks.
    I can't ever remember seen those codes before? Has your ABS ever worked?
  8. #8
    We reset it once and the codes went away. As soon as I tried to use the abs they came back.
    I donít think I can afford an upgrade of the abs so would prefer to keep it standard if possible.
  9. #9
    Iíve got one off of my J reg g60 if itís any good to you?
  10. #10
    Thanks is the part number 358614217
Similar Threads
  1. URGENT Vr6 oil pump & power steering pump
    By Tony_familiaruk in forum Wanted
    Last Post: 29th December 2015, 8:09 AM
  2. Replies: 6
    Last Post: 30th May 2015, 6:18 PM
  3. Lift Pump/Fuel Pump Assembly help -
    By Moreado in forum Engine Bay
    Last Post: 25th May 2013, 1:44 PM
  4. Locking pump which wires make it pump
    By leeeeshad in forum ICE 'n' Secure
    Last Post: 12th August 2011, 4:37 PM
  5. Replies: 19
    Last Post: 5th March 2009, 10:31 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupť! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
Follow us
advertising & sponsorship
