Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Fitting a VSR intake.
  1. #1
    How had is it to fit a vsr manifold?
  2. #2
    ⋆⋆ CF Donator ⋆⋆ Keyo's Avatar
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    1,110
    Does the VSR have a piggy back ECU like the Shrick and a solenoid that moves the flap , I don't know much about the VSR to be honest.
  3. #3
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    1,110
    Here are the Shrick instructions if that is a help.
    https://autotech.com/instructions/i129020K.pdf
  4. #4
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    2,099
    VSR requires a dedicated replacement OEM ECU that would normally come along with the manifold. This has a different map and a control wire on it. There should also be a green vacuum reservoir and hoses with t-piece, this operates the flap inside the manifold. All other work is exactly the same as removing and refitting the standard intake manifold, same gaskets, so you can either reuse your old ones or fit new ones. Everything else will match up and you will even be able to access your spark plugs, unlike on the Schrick VGI.
    My advice is to send me the VSR and I will show you how to fit it on my VR6!
    Seriously, though - Vince at Stealth knows these inside out and should be able ot help, even if you are missing the ECU. I have seen VSRs being run wit the Schrick control box and mild remap.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  5. #5
    Yeh I have the ecu and the chip by done by Vince for fitting too
    Only if you send me your car with it fitted on it afterwards
    The ecu is a grey or should it be in a black box
  6. #6
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    2,099
    Not sure about the colour - the only one I've seen in a while was on German Ebay a while back, and that was a whole ECU box, a direct drop-in replacement for the factory unit under the rain tray.
    Here are some pics of the whole shebang - and they show a black control box, but my understanding was that the ECU had to be swapped out as well.
    https://forums.mwerks.com/showthread...old-components
    Also, the first post here ins a translation of the original German write-up when the VSR was being marketed - note that it refers too an additional output wire from the new ECU to send a switch control signal to the black box. Yhis is what I've seen in the past, whereas the Schrick is just a standalone control box hooked up to an RPM signal from the coil.
    http://the-corrado.net/showthread.ph...-VSR-Explained
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  7. #7
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    1,110
    Quote Originally Posted by fendervg View Post
    That black box is a piggy back Ecu that will connect to the existing ECU , all it does is receive a signal from the ECU RPM that will then signal to the solenoid to trigger the flap at the desired setting, tends to be set at 4000 revs, looks the same set up as Shcrick just with slightly different colour/ shaped parts/connectors. It will be designed to plug and play with a stock VR6 ECU.
  8. #8
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    2,099
    Ok - so you could probably just hook it up to the coil or splice into the RPM signal to get it to work?
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  9. #9
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    1,110
    Not sure about that but I would imagine that a Shcrick ECU piggy would do the same job as VSR piggy and work on either , although the only problem is both are rare , no dealt it will be a right pain if these little piggies ever get water damaged.
  10. #10
    The box ecu I believe is grey on mine
Similar Threads
  1. Oil within the air intake
    By jackswan2013 in forum Engine Bay
    Last Post: 26th January 2017, 7:15 PM
  2. VR6 Air Intake
    By hombre_paulo in forum Wanted
    Last Post: 10th March 2011, 1:11 PM
  3. Replies: 16
    Last Post: 20th June 2009, 8:27 PM
  4. Intake
    By Patch in forum Engine Bay
    Last Post: 5th April 2008, 7:54 PM
  5. what air intake?
    By Welsh g60 in forum Engine Bay
    Last Post: 14th March 2004, 8:21 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
