Results 1 to 10 of 10
Thread: G60 front caliper slide pins
  1. #1
    CF Nutter
    Join Date
    15th October 2009
    Location
    wrexham
    Posts
    2,194
    Can anyone tell me the front caliper slide pins part number. I want to fit new ones to mine when I paint calipers next year.cheers
    1990 1.8 16v white
  2. #2
    ⋆⋆ CF Member ⋆⋆ vw rule's Avatar
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,524
    Hello there,
    according to ETKA it's listed as below:
    Protective boot/sleeve set for guide pin
    Part number 8E0 698 470B
    Slide guide pin with pad carrier (up to 1991) up to VIN 50-M-027-000
    Part number 857 615 125
    Slide guide pin with pad carrier (after 1991) after VIN 50-M-027-001
    Part number 357 615 125C
    You might find a set of slide guide pins on eBay, or if you enter part numbers into Google it should hopefully show you other options.
    Hope this helps
    Si
    Had MK2 1.8 Scirocco Scarla 1998 to 2002
    had it lowered on original wheels,
    K&N air fitler and Janspeed exhaust system.
    Now have 94 M reg Corrado 2.0 16v since 2002 still got it, been off the road now since early 2015
    hoping to get it finished this year.
    Also have a 2015 Seat Ibiza TSI i-tech as my daily driver. Plus I'm on The SEAT Forum.
    Link to 16v torque settings & ECU pin locations.
    http://the-corrado.net/showthread.ph...fuel-pressures
  3. #3
    CF Nutter
    Join Date
    15th October 2009
    Location
    wrexham
    Posts
    2,194
    Cheers I've looked on ebay I need the correct length
  4. #4
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,524
    I think this is the correct measurements but you'll need to check with your old one.
    Pin Shaft length 59mm
    Thread size M8 X 1.25mm
    Brake carrier measurements ending 125
    Length 182mm
    Width 105mm
    Height 85mm
    Weight 1.05kg
    OEM Make: Girling
    Pin Shaft length ?? Not sure about length on this one could be difference of 2mm ?
    Thread size M8 X 1.25mm I think ?
    Brake carrier measurements ending 125C
    Length 185mm
    Width 105mm
    Height 85mm
    Weight 1.18kg
    OEM Make: Girling
    I'll see if I can find anything else.
    Hope this helps
    Si
  5. #5
    CF Nutter
    Join Date
    15th October 2009
    Location
    wrexham
    Posts
    2,194
    Think I will have yo take them apart next spring to measure them as the chassis number is a 16v .someone fitted the g60 brakes in the past
  6. #6
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,524
    Regarding the 16v slide guide pins,
    this is the info according to ETKA.
    Slide guide pin with pad carrier (up to 1991) up to VIN 50-L-012-851
    Part number 443 615 125B
    Brake carrier measurements starting 443
    Length 185mm
    Width 95mm
    Height 78mm
    Weight 1.08kg
    OEM Make: Girling
    This one is possibly obsolete now ?
    Slide guide pin with pad carrier (after 1991) after VIN 50-L-012-852
    Part number 357 615 125B
    Brake carrier measurements starting 357
    Length 185mm
    Width 95mm to 100mm
    Height 78mm
    Weight 1.08kg
    OEM Make: Girling
    Can't really see find anything else.
    Hope this helps
    Si
  7. #7
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,524
    The Slide guide pins possibly are £8 to £12 for a set per side.
    Pad carrier complete with slide guide pins are £25 to £50 for aftermarket ones, but for OEM from Classic Parts or through Heritage, are something like £150 each.
    The only part number/item that I think is obsolete now is 357 615 125B
    All the others listed in above posts I believe are still available.
    Hope this helps
    Si
  8. #8
    Enthusiast
    Join Date
    15th October 2008
    Location
    West Yorkshire
    Posts
    319
    BiggRed sell these I think, can probably tell you which ones you need too.
  9. #9
    CF Nutter
    Join Date
    15th October 2009
    Location
    wrexham
    Posts
    2,194
    Sorted now thanks
  10. #10
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,524
    Good to hear you got it sorted.
    Si
Similar Threads
  1. Slide pins question! Have I shafted my carriers?
    By mattnorgrove in forum Drivetrain
    Last Post: 6th May 2010, 7:36 AM
  2. What to lube caliper pins with?
    By V-Dubstar in forum Drivetrain
    Last Post: 4th May 2010, 7:55 AM
  3. how much free play on caliper slider pins..??
    By plateletboy in forum Drivetrain
    Last Post: 30th August 2007, 4:41 PM
  4. VR6 rear caliper carrier/guide pins
    By Andy T in forum Drivetrain
    Last Post: 9th May 2007, 8:28 AM
  5. VR front Caliper
    By Dub Style in forum Engine Bay
    Last Post: 27th November 2004, 11:55 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
