Page 2 of 223 FirstFirst 12341252102 ... LastLast
Results 11 to 20 of 2227
Thread: Definitive 24v into a (VR) Corrado thread
  1. #11
    Enthusiast
    Join Date
    13th June 2005
    Location
    Isle of Man
    Posts
    897
    Well I guess it was being a bit too hopeful that it would just be THAT easy.
    Oh well, I've bought it now, so I'll have a go at fitting it myself.
  2. #12
    CF Nutter
    Join Date
    8th November 2002
    Location
    enfield, n.london
    Posts
    1,545
    sadly no engine conversion is ever going to be easy everything has its down side sadly
    but going by what Ive read its meant to be worth it once its done good luck
    alex
    ex - ccgb 1372 member
    http://www.corrado-database.nl/index.ph ... ado&id=420
    J-RAN sadly gone But I have 477bhp, 30v and two turbos to keep me happy now
    http://www.ukpassats.co.uk/phpbb/viewto ... ?f=5&t=240
  3. #13
    CF Nutter
    Join Date
    30th November 2004
    Location
    Manchester
    Posts
    1,091
    xbones, lol at your sig
    "coming not so soon"
    Now 24v V6 RWD 207 bhp its an Opel...honest!
    Previously 1994 2.0 16V Ice Grey RIP
    Xbox 360 Tag: Sintellins
  4. #14
    Super Moderator Kevin Bacon's Avatar
    Join Date
    5th March 2003
    Location
    Essex
    Posts
    26,749
    Quote Originally Posted by xbones
    It is easy :-)
    Can I angle grind your bonnet? :-)
    Did have: 94 Corrado R32
    Now have: 2004 Golf R32
  5. #15
    Enthusiast
    Join Date
    13th June 2005
    Location
    Isle of Man
    Posts
    897
    I was going to Dremel it!
    Is it worth fiddling with my final drive when I'm down there?
  6. #16
    CF-oholic!
    Join Date
    28th July 2003
    Location
    Blackpool & Swansea
    Posts
    2,800
    Quote Originally Posted by kevHaywire
    It is easy :-)
    I may let you do mine
    http://i76.photobucket.com/albums/j2...nPark038-1.jpg
    My old 24v VR - 234 BHP, 216 lb/ft
    Koni T/As, Eibach Springs, Lupo Wipers, Delocked, Uprated discs and pads, Upgraded Headlight Loom
    My Car
  7. #17
    Join Date
    5th March 2003
    Location
    Essex
    Posts
    26,749
    LOL..... well I'm more than willing to help with any 24V installs.... I need the practice for mine :-)
  8. #18
    CF-oholic! 24V Renshaw's Avatar
    Join Date
    27th August 2003
    Location
    Wilmslow
    Posts
    3,180
    Fitting a 24v.... mmmm i remember that!
    Fitting any modern engine in an older car all depends on how perfectly you want everything to work.
    As I was explaining to Coxy the other day there are advantages to fitting the entire wiring loom that you would never realise
    until you did it. For example, when I open the door of the car, the fuel pump primes! This is standard on a MK4 golf, but this would
    not happen if you just fitted the engine loom, spliced into the Corrado loom. Fair enough its not a major thing, but its there for
    a reason. Its all these little things that add up to mean that every morning, no matter how cold/hot it is the car starts first turn of the key.
    If you are happy with it "just working" then fair enough....
    So the 24v.... its not difficult to fit "physically" by any means. You need to modify the front mount bracket slightly to clear the oil cooler, but basically it fits on the VR mounts
    You can use a VR flywheel and clutch along with an 02A VR gearbox. Easy peasy
    Thats the lump sat in place.
    You will have to mod the front engine mount to lower the front of the block a touch (not on the R32) and remove one of the brace bars under the bonnet if you want the proper cover on and
    to keep some clearance.
    The exhaust downpipe needs to basically be made from scratch, just using the two flanges at the top as a start point.
    I fitted the water system as it is in the MK4, but used a VR6 rad and main waterhousing. You can use all VR stuff, but again with the complete loom in place, I wanted the connectors in the right place
    too.
    If you keep the air-con there is a whole load more stuff (too much to write about now), but one of the main things is cutting a section out of the front crossmember.
    Again I fitted the entire Mk4 brake system which meant mounting all the master cylinder, servo, ABS unit, pipework, sensors etc.. I also mounted the MK4 clutch pedal assembly and clutch Master cylinder.
    The fly by wire throttle has to be mounted inside by welding the bracket to the Corrado pedal box.
    You need run all the looms through. We welded in most of the MK4 firewall so that the original MK4 seal on the loom (great big single piece thing) worked properly and mounted as it would in the MK4.
    I also ran all the loom around for the lights, wipers etc.. all MK4. So no old Corrado loom at all.
    I could go on forever to be honest as I remember stuff I did, but there is so much you forget its unreal.
    The only way to find out is by doing it, obviously anyone doing it will come across the same issues, so ask and I am sure I will remember then!!
    Hope that gives you some idea.
    Jay
    A sense of Deja vu!....
  9. #19
    Enthusiast
    Join Date
    13th June 2005
    Location
    Isle of Man
    Posts
    897
    What have I let myself in for
  10. #20
    Join Date
    5th March 2003
    Location
    Essex
    Posts
    26,749
    Yeah but you're not doing it to that extent ! You just want the lump!
    Agree entirely with the reliability and factory fit and finish aspects....
Similar Threads
  1. Replies: 31
    Last Post: 31st August 2016, 10:12 AM
  2. Where is my old Corrado(s) thread
    By dave0280 in forum General Car Chat
    Last Post: 5th June 2015, 10:32 AM
  3. Definitive 16v tuning thread...
    By hyland770 in forum Engine Bay
    Last Post: 20th November 2010, 11:53 PM
  4. The Definitive 4wd Conversion thread
    By CoxyLaad in forum Drivetrain
    Last Post: 21st September 2009, 1:50 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
