Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 48
Thread: gear linkage adjustment
  1. #11
    Cheer's for that, I'll put this on my to do list.
  2. #12
    Regular
    Join Date
    26th October 2006
    Location
    leicester
    Posts
    166
    Re: gear linkage adjustment
    mines ok, just sometimes it feals abit stiff going into first, like if im sitting at the lights go to put it in first to pull of and ill have to give it more force then i usally do to get it in, but othertimes its not a problem,
    simon
    1992 - Corrad- 1800 16v KR engine,
    lowerd, borbet A's and a few subtle mods...... nothing special but looks clean and does the job
  3. #13
    Well i've been reading and reading...
    Left and right travel is fine, it's putting it into 2nd and 3rd that seems stiff. Is this something that i need to adjust at the gearbox end (from reading the above article) or am I looking at a completely different problem?
    Any thoughts would be appreciated.
    Thanks
  4. #14
    Super Moderator CazzaVR's Avatar
    Join Date
    6th December 2002
    Location
    Wotton-under-Edge, Glos
    Posts
    7,526
    Re:
    Quote Originally Posted by cheesewire
    4) Now....this is the critical part.....you need to make sure the gear stick travel is the same in both directions (left and right) and then retighten the nut.
    In other words, the 'day light' gap between the moving parts should be equal at the limit of the stick's travel - on both sides. It's difficult to explain and I can't take pics (yet) as my car is at Stealth.
    You should see what I mean when you start playing with it.
    Any pics of this , Kev? My 1st, 2nd and reverse are a little sticky occasionally- I'm pretty sure they just need a slight 'tweek' to smooth them out.
    'ave it!
    Corrado Club of Great Britain
    Gone, but not forgotten: Mystic Blue VR6 Storm
    Now: Avus Silver Audi S3 :: 1.8 20v Turbo :: BAM :: Recaro Leathers :: Bose :: Badger 5 v2 TIP :: Forge 007p :: 18" BBS RS2
    Gallery
    "Look Sir, Dubs,"
  5. #15
    Regular
    Join Date
    26th January 2005
    Location
    wilmslow, manchester
    Posts
    221
    My gear box is really vague (although all gears can be found correctly - theres just a lot of play)
    The linkage on top of the gear box is all very rusty and all the joins have a lot of play, is there a kit you can buy to replace the worn washers & bolts etc? or is it a case of trying to get all the little bits seperately? if so any ideas what the part numbers may be?
    1990 full VR6 conversion, Miltek exhaust, cat by-pass and 6-2-1 Manifold. BMC CDA, FK Konigsports, 312mm brakes & braided lines, lupo wipers...... and a BEAST of an overdraft!!!!
  6. #16
    Quote Originally Posted by adamukcorrado
    My gear box is really vague (although all gears can be found correctly - theres just a lot of play) The linkage on top of the gear box is all very rusty and all the joins have a lot of play,
    Hi
    Can you put up a picture of the linkages on top of the gearbox.
    1.8 16v
  7. #17
    Regular
    Join Date
    26th January 2005
    Location
    Posts
    221
    will do tomorrow if it ever stops raining!
  8. #18
    Regular
    Join Date
    30th September 2005
    Location
    liverpool
    Posts
    131
    i have the same problem with lots of play (front & back), i stripped mine down and there is a plastic/rubber bush that fits in the end of the cable that attaches to the gear stick shaft, mine has fell to bits, vw can not replace this on its own but you have to replace the cable £90 which includes the new bushes
    jay
  9. #19
    CF Nutter
    Join Date
    27th December 2002
    Location
    cambridge
    Posts
    1,903
    i might have a used bush if you want to cover posty....i replaced mine with a nylon one
  10. #20
    Regular
    Join Date
    26th January 2005
    Location
    Posts
    221
    Yeah i'll take your spare bush, certainly worth a try, PM me your details and i'll paypal you the money.
Similar Threads
  1. Replies: 4
    Last Post: 7th July 2008, 2:13 PM
  2. gear linkage issue
    By H8RRA in forum Engine Bay
    Last Post: 4th July 2008, 12:22 PM
  3. gear linkage
    By Twiss in forum Suppliers Forum
    Last Post: 20th December 2007, 4:47 PM
  4. gear linkage prob
    By mariovr6 in forum Archive
    Last Post: 25th November 2004, 11:47 AM
  5. Replies: 7
    Last Post: 25th April 2004, 10:01 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
