Page 5 of 5 FirstFirst ... 345
Results 41 to 48 of 48
Thread: gear linkage adjustment
  1. #41
    CF-oholic! VAG-hag's Avatar
    Join Date
    1st June 2005
    Location
    Tarn!
    Posts
    5,721
    Quote Originally Posted by Kevin Bacon View Post
    OK, here's the deal people.... and I'm going to stick it.
    Backward and forward travel
    This is adjusted on the gearbox selector. There are two cables. An upper and a lower. The lower one is fixed and the upper one is adjustable. 13mm spanner.
    Left and right travel
    This is adjusted at the gearstick end under the gaiter.
    The object of the adjustment is to get the left, right, forward and backward planes all equal in travel.
    A common issue is when the lever has more travel to the left, which makes engaging 5th difficult, or has more travel to the right, making 1st and reverse difficult to engage. Make sense?
    9 times out of 10, the backward and forward planes are OK, but to check, just make sure you can select all the gears to start with. If you can, it's the left / right planes that need adjusting.
    So....
    1) Pop the shift into neutral and slacken the aforementioned 13mm nut on the top cable on the gearbox.
    2) Lift up the gaiter and look at the sprung mechanism in front of the OBD port. Flick the stick left to right to see it in action. It has a 13mm nut on it and stiff spring, it's pretty easy to spot tbh.
    3) Hold the stick firmly and slacken the nut.
    4) Now....this is the critical part.....you need to make sure the gear stick travel is the same in both directions (left and right) and then retighten the nut.
    In other words, the 'day light' gap between the moving parts should be equal at the limit of the stick's travel - on both sides. It's difficult to explain and I can't take pics (yet) as my car is at Stealth.
    You should see what I mean when you start playing with it.
    On David's picture above, parts 7, 8, 13 and 17 are the fellas I'm on about.
    5) When you're happy the left and right planes are equal in travel, retighten the 13mm nut on the gearbox.
    Job done. Take out and road test.
    If it's still bad, check the shift lever isn't missing it's hinge circlip.
    Awesome post!!! Thank you kev.
    95 Mystic Blue Storm - It's bound to cause disappointment.
  2. #42
    Enthusiast
    Join Date
    28th March 2003
    Location
    CENTRAL SCOTLAND
    Posts
    598
    Done this yesterday. 1st and reverse were reluctant to work. It took a bit of adjustment inside the car and at the gearbox end, but now all the gears are perfect. Thank you.
    Fraser
    Classic Green Storm Turbocharged
  3. #43
    Newbie
    Join Date
    17th March 2016
    Location
    New hampshire
    Posts
    5
    I will be trying this!
  4. #44
    So....
    great guide, mines an ass to find 1st and reverse so will be trying this tomorrow if it stops raining
  5. #45
    CF-oholic! delfinis38's Avatar
    Join Date
    24th February 2006
    Location
    Muckle Flugga & Fastnet Rock
    Posts
    3,414
    Quote Originally Posted by slider View Post
    Change the oil in the gearbox as well... it may well of been in there 20 years.
    Corrado VR6 - Aqua Blue LC5U - 96 'N' Plate
    Black Leather - Heated Seats - Air Con
    Totally Standard and intend to keep it that way !
    Hibernation for Winter ! SORN
  6. #46
    Quote Originally Posted by delfinis38 View Post
    highly likely, might chuck some moly slip in as well
  7. #47
    another happy customer here
    cheers guys,
    only issue now is it crunches going into 5th if i go too far to the right
    weird this car
  8. #48
    CF Nutter
    Join Date
    15th October 2009
    Location
    wrexham
    Posts
    2,181
    hi been reading this do I still need to undo the bolt on the gearbox to adjust the side to side on gear lever.cheers
    1990 1.8 16v white
Similar Threads
  1. Replies: 4
    Last Post: 7th July 2008, 2:13 PM
  2. gear linkage issue
    By H8RRA in forum Engine Bay
    Last Post: 4th July 2008, 12:22 PM
  3. gear linkage
    By Twiss in forum Suppliers Forum
    Last Post: 20th December 2007, 4:47 PM
  4. gear linkage prob
    By mariovr6 in forum Archive
    Last Post: 25th November 2004, 11:47 AM
  5. Replies: 7
    Last Post: 25th April 2004, 10:01 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
