Page 49 of 49 FirstFirst ... 39474849
Results 481 to 489 of 489
Thread: The Forced Induction 20V Thread
  1. #481
    anyone help me? got the AUQ Lump in mine and gearbox went last night, its currently running the mk3 golf tdi gearbox , is this a good setup or not? whats best gearbox to use and is simple to do that all parts etc can be traced today and fitted today. cheers
  2. #482
    ⋆⋆ CF Donator ⋆⋆ dragon green's Avatar
    Join Date
    21st May 2008
    Location
    Nr.Tonbridge,Kent
    Posts
    3,994
    This should help
    http://the-corrado.net/showthread.php?t=31273
    Personally I have the CTN in mine
  3. #483
    Newbie
    Join Date
    5th September 2007
    Location
    Newton Abbot
    Posts
    40
    Hi all, I have a agu with a k03s on a 1990 so no cat. It running a bit lumpy and a small amount of black smoke was going to change the maf but dont know which to go for? Would the turbo upgrade mean needing a different maf? Thank you for any help
  4. #484
    Hi all thought it best to post in here than start a new thread.I'm looking at putting the BAM engine into my valver. I'm aiming to buy a complete Audi TT as I also want the seats. If I do this do I have to use Qpengs system or could I modify the original loom. And would I need to buy anything else for the conversion? Cheers
  5. #485
    Regular daveb142's Avatar
    Join Date
    3rd July 2012
    Location
    Plymouth
    Posts
    182
    Quote Originally Posted by Corrado-Matt View Post
    Good choice! You can use a standalone sytem such as QPeng. This way means you can retain a cable throttle body and will be much easier to wire in. Also have the gains of a standalone ECU etc. Downsides being bit rough when cold, no fault codes etc, no knock sensors taken into account or what not too and so forth. My mate runs it on his AUM K03s and its at 240bhp and shifts very well, so it is a good bit of kit.
    You can use the standard ECU. If you fancy doing the wiring yourself, "Rubjonny" does a very good guide on how to do it. Otherwise, either pay him to do the loom for you or I actually do similar in my spare time now (I've made various 1.8t looms to go into mk1's, mk2's, mk3's, Corrado's etc). If you go down this route, you will have to modify your pedalbox to accept the mk4 golf accelerator pedal as it is DBW (electronic throttle body). I've done this on mine as i'm running an AUQ DBW 1.8t. It's quite a simple bracket welded onto the pedalbox.
    Benefits of this method - Can still be mapped through the vagcom port, you can see the fault codes etc for the engine and it takes into account all of the engines sensors and what not. Downside, you could say even with mapping it's not as powerful, but a simple map will take you to 280bhp so still bleddy good for standard ECU! There are also many other pro's/cons of both. Worth a google!
    Other than that, a good idea would be to run a G60 flywheel with VR6 clutch, bin off the dual mass flywheel! I'm running a diesel gearbox, however your 16v box could be used still.
    Downpipes can be bought from Q-Peng or trackslag.
    Upgrade your radiator to a bigger one, my 16v one was not up to the job!
    Upgrade your brakes too, minimum G60 brakes really.
    FMIC, Intake pipe etc will also be beneficial.
    Any other help just say
  6. #486
    How do you guys deal with the wheelspin. I cant put power down in 1st or second. Ive jacked rthe suspension so the car leans onto the front wheels. Got wide 16" wheels with good tyres. Soon as the turbo is in spin wet or dry.
  7. #487
    Join Date
    3rd July 2012
    Location
    Plymouth
    Posts
    182
    Quote Originally Posted by zyndol View Post
    I use a Mk3 tdi gearbox. Handles the torque much better. Might spin in first dependant on tracking, won't spin 2nd and pulls well.
    My old 16v box used to spin 1-3rd and try to pull me into a hedge. Tdi boxes are the way forward
  8. #488
    Newbie Orkius's Avatar
    Join Date
    22nd September 2012
    Location
    Bournemouth
    Posts
    52
    Quote Originally Posted by daveb142 View Post
    i'll second the tdi gearbox. as dave says and also much better for motorway cruising, nice long 5th gear
  9. #489
    Hi there looking for a detailed guide to dropping 1.8t in a corrado.. Seen some stuff online suggesting its not one of the harder swaps but would love a guide for dummies like me! Also is there a complete conversion kinda kit that I can buy? Seen these q Peng guys on line but their site seems dead!
    Help me pop my conversion cherry.. Be gentle.
    Thanks my homies
Similar Threads
  1. The Forced Induction VR6 thread
    By Kevin Bacon in forum Engine Bay
    Last Post: 15th December 2017, 5:24 PM
  2. The Forced Induction 16V Thread
    By vwdeviant in forum Engine Bay
    Last Post: 6th July 2013, 8:12 PM
  3. The Forced Induction 8V Thread
    By junkie in forum Engine Bay
    Last Post: 4th July 2010, 9:25 AM
  4. The Thread In My Head Is Cross Threaded...Thread
    By Walesy in forum Engine Bay
    Last Post: 16th July 2005, 8:38 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
