Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Corrado Lambda Sensors - Bosch Part Numbers
  1. #11
    Re: Corrado Lambda Sensors - Bosch Part Numbers
    I just got my bosch universal regular class oxygen sensor 4-wire, 26 in. wire length, planar manufactured with a two-foot length sensor wire it uses a submersible patented connection system that protects against contamination and withstands the effects of extreme temperatures and engine vibration
    Features posi-lock connectors that can be unscrewed and reconnected in case of a wiring mistake; Wire splicing required.
  2. #12
    CF-oholic! fla's Avatar
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,433
    is there a part number for the OBD2 sensor?
    Hasan
    VR6 Auto to manual conversion, beige leather, aircon, TT comps, blue dash lights & switches, Koni TA/Nothelle springs, OBD2, 264 cams, Schrick
    my car
  3. #13
    ⋆⋆ CF Donator ⋆⋆ Portent's Avatar
    Join Date
    16th August 2009
    Location
    Surrey
    Posts
    3,615
    I need a new lambda to replace the missing one on mine. VAG ar quoting £160+. So can anyone confirm if this looks the right one for a May 1994 VR6 OBD1:
    http://www.carparts4less.co.uk/cp4l/...87b084c&000210
    The part number doesn't seem to bear any resemblance to the number earlier in this thread. It is, however, listed as for a 2.9 VR6 up to Nov 1994.
    Storm grey VR6 | BBS RX2 16" | Milltek | D&G cams and map | Black cloth Recaros | Audioscape | Huge grin
  4. #14
    Enthusiast bmwcompact's Avatar
    Join Date
    30th December 2011
    Location
    South Cumbria/Lakes
    Posts
    254
    Ive recently replaced the Lambda sensor on my car 94 2l 16v 9A engine. The correct Bosch part as already given on this thread is 0 258 003 165. Its sold by www.carparts4less.co.uk as their part no 710441475 @ £54.66 with free delivery.
    For those thinking about undertaking the task I should add it was impossible to remove the old sensor in situ. I tried releasing the cat at the front end for better access to no avail. I ended up removing the cat from the car and used heat to try to free the sensor. After cutting the old sensor in half a socket and long ratchet were used to finally free it. Refitting was straightforward with new bolts/nuts at the fore end and a clamp at the rear.
  5. #15
    ⋆⋆ CF Donator ⋆⋆ tonedef's Avatar
    Join Date
    4th October 2006
    Location
    Cuckney
    Posts
    964
    Quote Originally Posted by fla View Post
    Nobody seems to have answered this at the time.
    I just removed the original lambda sensor from my 95 VR6 part number 021 906 265 E and replaced it with 021 906 265 AK . The OBD2 ECU had kept throwing up a lambda fault code before swapping and is now fault free on VagCom.
    It was £138.47 from TPS after 10% discount.
    Last edited by tonedef; 9th February 2014 at 8:19 AM. Reason: Added original VR6 part number
    95 Classic Green VR6: Climatronic & OBD2, Grey Leather Recaro Interior
    CCGB No. 58
  6. #16
    ⋆⋆ CF Member ⋆⋆ loepan's Avatar
    Join Date
    15th September 2013
    Location
    devon
    Posts
    478
    [/QUOTE]although it's usually the ECU loom side that breaks and you need to either use repair wires or get a new plug from VW - £7ish)[/QUOTE]
    whilst replacing my lambda sensor one of the wires in the ecu side has broke out of its connector, does the whole connector need replacing or can i solder on a new spade connector to push in the old one? if i can get the old pin out!
    anyone know? or know what the name of the replacement plug is
Similar Threads
  1. ISV Part Numbers G60
    By Topaz2008 in forum Suppliers Forum
    Last Post: 29th June 2009, 7:52 PM
  2. Part Numbers
    By radness in forum Suppliers Forum
    Last Post: 29th January 2009, 3:54 PM
  3. Part Numbers
    By 2cc in forum Archive
    Last Post: 22nd March 2004, 1:49 PM
  4. Part Numbers
    By nigwell in forum General Car Chat
    Last Post: 29th January 2003, 10:15 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
