Page 2 of 23 FirstFirst 123412 ... LastLast
Results 11 to 20 of 226
Thread: The annoying loose handbrake tunnel cover - a solution!
  1. #11
    ⋆⋆ CF Donator ⋆⋆ daves16v's Avatar
    Join Date
    28th November 2003
    Location
    M1 J25
    Posts
    4,591
    Re: The annoying loose handbrake trim - a solution!
    Quote Originally Posted by paul20v
    i guessed that when i saw your pics , but the title made me think that something had been done with the rubbish lever cover other than pushing it back on every time you let the handbrake off, oh well
    Subject edited.
    Best Car! - CCGB National Day 2013 Castle Combe
    1994 VR6 - 2.5" Bastuck Exhaust - BBS RC's - 288 Front Brakes - Mk4 Rears - Bilstein B12 - Smoothed Rear - Moonroof - OBD2 -
    Braided Hoses - Aero Wipers - Short Shift - Black Heated Leather - SWG Scuttle Cover - OEM volt/oil gauges - 263 Cams - Carbonio Inlet -
    Golf Mk4 Handbrake
  2. #12
    CF Nutter
    Join Date
    25th April 2007
    Location
    Croydon
    Posts
    1,391
    Re: The annoying loose handbrake tunnel cover - a solution!
    Brilliant! Would definately want a set
  3. #13
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    12th May 2006
    Location
    Derby
    Posts
    1,237
    I dont even have the central tunnel or handbrake cover on mine at the minute. Took it off for some handbrake cable adjustment about 2 months ago and havent put it back on yet
    BROKEN FOR PARTS - Corrado, 1990 1.8 16v, tornado red
    RECENTLY SOLD - 1996 Audi A4 TDI Wagon
    NEW TOY - 04 plate Black Civic Type R
  4. #14
    Enthusiast
    Join Date
    4th July 2006
    Location
    Chiswick & Warsaw
    Posts
    282
    I'll take one please
  5. #15
    Join Date
    28th November 2003
    Location
    M1 J25
    Posts
    4,591
    Right, I've now made the bracket from Stainless and modified it slightly. The finished item fits very well and more importantly holds firm - see photo, I'm very happy with it.
    For those wanting one I can do it for £12.50 posted which includes all Stainless screws nuts and washers. You will need to provide your own 6mm drill bit for the plastic and M4 Tap for the floor fixing. As most people will already have a drill bit close to the correct size, I may be able to supply the Tap but it will up the cost slightly.
    Comments welcome.
    Golf Mk4 Handbrake
  6. #16
    ⋆⋆ CF Donator ⋆⋆ boost monkey's Avatar
    Join Date
    27th July 2007
    Location
    Oxford
    Posts
    5,627
    Are you sure there is enough flex in this piece of metal to justify the move from aluminium to steel? I'm in the middle of my materials engineering revision, and I really can't see the necessity of an upgrade to steel, it's hardly a load bearing part.
    Was the aluminium particularly low grade or something?
    1990 Dark Burgundy Pearl Corrado 16v - Project Plum
    1989 Black Mark 2 Golf GTi 8v - Willow
  7. #17
    ⋆⋆ CF Member ⋆⋆ easypops's Avatar
    Join Date
    13th July 2006
    Location
    Glasgow
    Posts
    3,136
    I'll have one at £12.50 no worries.....could you explain about the "tap" situation for me as i'm not sure what it is
    and if need be i'll have that also
    Thanks for the effort
    95 Classic Green Storm
    95 Flash Red VR6
    For those who understand, no explanation is needed.
    For those who do not understand, no explanation is possible
  8. #18
    Join Date
    27th July 2007
    Location
    Oxford
    Posts
    5,627
    a tap is a small device which is used to turn the flat edges of a hole into threaded edges so you can screw a bolt into it and it will hold.
  9. #19
    Join Date
    13th July 2006
    Location
    Glasgow
    Posts
    3,136
    Quote Originally Posted by boost monkey
    Ah i see, can i not just buy self tapping screws/bolts for that bit then?
    95 Flash Red VR6
  10. #20
    Join Date
    27th July 2007
    Location
    Oxford
    Posts
    5,627
    quite possibly, my man.
Similar Threads
  1. Beige Foot rest + handbrake cover
    By emu in forum Wanted
    Last Post: 19th February 2011, 10:24 PM
  2. funny noises and loose cat cover
    By TimDoc in forum Engine Bay
    Last Post: 21st April 2010, 9:58 AM
  3. Replies: 8
    Last Post: 11th November 2008, 10:08 PM
  4. handbrake handle cover wont come apart.
    By Talc in forum Interior
    Last Post: 6th September 2006, 4:40 PM
  5. Hnadbrake tunnel plastic cover
    By capnahab in forum Interior
    Last Post: 12th August 2006, 9:46 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
