Page 9 of 9 FirstFirst ... 789
Results 81 to 84 of 84
Thread: Definitive G60 Timing Belt Setting
  1. #81
    ⋆⋆ CF Member ⋆⋆ STU175's Avatar
    Join Date
    31st January 2008
    Location
    Ipswich, Suffolk
    Posts
    589
    great guide but i hope someone can settle a disagreement with my mate!
    if i change the cambelt and do no other work do i have to adjust the timing? if so why?
    my mate who works in an HGV maindealer and his "experts" he works with say
    "i dont and dont need to bother with all the unplugging coolant sensor revving 3 times to reset ecu sequence rubbish just change the belt it will be fine"
    i have shown him all the guides but would be good to be able to give him the technical reason why this is needed
    G60-1991-Alpine White-JMR Stage 4 charger-JMR Big Valve Head-Schrick 268/276 Cam-forged 83mm pistons-forged conrods-lightened and balanced bottom end-Wagner I.C-Oil cooler-Smoothed bay
    link to build thread http://the-corrado.net/showthread.ph...TE-G60-UPDATED
  2. #82
    Super Moderator Yandards's Avatar
    Join Date
    17th March 2004
    Location
    Carterton, United Kingdom
    Posts
    4,821
    Blog Entries
    8
    Stuart,
    If you can manage to get the timing marks to align perfectly then you could leave the timing alone.
    The reason I suggest that you need to do the timing is that aligning the timing marks is difficult thanks the inner wing getting in the way of your eyeline, if you get the intermediate shaft in roughly the correct place then by setting up the timing you can compensate for the fact that the timing mark on the intermediate shaft might not be in exactly the correct location.
    As for the HGV crowd, the G60 engine management is very very sensitive to correct timing to produce good power, the reason the blue temperature sensor needs to be unplugged is that you then place the engine into a 'basic' setting mode. As the timing is dynamically set (2000-2500 rpm) this mode prevents the ECU from advancing and retarding the timing during the setup process. The 3 revs information may or may not be relevant (I think it is removed from later ECU code) but it is mentioned on the VW G60 workshop video as part of the process so I have included it the guide.
    Finally the VW workshop manual instructs you to check (and adjust if required) the timing with a timing light using the process I have previously described after replacing the cambelt; on older distributor equiped engines this is good practice as you never know if the timing was correct before you started.
    Cheers fool,
    Yan
    1990 G60-16v Blue Pearl Effect
    Now sold, 1991 Nugget G60
    CCGB Technical Secretary
  3. #83
    Join Date
    31st January 2008
    Location
    Ipswich, Suffolk
    Posts
    589
    cheers for the reply yan
  4. #84
    Newbie
    Join Date
    19th September 2014
    Location
    Edinburgh
    Posts
    7
Similar Threads
  1. Supercharger Belt Timing & rebuild.
    By tonysangha in forum Engine Bay
    Last Post: 28th January 2009, 6:47 PM
  2. Setting up a sub....
    By JMC in forum ICE 'n' Secure
    Last Post: 23rd March 2007, 2:38 PM
  3. VW Polo G40 Timing Belt Change
    By kongo127 in forum General Car Chat
    Last Post: 17th August 2006, 9:24 PM
  4. Corrado Timing Belt Tensioner VAG Tool
    By Frostee in forum Engine Bay
    Last Post: 12th October 2005, 6:33 PM
  5. Timing Belt and tensioner - G60
    By biggrim in forum Engine Bay
    Last Post: 5th March 2005, 12:00 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
