Page 2 of 33 FirstFirst 123412 ... LastLast
Results 11 to 20 of 326
Thread: The definitive VR6 cooling guide
  1. #11
    CF-oholic!
    Join Date
    27th February 2004
    Location
    Toronto
    Posts
    9,148
    Re: FAN TEMP
    Quote Originally Posted by Critical_Mass
    My previous 2ltr 8v rado did that, as did my G60. My 93 Vr has never had the fans come on after engine has been switched off, even after giving it some beans before hand. Potential problem, or how it should be?
    How hot was the water? Is the aux water pump shagged? (quite a few are and they're not cheap to replace). If it's not getting stupidly hot, then I wouldn't lose sleep over it.
    Quote Originally Posted by 3corsameal
    i mixed my coolant up nearly 50/50, more like 60/40 is that right?
    No, you'll die in a firey death immediately.
    Course it is. It might not cool quite as well, but nowt major. It just cost you more to fill up. The G12+ is anti-freeze/anti-corrosion solution and hasn't got quite as good thermal absorption qualities as water, but there's not much in it.
    Pedestrianised.
    '95 Satin Silver VR .: Koni :: H&R ::TT brakes :: Compomotive :: Magnex :: Recaro :: Audioscape :: DDI :.
    '93 Satin Silver VR .: Koni :: H&R :.
    '94 Aqua Blue VR .: RI(many)P :.
  2. #12
    CF-oholic!
    Join Date
    16th July 2005
    Location
    Leeds
    Posts
    7,421
    Re: FAN TEMP
    Quote Originally Posted by dinkus
    The water temp was no higher then it should be running, no more then 110. The water pump was replaced in January, whilst the engine was out. The temperature is fine even when im pushing it. So as you've said, its not worth losing sleep over Just wasnt sure if it should come on after the engine was switched off. I guess ill see if the days stay hot.
    Gaz
    '93 VR6 Bordeaux pearl- Recon VR engine -16/01/08; KW V1s; BMC CDA; Milltek Sports CAT; Supersprint exhaust; 16" Cades Eros; smoked rears & side reps - SOLD 14/07/2013 Gone but not forgotten.
    "We can't stop here this is bat country"
  3. #13
    ⋆⋆ CF Donator ⋆⋆ mattnorgrove's Avatar
    Join Date
    18th July 2006
    Location
    Cannock, Staffs
    Posts
    1,312
    Re: The definitive VR6 cooling guide
    Quality thread Dinkle!
    Have you wired the 3rd fan stage to a switch on the dash then?
    I'd be interested in doing just that, cos if there's one thing I'm paranoid about, it's high coolant temps!
    Cheers!!1!
    1995 Aqua Blue Pearl VR6
  4. #14
    Super Moderator Kevin Bacon's Avatar
    Join Date
    5th March 2003
    Location
    Essex
    Posts
    26,749
    Having had my Laptop as a passenger for the past 18 months, I've observed the following in respect of VR Water temps :-
    "Middle of the guage" on the VR is actually 98 degrees and Stage 1 fan will be running. It kicks in as Dinks advised, at 95 deg C.
    The water temp gauge under reads by around 10 deg below "middle", which highlights car manufacturers always bias temp gauges to sit in the middle because middle is "normal" to most people
    Above 45mph, normal summer cruise water temp is 80 - 84 deg C
    Above 40mph, normal Winter cruise temp is 75 - 82 deg C.
    I also discovered you only need one, yes ONE, 11" SPAL fan to keep the water at 95 deg constantly in traffic, even when it's 27 deg C outside, like it was last night when I was stuck on the A12 for an hour waiting for an accident to clear.
    The whole 3 speed thing for the uK is a nonsense. Completely over the top!!
    Not sure if Dinks mentioned it, but you can bridge the red/black speed 2 wire and also the black Speed 3 wires with a 2 way switch and manually start them in the car :wink:
    Oh and it's the pump that remains active for around 10 mins on shut down, not the fans. Speeds 1 and 2 will only start if necessary, i.e. between 95 and 105 degs.
    Did have: 94 Corrado R32
    Now have: 2004 Golf R32
  5. #15
    CF-oholic!
    Join Date
    27th February 2004
    Location
    Toronto
    Posts
    9,148
    Thanks for the info Mr. Cheesewire.
    That info about the after-run does make a bit more sense. I couldn't work out how it was going to work otherwise.
    I'll update the main thread now...
    Pedestrianised.
  6. #16
    Regular
    Join Date
    25th January 2005
    Location
    near an A-Road
    Posts
    238
    Regarding cooling, i've been running my vr6 for a couple of months now, with a swtich on the speed 3 fan, total control in theses hot conditions, and would recommended it also.
  7. #17
    Join Date
    5th March 2003
    Location
    Essex
    Posts
    26,749
    The idea behind the after-run pump is too circulate the water round the heater matrix and rear of the block to prevent localised over heating.
    That runs regardless, come rain, shine, snow, ice and even if the engine hasn't even run (ignition on, then off).
    Speed 1 has direct battery power and will run if it's triggered.
    Speed 2 has power maintained to it only during the 10 min after run cycle and will also run only if tiggered.
    Speed 3 is ignition only.
    So if you pull up after a journey and the fans don't run, that is a good thing, not a bad thing :wink:
  8. #18
    CF-oholic! herisites's Avatar
    Join Date
    6th June 2006
    Location
    Rushden, United Kingdom
    Posts
    3,478
    Im going to be putting a switch between the speed 3 fan on mine ready for mu euro trip. Can see it being rather helpful when its most likely going to be over 30 degrees
    Also will get a SPAL when i have some spare cash, which probs wont be for a while
    Blackberry R32 278bhp - Gone but not forgotten
  9. #19
    CF-oholic!
    Join Date
    27th February 2004
    Location
    Toronto
    Posts
    9,148
    Just for anal-retentiveness and/or completeness...
    Do you know which 11" fan you have on your VR? There seem to be three differen 11" (280mm) Spal fans available..
    Code:
    SPAL Ref:                SPAL Code:         Dia.        Depth          Air Flow           Current       Airflow
    VA09-AP8/C-54A           3010.0318         280 mm       52 mm         1500 m3/hr         6.9 Amps       Suction
    VA03-AP70/LL-37A         3010.2054         280 mm       94 mm         2350 m3/hr         12.5 Amps      Suction
    VA04-AP70/LL-37A         3010.2076         280 mm       94 mm         2350 m3/hr         12.5 Amps      Suction
    Pedestrianised.
  10. #20
    Join Date
    5th March 2003
    Location
    Essex
    Posts
    26,749
    God knows! Defo a suction one and probably the middle one
Similar Threads
  1. The definitive 312mm brakes onto a VR thread
    By dinkus in forum Drivetrain
    Last Post: 19th April 2012, 10:58 AM
  2. Replies: 1
    Last Post: 8th July 2010, 5:29 PM
  3. The definitive guide to ABS
    By jpowell79 in forum Interior
    Last Post: 21st April 2010, 9:20 AM
  4. Replies: 2
    Last Post: 22nd February 2009, 9:47 PM
  5. definitive running tips required on a vr6, PLEASE....
    By jamest in forum Suppliers Forum
    Last Post: 3rd November 2003, 10:51 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
