Page 3 of 33 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 326
Thread: The definitive VR6 cooling guide
  1. #21
    CF-oholic!
    Join Date
    27th February 2004
    Location
    Toronto
    Posts
    9,148
    Re: The definitive VR6 cooling guide
    Oh yeah, nothing like a nice bit of suction
    I've no idea what the difference is between the bottom two, other than the part number
    Either way, they're all around the £70 mark, which is considerably cheaper (not to mention quieter and lighter) than buying the standard fan setup from VAG for a couple of hundred quid!
    Pedestrianised.
    '95 Satin Silver VR .: Koni :: H&R ::TT brakes :: Compomotive :: Magnex :: Recaro :: Audioscape :: DDI :.
    '93 Satin Silver VR .: Koni :: H&R :.
    '94 Aqua Blue VR .: RI(many)P :.
  2. #22
    Super Moderator Kevin Bacon's Avatar
    Join Date
    5th March 2003
    Location
    Essex
    Posts
    26,749
    The difference is blade type I believe, i.e. curved blades for quiet running, or straight blades for noisy all out sucking action
    I have the curvy blades
    Did have: 94 Corrado R32
    Now have: 2004 Golf R32
  3. #23
    CF-oholic!
    Join Date
    27th February 2004
    Location
    Toronto
    Posts
    9,148
    Quote Originally Posted by cheesewire
    The idea behind the after-run pump is too circulate the water round the heater matrix and rear of the block to prevent localised over heating.
    That runs regardless, come rain, shine, snow, ice and even if the engine hasn't even run (ignition on, then off).
    Speed 1 has direct battery power and will run if it's triggered.
    Speed 2 has power maintained to it only during the 10 min after run cycle and will also run only if tiggered.
    Speed 3 is ignition only.
    So if you pull up after a journey and the fans don't run, that is a good thing, not a bad thing :wink:
    Good stuff, amended the original post with this
    I much prefer my suction friend to have some curves too
    Pedestrianised.
  4. #24
    CF-oholic!
    Join Date
    16th July 2005
    Location
    Leeds
    Posts
    7,421
    Glad to hear that. Thanks Mr Cheesewire
    Gaz
    '93 VR6 Bordeaux pearl- Recon VR engine -16/01/08; KW V1s; BMC CDA; Milltek Sports CAT; Supersprint exhaust; 16" Cades Eros; smoked rears & side reps - SOLD 14/07/2013 Gone but not forgotten.
    "We can't stop here this is bat country"
  5. #25
    CF Nutter
    Join Date
    10th October 2004
    Location
    Tunbridge Wells, Kent
    Posts
    1,887
    You should sticky this thread of all VR-based temperatureness
    Very useful indeed
    VR sold - new wheels: E39 BMW 530i Sport
    Still miss both my 'Rados
    http://www.johnmitchellracing.co.uk/
  6. #26
    Enthusiast ziderapple's Avatar
    Join Date
    28th June 2006
    Location
    Dubai
    Posts
    648
    Great thread, been thinking for ages someone with the knowledge should do a decent write up on the subject. So thank you.
    Also would it be worth copy and pasting the first post into a wiki guide?
    Chris
    24v 'rado - Sold
  7. #27
    CF-oholic!
    Join Date
    27th February 2004
    Location
    Toronto
    Posts
    9,148
    Just added the pumps section
    Quote Originally Posted by ziderapple
    And yup, if the wiki would let us edit it at the moment (it's on the to-do list)
    Pedestrianised.
  8. #28
    Join Date
    5th March 2003
    Location
    Essex
    Posts
    26,749
    Quote Originally Posted by Critical_Mass
    Forgot to say...... it's a good thing providing the dash gauge isn't reading 100+
    If temperature is normal i.e. ~ 90 degs when you stop, there's a good chance the 95 deg Stage 1 won't be triggered. It may kick in randomly as the after run pump circulates the hotter water out of the matrix and block/head into the radiator. All normal stuff.
    If the fans do nothing when the gauge reads 100 (middle), the rad switch is probably knack'd.
    If the fans do nothing past 105, the rad switch *or* fan controller is borked.
    If the fans do nothing past 110, run!!
    Nah, stage 3 switch is borked or missing in action, presumed dead....or the controller.
    I've had to replace the controller and it's an eye watering experience, £110+VAT IIRC!
  9. #29
    Join Date
    28th June 2006
    Location
    Dubai
    Posts
    648
    Is this being added to the knowledge bank?
    Chris
    24v 'rado - Sold
  10. #30
    Enthusiast
    Join Date
    10th March 2004
    Location
    Surrey darling!
    Posts
    869
    Can we have a 'cooling trouble shooters guide for dummies' please as this makes absolutely no sense to me....
    I've just bought an M red VR6 on 69k and the water temp reading is going up to 110, whereas the oil temp on the maf says 108 at most. The coolant is the colour of rust and the oil is black as the car has sat in a garage for 3 years - will be serviced on Saturday!
    The fans only turn on after I turn the ignition off and even at 110 degrees do not kick in until the engine is turned off?
    Any thoughts before I go and buy a 5 speed setting fan with AC????
    Biggerbigben thinks I need a new fan switch but after calling up VW they say there are several - so I said I'd find out on the C forum!
    Cheers
    Neil
    Current :: Porsche 911 (997) Carrera S
    Website :: http://www.fastgerman.com
    http://www.fastgerman.com/fg.jpg
Similar Threads
  1. The definitive 312mm brakes onto a VR thread
    By dinkus in forum Drivetrain
    Last Post: 19th April 2012, 10:58 AM
  2. Replies: 1
    Last Post: 8th July 2010, 5:29 PM
  3. The definitive guide to ABS
    By jpowell79 in forum Interior
    Last Post: 21st April 2010, 9:20 AM
  4. Replies: 2
    Last Post: 22nd February 2009, 9:47 PM
  5. definitive running tips required on a vr6, PLEASE....
    By jamest in forum Suppliers Forum
    Last Post: 3rd November 2003, 10:51 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
