Page 35 of 36 FirstFirst ... 2533343536 LastLast
Results 341 to 350 of 359
Thread: The definitive VR6 cooling guide
  1. #341
    ⋆⋆ CF Donator ⋆⋆ 1xshaunx1's Avatar
    Join Date
    14th December 2010
    Location
    near sheffield
    Posts
    463
    Have you fixed yours then Tony, if so what was it
    4th one surely the last
  2. #342
    ⋆⋆ CF Donator ⋆⋆ Keyo's Avatar
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    1,130
    Quote Originally Posted by fendervg View Post
    Thanks Tony - I'll take a look later and check to see if I can find any more on it - it's kind of covered by the bracket that holds it, so will need to drop it.
    EDIT: on second thoughts, I have the early controller with just the single large fuse, so will need to keep looking. Are the late type ones interchangeable with the early ones by any chance?
    Im sure I read somewhere that early models had a 2 stage fan and late 3 stage , could of imagined it though. Would this be the reason they changed over fan controller, I have no idea to be honest but keep us updated on your progress .
    Cheers.
  3. #343
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    1,130
    How many sensors do you have in your thermostat Fen ?
  4. #344
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    2,110
    Quote Originally Posted by Keyo View Post
    There's 3 sensors, yellow, blue and black/brown. I think stage 3 is one of these sensors. It's definitely 3 stage as I've heard it come on in after-run and also when the rad sensor was faulty, and it's so loud you couldn't miss it.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  5. #345
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    1,130
    Yep 3 stage for sure , I can't see why the newer version of the fan controller would not work if it is three stage. there is also another fan controller unit that is cheaper then the late VR fan control unit that has an A on the end with the same part number before that, is a lot more common and therefore cheaper, maybe this will also work.
    From a Golf Mk3 357 919 506 A
    https://www.ebay.co.uk/itm/Vw-Golf-M...AAAOSw5SNdRHYS
  6. #346
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    1,130
    It does appear that you can use a MK3 golf one as the part numbers are cross referenced on this aftermarket fan control unit.
    https://www.ebay.co.uk/itm/New-VEM-R...cAAOSw6UlcpjuI
    Manufacturer Part Number 1: FORD : 7203654, FORD : 95VW14B205AA, SEAT : 357919506, SEAT : 357919506A, SEAT : 3A0919506, VAG : 357919506, VAG : 357919506A, VAG : 3A0919506, VW : 357919506, VW : 357919506A, VW : 3A0919506
    Has your part number on your existing fan got one of the above numbers?
  7. #347
    Super Moderator Kevin Bacon's Avatar
    Join Date
    5th March 2003
    Location
    Essex
    Posts
    26,780
    Yeah, from memory.....
    2 pin blue = engine ECU coolant sensor
    4 pin yellow = Stage 2 fans and dash gauge - 105 ish degrees
    2 pin black = Stage 3 fans - 115 ish degrees
    3 pin thermo switch in radiator = Stage 1 fan and after run pump signal to fan controller - 95 degrees
    I believe the Fan controller takes a signal from the yellow and black sensors, and stage 1 runs autonomously.
    It's one hell of a system just to run some fans
    Maybe MK5 GTI fans would be a good upgrade. The controller is built into the fan motor and just takes one signal from the coolant sensor. Much simpler!
    Did have: 94 Corrado R32
    Now have: 2004 Golf R32
  8. #348
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    11th July 2009
    Location
    Leeds
    Posts
    959
    Quote Originally Posted by 1xshaunx1 View Post
    It's half fixed - the run on issue sorted itself out which just left the fans coming on with the ignition. Pulling fuse 6 stopped it happening - I thought there was a crossed circuit somewhere as most fusebox guides say that fuse is just for the fresh air blower, but nope, buried in the late vr wiring diagrams, the circuit splits to send an ignition live signal to the fan controller. I found the connector behind the fusebox, disconnected the fan controller feed and the fans went off... I'd already changed the fan controller, so now the issue had to be in the signal circuits for the temp senders.
    So I went back to disconnecting the senders, yellow and rad sender no difference, but the issue stopped when I disconnected the black sender - it must have been stage 3 that was coming on, not stage 2.
    That's as far as I've got, I'm running without the black sender plugged in at the moment, next step is to order a new sender, plug it into the connector and see what happens. Or I have a brown sender in the garage (and new 4 pin connector) as I was planning to run aircon at some point.
    Other electrical gremlins are okay for now - rear light turned out to be that I'd dropped a small nut into the rear light bulb holder when reassembling the car after welding and painting - that was shorting the circuit and blowing the fuse. Horn is working for now, not sure what was wrong here, though the temp sender wiring and horn follow a similar route down the chassis leg.
    Sorry for all the detail, hope it helps though if someone is trying to diagnose a similar problem.
  9. #349
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    2,110
    Quote Originally Posted by tony_ack View Post
    Fuse 13 (horn) also covers the aux water pump and radiator run on.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  10. #350
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    1,130
    Good luck with this Ant sounds like your well on your way to solving the issues.
Similar Threads
  1. The definitive 312mm brakes onto a VR thread
    By dinkus in forum Drivetrain
    Last Post: 19th April 2012, 10:58 AM
  2. Replies: 1
    Last Post: 8th July 2010, 5:29 PM
  3. The definitive guide to ABS
    By jpowell79 in forum Interior
    Last Post: 21st April 2010, 9:20 AM
  4. Replies: 2
    Last Post: 22nd February 2009, 9:47 PM
  5. definitive running tips required on a vr6, PLEASE....
    By jamest in forum Suppliers Forum
    Last Post: 3rd November 2003, 10:51 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
