Page 10 of 10 FirstFirst ... 8910
Results 91 to 97 of 97
Thread: ABS light arghhhhh!!
  1. #91
    Enthusiast
    Join Date
    8th February 2007
    Location
    n. ireland
    Posts
    606
    Quote Originally Posted by Rob W View Post
    Yeah, i had that in mind, but I'm hoping to cover all the easy bases before i start to take the ABS pump of to repair/overhaul.
    Just by chance, do you know of anyone who does the ABS pump overhaul?
    You may remember that Wheeler Dealers did a Corrado a while back and they had the ABS pump repaired. Check out the link below and you'll find the name of the company they used about half way down the page.
    http://the-corrado.net/showthread.ph...Dealers/page14
  2. #92
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,734
    You have the same size tyres front and back?
    Have you scanned it?
  3. #93
    Newbie
    Join Date
    15th January 2017
    Location
    Salisbury
    Posts
    26
    all tyres are the same all round. What do you mean 'Scanned it', are you talking about plugging the diagnostics into it? if yes, then i have plugged it in but i think i bought a crappy one from china, it won't let me erase all faults to conduct a full check. I'm getting a friend to lend me theres hopefully next week to see if i can get any other feedback.
    Quote Originally Posted by Dox View Post
  4. #94
    Newbie
    Join Date
    15th January 2017
    Location
    Salisbury
    Posts
    26
    Quote Originally Posted by leon263 View Post
    just been in touch with the company, 160 for them to collect, repair and deliver. seems a bargain. hopefully gonna get it plugged in to a decent OBD1 next week and check the faults over first.
  5. #95
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,734
    Some say they can't scan C ABS, but mine scans with VCDS.
    Whereabouts are you?
    I presume you have the reluctor rings fitted to the rear discs? Your car seems to be seeing a speed differential front to rear?
    Happy to scan anyone if they're close to Cheshire
  6. #96
    Newbie
    Join Date
    15th January 2017
    Location
    Salisbury
    Posts
    26
    im in Wiltshire. thanks anyway.
    i renewed discs all round and new rings when i changed the rear hubs.
  7. #97
    Newbie
    Join Date
    15th January 2017
    Location
    Salisbury
    Posts
    26
    Well, i think I'm getting somewhere.
    just been able to get back to working on the Rado as i've been away with work for a while. i sent the ABS Pump off to the company used on 'wheeler Dealers', unfortunately/fortunately, they informed me that the pump was all ok. Now i have it all fitted, and bleed the system and i still had feed back coming through the brake pedal whilst driving and the light came back on. it was then i realised that there is a bleed valve on the M/C. well, i didn't know that. so much air came out of it there was a sense of relief. Finally, the feed back form the pedal has now gone. the light still remains. i looked at the ECU this afternoon and noticed that the pins were badly corroded. this was due to the heater matrix fault when i acquired the Rado. all cleaned up and and all back together. from there i checked all the sensors resistance from the ECU harness back and found the F/L sensor is only reading 780 ohms, not the 1-1.3k ohms required. F/L sensor is now on route and i am hopeful that this all the issues dealt with for the ABS.
    Fingers crossed, i'll have my Rado in for its MOT within the next few weeks. i hope!!!
Similar Threads
  1. Side light and rear light
    By burn-rubber-not-soul in forum Exterior
    Last Post: 10th October 2010, 11:22 AM
  2. PAS too light!?
    By g60kpj in forum Drivetrain
    Last Post: 24th September 2007, 2:58 PM
  3. light problems. only one light works on dip -main both on hi
    By praise b the LOweReD in forum Engine Bay
    Last Post: 30th May 2007, 8:59 AM
  4. Oil light (the little oil can..)
    By Lanceevox in forum Interior
    Last Post: 28th March 2006, 12:03 AM
  5. ABS light came on.... no !!!!!
    By chris CORRADO in forum Archive
    Last Post: 21st April 2004, 10:52 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
