Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 85
Thread: Mk4 Golf Rear Calipers Upgrade. Re: Parts
  1. #11
    ⋆⋆ CF Member ⋆⋆ Jim Bowen's Avatar
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,960
    Re: Mk4 Golf Rear Calipers Upgrade. Re: Parts
    Quote Originally Posted by Toad
    Have you hit it with a hammer and punch yet?
    no
    but i've learnt that the metal part of a light bulb stays hotter for longer than the glass bit
    Just like a golf................But better!!!
  2. #12
    Newbie
    Join Date
    5th June 2006
    Location
    High Wycombe/Cippenham
    Posts
    83
    I got fed up of waiting for the rear calipers to show up on eBay so I sourced my rear mk4 calipers from volkswagenspares for £75. They were in good condition and it didn't take much to clean them up and paint them red as they are made out of aluminum.
    The front ones were a different matter. I got them for £60 off eBay in quite good condition but being made out of steel, even the small amount of rust that it had, it took bloody ages to grind off.
    http://www.car-partsonline.com/Brake_Calipers_34.asp
    Steve
    1994 Corrado 2.0 8v Ice Grey Violet
    1995 Corrado 2.9 VR6 Mystic Blue Storm
    17" BBS RX2 : 288mm + Goodridges : Koni TA/H&R : Lupo GTI Wipers : Magnex : Lightened Pulleys : SP 263 cams : Mocal : Stealth Remap
    CCGB Member 990
  3. #13
    CF Nutter
    Join Date
    19th February 2003
    Location
    Aberdeen, Scotland
    Posts
    1,810
    3corsameal,
    what model of MK4 Golf do those part nunbers that you posted up correspond to ? Can you use MK4 calipers from ANY MK4 Golf ? Just want to try and get them a bit cheaper than from VW or BigRed and have seen some for £55+VAT each but they have no part numbers just model type,
    Cheers
    2XX ? BHP Corrado G60 in Subaru Sonic Blue Metallic, build underway........so many wheels, so little time........
  4. #14
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,960
    i'm not sure, i just got the part numbers given to me on here by supercharged (i think)
    when i went to VW originally the chap told me there was several different ones, i guess the later the letter in the number the later the model of car, maybe they kept revising the brakes?
    as i found ones starting with 1D0, 1H0, 1J0 etc
    ordered a nice brake line flaring tool, a skyes pickavant one, better be good as that was another £100
  5. #15
    CF Nutter
    Join Date
    19th February 2003
    Location
    Aberdeen, Scotland
    Posts
    1,810
    Just ordered a pair of alloy MK4 calipers for £103 delivered which was good price, and will paint them red myself. And seeing as I saved money here, ordered a pair or new caliper carriers and slider pins from VW for £127.04 delivered. So brake spec now will be as follows:
    Brembo 4-pot front calipers with alloy carriers
    305x28mm front brembo slotted discs
    Brembo pads
    MK4 alloy rear calipers
    New VW G60 rear caliper carriers
    Brembo rear discs
    AP Racing rear pads
    Also have new bearings front and rear and new handbrakes cables to fit as well, should be a massive improvement !
    Cheerds
  6. #16
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,960
    sounds awesome setup, i take it you haven't got standard wheels to fit those front brakes?
    are you also planning to do anything with the "hard" brake lines? my tool arrived today for making flared ends, just waiting for all the pipe and stuff to turn up so i can practise
  7. #17
    CF Nutter
    Join Date
    19th February 2003
    Location
    Aberdeen, Scotland
    Posts
    1,810
    Dunno about doing anything with the hard brake lines, will just be getting garage to fit everything tbh at same time. Wheels are ETA Porsche "Turbo" twist 3-piece split rims in 8x17" size all round, plenty of clearance I think (have seen Brfembo's fitted to cars that have these wheels).
  8. #18
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,960
    i've found the hard lines to be a bit of a state after 13yrs, so having to replace those as well now.
    bit of a pain but seems a worth while thing to do
  9. #19
    CF-oholic! Goldie's Avatar
    Join Date
    14th January 2006
    Location
    Durham / Glasgow
    Posts
    4,457
    Definitely a worthwhile conversion going down the MK4 route. My handbrake was just for decoration until i sorted the rear beam and all the brakes to Mk4 items..
    94 Satin Silver VR6, 18 Tungsten Silver Golf GTI
    Previously: 95 Aqua Blue 16v, 95 Classic Green Storm, 96 Moonlight Blue 8v
    And a number of breakers..
    CCGB 2647
  10. #20
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,960
    Just some more bits ill add to this thread, seeing as they arrived now.
    Brake pipe flaring tool, required if you want to replace your brake lines, Worth while getting a semi decent one if your not experienced, the cheaper ones are a bit naff from what i've read.
    This was about £100 off ebay and comes with the other tools, like cutter, bender, and derburring tool
    Brake pipe and unions, the pipe is 3/16" or 4.76mm, the unions are 10mm and i ordered some 12mm and some spare bleed nipples (not sure why i got the nipples as the brakes all have new ones anyway, does the master cylinder have some?)
    ordered from:
    http://www.brake-pipe.co.uk/
Similar Threads
  1. Mk4 Rear Calipers
    By hombre_paulo in forum Wanted
    Last Post: 1st February 2011, 1:08 PM
  2. Rear Calipers
    By V-Dubstar in forum Drivetrain
    Last Post: 1st June 2009, 10:18 PM
  3. MK4 Golf Rear Calipers + Pad question
    By Supercharged Junkie in forum Drivetrain
    Last Post: 22nd July 2008, 11:32 AM
  4. G60 Rear Calipers
    By Slimg60 in forum Drivetrain
    Last Post: 11th January 2007, 11:41 PM
  5. MK4 Golf Front Calipers
    By andy in forum Drivetrain
    Last Post: 23rd April 2005, 8:21 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
