Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 64
Thread: 288 Front Brakes and MkIV Rears -Part Number Thread
  1. #11
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,726
    Re: 288 Front Brakes and MkIV Rears -Part Number Thread
    Cheers for the info, lads. I have updated the original post with part numbers.
    We still need some more for:
    ABS rotors
    Rear Pads
    Rear discs
    Rear bearings
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  2. #12
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,726
    No more info ? Come on lads, get out your receipts and start posting ! Surely we have some more info out there. Just want to make the conversion easier off the shelf for myself and others.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  3. #13
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,726
    I've just asked my mechanic here in Ireland to check prices and availability for the following from VAG - at present dealers here are doing a 25% discount over normal trade prices on brake service parts, so it will be interesting to see if this applies to older cars as well:
    Front:
    1 x 3A0615123 calliper with 54mm pistons lh
    1 x 3A0615124 calliper with 54mm pistons rh
    2 x 4A0615125A calliper carriers, 288 mmm
    4 x 4D0698647 Calliper guide bushes
    4 x N90708502 calliper carrier mounting bolt
    2 x 3A0615301A Front brake discs, 288 mmm
    1 x 8N0698151 Front brake pads, set
    Rear:
    1 x 1J0615423 rear calliper, lh
    1 x 1J0615424 rear calliper, rh
    1 x 1H0615425 calliper carrier, lh
    1 x 1H0615426 calliper carrier, rh
    1 x Goodridge kit part number- SVW0506-2P
    2 x 191598625 rear wheel bearings
    2 x Rear discs (standard corrado rear)
    1 x rear pads (standard VR6)
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  4. #14
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,726
    Finally got round to getting these fitted - big difference. The 288 just fit under the speedlines, and fill out the rims nicely - the rears are reassuring, and hopefully they shoul dnot suffer from any seizinf like the MkIIs. Brake feel is very positive and definitely better. The only issue was the Mk2 to Mk4 rear hoses - the banjo nut was the wrong size and we had to get a new one from a hydraulic hose place.
    I went for all new parts, but you could get away with refurbed s/h items - especially the carriers, as these are very pricey.
    Definitely a mod well woth doing and still OEM - VR6s should probably have had 288s as standard anyway seeing as the Mk3 Golf Vr6 had them.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  5. #15
    CF Nutter V-Dubstar's Avatar
    Join Date
    16th February 2009
    Location
    Westbury Wiltshire, and Chepstow S.Wales
    Posts
    1,621
    Quote Originally Posted by fendervg
    Yeh they're quite a snug fit between the Speedlines ey?! It was only the late mk3 VR's that had 288's (95 onwards) so it was too late for the Corrado then
    If it ain't V-Dub, it f**kin' should be!!
    Dragon Green VR6 - 186.8bhp @ 5820rpm
  6. #16
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,726
    Yeah, I guess it was too late by then - still would have been nice if they'd had more stopping power from the get go.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  7. #17
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,726
    Updated list with more part numbers for rear discs, pads and ABS rings. That should be pretty much it.
    Can we make this sticky if possible ? Thanks.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  8. #18
    ⋆⋆ CF Donator ⋆⋆ Dude VR6's Avatar
    Join Date
    9th October 2008
    Location
    Banbury
    Posts
    1,139
    Nice work
    Black 94 VR6 - uprated headlight loom, BMC cda, Eibach front/rear ARB, H & R springs/Bilstein dampers ,VT Front Mount, Rear strut brace, 17" MO Compomotives, Crystal/Red rear lights, 312mm front brakes, and I still haven't finished.
    CCGB 3113
  9. #19
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    11th July 2009
    Location
    Leeds
    Posts
    933
    I've also read that the 288 setup was also used on MK3 GTIs from late '95 onwards, so that should make second hand setups easier to find.
    Will the ABS rotors that are already on the Corrado fit on the 288 discs?
    2004 Skoda Fabia VRS (daily)
    1995 VW Corrado VR6 Classic Green - Koni T/A + H&R springs, BMC CDA, Climatronic, BBS RCs, 288mm brakes
  10. #20
    Enthusiast
    Join Date
    8th May 2003
    Location
    Bournemouth
    Posts
    576
    The abs rotors fit to the back of the hubs not the brake disc
Similar Threads
  1. Part Number help please.
    By shawshankkid in forum Suppliers Forum
    Last Post: 16th September 2009, 3:25 PM
  2. Part Number Anyone?
    By Wendy in forum Suppliers Forum
    Last Post: 14th July 2009, 12:16 PM
  3. Part Number help
    By faithless in forum Suppliers Forum
    Last Post: 24th June 2008, 5:23 PM
  4. Part Number help
    By logicaltuning in forum Suppliers Forum
    Last Post: 5th February 2006, 11:47 AM
  5. Part Number
    By Oakley in forum Exterior
    Last Post: 11th November 2004, 9:53 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
