Page 7 of 7 FirstFirst ... 567
Results 61 to 64 of 64
Thread: 288 Front Brakes and MkIV Rears -Part Number Thread
  1. #61
    Im from Portugal, i purchased a 2.0 16v two weeks ago and it needs disc and pads front and rear, in my mk4 golf i upgraded to the R32 332mm in the front and to s3 with epytec adapter to run 280mm at the back, so i have the stock front FS III and the rear 232mm here sitting and i wanted to know if in can re-use them form the corrado, Thank you
  2. #62
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,666
    The rears will bolt straight on to the existing carriers, but you will need conversion brake hoses because MK4s have the banjo bolt fitting. Many have done this conversion.
  3. #63
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,666
    VR6 and G60 both use the same Calipers and carriers on the front, both use a 280mm disk (VR6 have 5 stud and G60 4 studs).
    VR6 can be fitted with 288mm disks from late MK3 Golf GTis / VR6s and Calipers and carriers from either the same GTi / VR6 or Golf MK4 are then used as they are the same (MK4 disks have a different offset and canít be used).
    So my untested theory suggests 288mm Calipers and carriers fill fit the 16v using a MK3 GTi / VR6 disk redrilled to 4 x 100 (youíll need conversion hoses for the front too).
    No one has ever tried it to my knowledge, I donít know why?
  4. #64
    Thank you Dox, my doubt was if i can bolt on the 288 carrier in my hub
Similar Threads
  1. Part Number help please.
    By shawshankkid in forum Suppliers Forum
    Last Post: 16th September 2009, 3:25 PM
  2. Part Number Anyone?
    By Wendy in forum Suppliers Forum
    Last Post: 14th July 2009, 12:16 PM
  3. Part Number help
    By faithless in forum Suppliers Forum
    Last Post: 24th June 2008, 5:23 PM
  4. Part Number help
    By logicaltuning in forum Suppliers Forum
    Last Post: 5th February 2006, 11:47 AM
  5. Part Number
    By Oakley in forum Exterior
    Last Post: 11th November 2004, 9:53 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupť! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
Follow us
advertising & sponsorship
