Page 2 of 22 FirstFirst 123412 ... LastLast
Results 11 to 20 of 220
Thread: The "Will these wheels and tyres fit" thread
  1. #11
    CF-oholic! dukest's Avatar
    Join Date
    4th July 2005
    Location
    London
    Posts
    2,543
    Blog Entries
    1
    Quote Originally Posted by bigkev View Post
    will 17x8.5 brock b1 rims with et 13 fit my corrado vr6 lovered by 40mm thanks
    I would imagine that this would need some kind of arch rolling to avoid rubbing unless you drive very slowly!
    ---------- Post added at 10:20 PM ---------- Previous post was at 10:19 PM ----------
    Quote Originally Posted by VW_OwneR_85 View Post
    hi ppl, looking into getting banded steels for my vr6, not sure on the dimensions i wanna go for yet, i still need to get the steelies, but what would be the ultimate best look dimensions with no modifications {other then the banding} and no rubbing, i.e wheel size, offset and width, thanks..
    if you dont want to do any other mods then 8 is as wide as you want to go and Et30 as low in offset terms. i dont know that you're able to adjust offset to your choice while banding though, it will just be varied from its original value by as much as the steel is widened?
    M8 VWR - 95M Aqua Blue VR6, Schrick VGI & 263s = 214bhp & 208lb/ft, 288/280mm brakes, Koni/H&R, Eibach ARBs.
  2. #12
    Enthusiast
    Join Date
    6th May 2009
    Location
    Penzance Cornwall
    Posts
    624
    What about 17 x 8 et35 with a 215 40 17 tyre on a 40mm lowered VR
    1994 VR in Dragon Green with all red rears, DG autotech Uprated Headlight Loom, 312mm front brakes, Koni TA's with H&R springs, Eibach ARBs, Rear strut brace, full Jetex exhaust. Soon: 280mm rears, stainless 6 branch manifold, 63mm stainless decat, lightened flywheel, ARP conrod bolts, 360cc redtop injectors, rotrex C30-84 , headspacer, full set vibratechnics mounts!
  3. #13
    Join Date
    4th July 2005
    Location
    London
    Posts
    2,543
    Blog Entries
    1
    You should be ok with that most of the time although 205 tyres always give you more breathing space.
  4. #14
    Enthusiast
    Join Date
    6th May 2009
    Location
    Penzance Cornwall
    Posts
    624
    Quote Originally Posted by dukest View Post
    Cheers, with the 215's i would'nt have any stretch on the 8" wide rim tho would I?
    I'd rather have a bit more rim protection as the misses has a close friendship with the local kerbs, and my parkings not perfect either!
  5. #15
    Enthusiast
    Join Date
    6th May 2009
    Location
    Penzance Cornwall
    Posts
    624
    I've spotted some alloys I really like they are 16 x 8 and the is ET37 but they'll need adapters to fit. So say add another 20mm for the adapters.
    So what are my chances of getting away with these without having to touch my arches?
  6. #16
    Join Date
    4th July 2005
    Location
    London
    Posts
    2,543
    Blog Entries
    1
    stretch the tyres and drive slowly and you might be ok
  7. #17
    Regular Ralphead's Avatar
    Join Date
    20th January 2007
    Location
    North Cornwall
    Posts
    220
    Has anyone run 205/55 15s and do they rub anywhere with a gentle drop of 40ish mm?
    And what offset would be needed with a 15x7 rim?
    Mine's a '90 16v
    Thanks
  8. #18
    Enthusiast
    Join Date
    13th June 2005
    Location
    The Netherlands
    Posts
    801
    How about this conmbination on a VR:
    Will 17*7.5 et35 wheels with 215/40 17 tyres fit a VR6 without any issues on a 40mm drop?
    I cannot decide over 205/40, 215/40 or 215/35 on above mentioned wheels. Cost is not an issue for the tyres and the main concern is comfort and no rubbing issues.
    Any input appreciated as I cannot decide. I'm currently running 195/40 17 on these rims but the ride is a bit harsh and I don't like the stretch look that much (the tyres came with the wheels when I bought them but now need replacing). I would also like a fairly straight side wall and with some kind of rim protection as it's too easy to kerb the alloys atm and they will be refurbed before I fit any new tyres.
    Cheers,
    Dutch
  9. #19
    Join Date
    4th July 2005
    Location
    London
    Posts
    2,543
    Blog Entries
    1
    probably best for you to go 215/40 then as you should be ok at et35 even though 205 would be the normal choice. hopefully with 215 you'll get a bit of protection and not much stretch without rubbing. 215/35 would be a step back from where you are i would say. check out the calculators above to see the difference in sidewall height with the various options. if you're on coilovers obviously you can adjust height for rubbing.
  10. #20
    Enthusiast
    Join Date
    13th June 2005
    Location
    The Netherlands
    Posts
    801
    Thanks for the advice. I'm on coilovers so like you say can adjust if necessary. I did do some searching before posting, but wasn't 100% clear if 215/40's would rub with my wheel size and offset. My current wheels and tyre sizes give a sidewall of 3.1 inches according to http://www.miata.net/garage/tirecalc.html, and 215/40 would be 3.4 and 215/35 - 3 inches. From a comfort point of view the 215/40 would be the better option I guess and give virtually no stretch?
    I think I'll be going for 215/40 Conti SP3's then, unless you know of a better option with some rim protection?
    R,
    Paul
Similar Threads
  1. Replies: 2
    Last Post: 18th May 2009, 7:50 AM
  2. wheels and tyres
    By roystonvr6 in forum Exterior
    Last Post: 24th February 2005, 11:15 AM
  3. 9 x 15 / 16 wheels... what tyres?
    By Robbo149 in forum Exterior
    Last Post: 18th August 2004, 7:28 AM
  4. TT wheels / tyres
    Last Post: 21st March 2004, 5:14 PM
  5. Will 205/50 R15 tyres fit on my Sebring alloys?!
    By Dave_Corrado16v in forum General Car Chat
    Last Post: 18th March 2003, 9:13 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
