Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
Thread: MK4/Polo Shifter
  1. #1
    Enthusiast
    Join Date
    29th May 2008
    Location
    Västerås, Sweden, Sweden
    Posts
    774
    MK4/Polo Shifter
    Hi!
    Im looking into doing this.. but does any one have a easy guide to all the parts needed?
    Can I use the whole MK4 shifterbox or is the Polo the way to go?
    Shifterbox: MK4 or Polo
    Shifter: Mk4 inside a Polo box?
    Cables: MK4
    Shifter tower: MK4?...
    Is this correct?
    Any one with the part numbers?
    My Moonlight Blue Corrado VR6 project... the never ending story!
    http://the-corrado.net/showthread.ph...Corrado-Woho!!
  2. #2
    Enthusiast
    Join Date
    7th January 2007
    Location
    Devon
    Posts
    351
    There are three parts you need. The mk4 Polo shifter housing and baseplate, and a lever for the mechanism.
    The three parts allow you to mount the mk4 02J shifter mechanism in a housing which bolts in to the Corrado.
    Part numbers:
    6n0 711 061 a houseing
    6n0 711 090 a base plate
    6n0 711 611 c selector arm
    Those are the only three Polo parts. All the others are mk4 (cables, tower, etc). They are about £50 new from VW.
    Hope that helps
  3. #3
    ⋆⋆ CF Donator ⋆⋆ poll250's Avatar
    Join Date
    25th January 2007
    Location
    Oxford
    Posts
    1,002
    I've had a s3 shift mech, cables and tower kicking about for a while. I spent about two hourstrying to fit the shift mech into the tunnel but it was too big.
    Are the Polo parts still available new then? I don't suppose you have a photo of them?
    Poll
    C63 AMG Coupé +
    Corrado VR6 Turbo
    GONE: Porsche Cayman S / E46 M3
    Aqua-Blue Pearl | Stealth Turbo | Custom Exhaust | 17" BBS RCs| Wavetrac LSD |Racelogic TC | 262s | ARPs | Cream Leather | Weitec Hicon GTs + Rear Arb | 312 Brembos + Mk4 rears | Aero Wipers | DDI | Momo | Mocal | S3 Shifter |Fixed Column...
  4. #4
    Enthusiast
    Join Date
    29th May 2008
    Location
    Posts
    774
    Thanks alot mate!! Found that there is a Polo -00 at the local junkyard... sweet!
    And the MK4 stuff... any part nr for those or should I look for a specific engine that have the O2J box?
    And the mounting bracket is the same on a Polo and Corrado? Thats why it fits..?
    Everything else is from a MK4 shifter... so I can take both and then swap the parts needed?
  5. #5
    Enthusiast
    Join Date
    7th January 2007
    Location
    Devon
    Posts
    351
    The parts are only from the diesel model, not all 6N Polos, so be sure it is the right one.
    As far as I know any mk4 shifter should work in this housing. The Polo tunnel is the same as the mk2 / Corrado, so thats why it fits, as opposed to the mk4 tunnel which is very different.
    Basically you need a mk4 shifter setup and these three parts and you can build one that fits the 'rado. I'm pretty sure this setup fits the 02M as well - afaik that has the same shift tower as the 02J, but I'm not 100%.
    @poll250 - yes the parts are still available new. They used to be on back order in the UK, but I have shipped so many sets to the USA that now they keep them in stock at Milton Keynes and at my local TPS
    Here's the original thread on Vortex that started me supplying these parts to the guys in the US: http://forums.vwvortex.com/showthrea...nd-slight-rant
    And a pic from that thread:
    The Polo housing is at the bottom.
  6. #6
    what are the gains from doing this?
    corrado G60 - metallic pearl green
    mk4 golf 1.6 8v 4dr silver- for the family like!
    yzf600 thundercat
  7. #7
    Enthusiast
    Join Date
    29th May 2008
    Location
    Posts
    774
    Smoothnes!
    And no 5hp gain
    Aha... so its not all Polos that have that box... damn! Because they had two 6N Polos at the yard but not a singel TDI.
    What would I cost from VAG if I would order?
  8. #8
    Join Date
    25th January 2007
    Location
    Oxford
    Posts
    1,002
    Ordered my Polo parts earlier and should have them in a couple of days. Will get it built up asap and postsome photos.
    Poll
    C63 AMG Coupé +
    Corrado VR6 Turbo
  9. #9
    Enthusiast
    Join Date
    29th May 2008
    Location
    Posts
    774
    Do that boy!
    I got quoted about 100eruo for all the Polo parts at VAG.
  10. #10
    Join Date
    25th January 2007
    Location
    Oxford
    Posts
    1,002
    Picked my parts up Thursday and spent today fitting. The shift mech bits fit inside the tunnel nice and easily. Need a couple of longer volts to fix it to the chassis but found some luckily.
    Getting the old tower out and new one in was a pig of a job, so much stuff in the way but managed it in the end, looks like adjustment will be nice and simple so will give that a go tomorrow.
    One thing: how do you get the reverse light working? The rado one sits on top of the tower, but the mk4 one has a threaded hole in the side. Do I need to buy an extra sensor to screw in?
    Poll
    C63 AMG Coupé +
    Corrado VR6 Turbo
Similar Threads
  1. Fitting an O2J / MK4 shifter
    By poll250 in forum Drivetrain
    Last Post: 8th October 2010, 5:42 PM
  2. mk4 shifter fit ctn box?
    By falcodub in forum Drivetrain
    Last Post: 12th October 2009, 5:41 PM
  3. fitting a mk4 shifter
    By Sc0rian in forum Drivetrain
    Last Post: 11th July 2008, 12:04 PM
  4. Fuel tank Issues - Mk4 Polo - lill car
    By caribsimon in forum Engine Bay
    Last Post: 19th June 2006, 10:49 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
