Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 76
Thread: MK4/Polo Shifter
  1. #21
    CF Nutter
    Join Date
    27th December 2002
    Location
    cambridge
    Posts
    1,903
    if you get a shifter from a ibiza 20v its already polo spec so no need to buy those extra parts
  2. #22
    ⋆⋆ CF Donator ⋆⋆ daves16v's Avatar
    Join Date
    28th November 2003
    Location
    M1 J25
    Posts
    4,589
    Quote Originally Posted by Sean_Jaymo View Post
    Try a scrappy for the tower, mine cost a fiver. Very worthwhile mod.
    I've got some local to me, I'll drop in Sat morning.
    Best Car! - CCGB National Day 2013 Castle Combe
    1994 VR6 - 2.5" Bastuck Exhaust - BBS RC's - 288 Front Brakes - Mk4 Rears - Bilstein B12 - Smoothed Rear - Moonroof - OBD2 -
    Braided Hoses - Aero Wipers - Short Shift - Black Heated Leather - SWG Scuttle Cover - OEM volt/oil gauges - 263 Cams - Carbonio Inlet -
    Golf Mk4 Handbrake
  3. #23
    CF Nutter
    Join Date
    27th December 2002
    Location
    cambridge
    Posts
    1,903
    slight chance you need the bearing that the tower sits in , 2x 13mm bolts directly under where the tower is plus drain the oil
  4. #24
    Join Date
    28th November 2003
    Location
    M1 J25
    Posts
    4,589
    I wish! Had to pay £30 this morning from my local scrappy but never mind I've got one now.
    Quote Originally Posted by steveo29 View Post
    I don't think I need the bearing as it should already be in the box. I have a spare 02A tower and the bottom end is the same as the 02J so should just be a straight swap.
    Golf Mk4 Handbrake
  5. #25
    CF Nutter
    Join Date
    27th December 2002
    Location
    cambridge
    Posts
    1,903
    ok sounds like youre okay...theyre not all the same though so worth anyone checking they have the right bits
  6. #26
    CF-oholic! Sean_Jaymo's Avatar
    Join Date
    3rd June 2008
    Location
    Lincolnshire
    Posts
    2,913
    Was that Charles Trent by any chance? I've been there twice and I've found them hit or miss on part prices. Maybe he charged you that because you e rendered a gearbox useless to them in their eyes?
    Either way, it will be worth it in the end. I'm pretty chuffed with the conversion myself.
    I drove mine back to back with Mics car and that has your short shift mod and found that the o2j shift mechanism was a bit heavier but just as nice to use. The throw was also quite short but that's because I had to cut a couple of inches from the gear stick it self.
    Maybe a different tower weight will improve the heavier feel.
  7. #27
    CF Nutter
    Join Date
    27th December 2002
    Location
    cambridge
    Posts
    1,903
    i found mine was too far travel side to side
    heres what i did to make it ajustable
    grind off the weld so you can remove the pin
    drill down the pin so you can tap threads into it
    file a slot where the hole was- bingo ajustable side to side movement
  8. #28
  9. #29
    Join Date
    28th November 2003
    Location
    M1 J25
    Posts
    4,589
    Never heard of Charles Trent so Googled it and it's a bit far out. My nearest scrappy is 1 mile away in Stapleford so went there and yes you are right it rendered the gearbox useless.
    Golf Mk4 Handbrake
  10. #30
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st December 2004
    Location
    Roma,Italy
    Posts
    2,027
    I'm also in the process of carrying out this mod but there are a few things that have cropped up and i think are
    worthy of mention to help others planning on doing the same thing to their corrados.
    The main issue concerns the polo tdi housing, or at least the version supplied to me from Vw here in Rome but
    ordered in from Germany, P/N: 6NO 711 061A. My supplied version is different than the version photoed by Dave16v, The
    first thing that differs is the size of the holes that secure the gear lever's plastic ball into the actual
    housing, the two Torx bolts present on the golf 4 or Audi A3's gearshift housing with part number KO 711 061A won't fit as they are too big,
    so you'll need smaller Torx bolts off something else, also the fixing plate, P/N: IKO 711 061A off the 2005 model Audi A3/Golf 4 is
    also bigger so the holes don't align up when securing down the actual gear stick into the aluminium polo tdi's housing so you'll have to drill another hole on the bracket.
    Ok, Nothing huge but still a bit of a ball ache, especially if you new polo housing's gear stick mounting holes aren't
    even bloody well threaded!! Yep, brand new housing and they forgot to thread the holes..
    Remember also that in order to separate and actually remove the gear stick your going to have to compress the spring and remove the securing collar
    Again, not rocket science but fiddly.
    Lastly, I noticed that, at least on the version supplied to me, there's a small aluminium ear or lug present which serves as a resting point for the
    sideways movement spring, both ends of the spring rest on it, on the 2005 gearshift it's incorporated onto the fixing bracket along with a small rubber bung thing
    that serves as the rest so in order to refit the relay lever P/N: 6n0 711 611 c first snap off the lug then fit the lever otherwise the lever won't sit flush
    and it won't work.
    Phew, sorry for the long post but i think that it should be pointed out that this mod isn't exactly 'Plug and Play' as other forums would make you believe..
    All of my components, both new and used, were all made in 2005, as stamped on the Aluminium polo tdi housing, gearshift housing off a golf 4 etc.
Similar Threads
  1. Fitting an O2J / MK4 shifter
    By poll250 in forum Drivetrain
    Last Post: 8th October 2010, 5:42 PM
  2. mk4 shifter fit ctn box?
    By falcodub in forum Drivetrain
    Last Post: 12th October 2009, 5:41 PM
  3. fitting a mk4 shifter
    By Sc0rian in forum Drivetrain
    Last Post: 11th July 2008, 12:04 PM
  4. Fuel tank Issues - Mk4 Polo - lill car
    By caribsimon in forum Engine Bay
    Last Post: 19th June 2006, 10:49 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
