Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
Thread: URGENT: check your battery wiring TODAY!
  1. #11
    Enthusiast tentonhammer's Avatar
    Join Date
    2nd November 2011
    Location
    Surrey
    Posts
    457
    Last thing you want is a fire you can't put out - I hope I never have to use my extinguisher.
    Will check live feed.
    Thanks Stone,
    "You see in this world there's two kinds of people my friend, those with loaded guns, and those who dig...you dig!"
  2. #12
    ⋆⋆ CF Member ⋆⋆ Jim Bowen's Avatar
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,949
    Just checked mine, looks like its had it, will be replacing it thats for sure, its really wobbly around the connection there.
    ---------- Post added at 2:04 PM ---------- Previous post was at 2:03 PM ----------
    Think i've actually been looking at the earth
    Just like a golf................But better!!!
  3. #13
    CF Nutter RW1's Avatar
    Join Date
    29th March 2005
    Location
    Up NorthWest
    Posts
    2,079
    Quote Originally Posted by Stonejag View Post
    found the culprit - a single thick wire, red with black tracer. to the positive battery terminal had parted ways. .
    Have you got a photo of this wire as I can't find it.
    All red or a thick black. Agrees with the 1995 Wiring Diagram and 1994 is the same.
  4. #14
    ⋆⋆ CF Donator ⋆⋆ Stonejag's Avatar
    Join Date
    30th May 2011
    Location
    Harpenden, Herts
    Posts
    1,837
    Quote Originally Posted by RW1 View Post
    You are quite right - on closer inspection it is a solid red wire. The reason I thought it had a black chaser is because the insulation is charred! I have obviously had a very lucky escape.
    PLEASE PLEASE PLEASE CHECK THIS WIRE BEFORE YOUR LOOM CATCHES FIRE!
    Stone
    RIP: '95 Blackberry Corrado VR6 auto
    Daily: 2003 DPB Mk4 R32
  5. #15
    Join Date
    29th March 2005
    Location
    Up NorthWest
    Posts
    2,079
    The wire end is not OEM. Its been remade and badly at that!!
    See the brass ring tag to the front and slightly below the one you are pointing out. Thats OEM and it should look like that.
    And the one underneath the faulty one behind the OEM looks a badly repaired crimp as well.
    This is the original installation, 2 views:
    Top - Looking towards the windscreen washer bottle.
    Bottom - Looking towards the left radiator fan.
    Ignore the two blue ring tag connections along with the double red partly sheaved in black. They are not standard Corrado.
    The OEM are all brass coloured crimped ring tags. 2 single red wires and a double red wire.
    Somebody has bodged a double repair on those two cables in your photgraph and both need remaking properly.
    And the OEM lowest (double red) in the photo next to the black fabric pipe has broken its insulaltion as well. Thats just waiting to happen!
  6. #16
    Join Date
    30th May 2011
    Location
    Harpenden, Herts
    Posts
    1,837
    Cheeky, I repaired both those silver crimps and they're solid as anything The original OEM brass one was what had failed, I had to snip a good inch off the end before recrimping it to get back to a good bit of wire. The temporary AA repair was just folded on with pliers, I pulled it off the wire end without even having to uncrimp it...
    The silver crimps aren't going anywhere, they're both crimped correctly with the appropriate tool. I might revisit them at some point if I find some of the original style terminals (to give a little more strain relief) but the second crimped point was where the original wire failed!
  7. #17
    These tales are always helpful to everyone and help build our knowledge of what sh!t can happen to us unwitting souls.
    Remember, though, guys, you do not need to use your current-drawing fog lamps unless the visibility is less than 100 metres in fog/smoke or blowing snow. IIRC.
    In Scotland, the police will delight in booking you if you do. <100 metres visibility is actually relatively rare.
  8. #18
    Newbie smithy220's Avatar
    Join Date
    3rd March 2006
    Location
    birmingham aka brum
    Posts
    54
    easy cheap fix,fit a rover 75 battery cable,available in every breakers in the land.
    anyone in need of mig welding/light fabrication
    car audio/wiring/car servicing?
  9. #19
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,935
    Sorry wrong topic!
    95 Classic Green VR6 - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  10. #20
    Enthusiast Billzeebub's Avatar
    Join Date
    1st October 2008
    Location
    East Sussex
    Posts
    906
    since reading this thread I have checked the wiring and also the battery. Replaced the battery with new Bosch Heavy Duty item, which in itself seems to have transformed the car electricaly speaking. I also now have a small powder fire extinguisher in the cabin and a larger one in the boot!!..
    94 2.0 16v Manual Classic Green/Black Cloth M447 BLE, 95 VR6 Manual Aqua Blue/Black Cloth N585 BUA, 95 Storm Manual Mystic Blue/Black Lthr M200 DAN, 94 VR6 Manual Classic Green/Beige Lthr M159 LYF, 96 VR6 Automatic Moonlight Blue/Black Lthr N866 XSS, 94 VR6 Manual Classic Green/Grey Lthr M803 XMB, 95 Storm Manual Classic Green/Beige Lthr M964 XSX, 94 VR6 Manual Aqua Blue/Beige Lthr M420 BOY, 95 VR6 Manual Blackberry/Black Lthr N320 MRN.
Similar Threads
  1. Central locking not working - CHECK YOUR WIRING
    By daves16v in forum Exterior
    Last Post: 23rd August 2015, 7:08 PM
  2. **URGENT*** Lambda/ecu wiring
    By Critical_Mass in forum Engine Bay
    Last Post: 29th November 2009, 5:22 PM
  3. *Urgent wiring help needed!!!!!!! *
    By mic_VR in forum ICE 'n' Secure
    Last Post: 17th January 2009, 4:08 PM
  4. VR6 starter wiring.........Urgent answers PLZ
    By Dub Style in forum Engine Bay
    Last Post: 1st May 2005, 11:46 PM
  5. Diagnostic check today
    By Bora Bora in forum Engine Bay
    Last Post: 26th November 2004, 2:14 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
