Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: URGENT: check your battery wiring TODAY!
  1. #21
    Newbie MurdoMac's Avatar
    Join Date
    26th October 2003
    Location
    NW Sotland
    Posts
    94
    I would steer clear of powder to be honest while it is very effective at puting out a fire, it's dangerous for the health, yours and the car, the powder is extremly cancerous and will also quite likely kill your engine if ever used foam is I would think a better option or CO2 for anything electrical.
  2. #22
    Super Moderator davidwort's Avatar
    Join Date
    24th January 2003
    Location
    Northampton
    Posts
    7,303
    Blog Entries
    1
    I think this is partly a small lesson about connectors to use under the bonnet, they should have 2 crimps that peel over in an 'm' shape as with the OEM ones, the inner one making the contact with the cable and the outer clamping the insulation, as well as making a firmer grip on the cable this helps prevent moisture entering the insulation and corroding the wires especially in an exposed position like the battery positive terminals.
    I hate the modern cheap radio/alarm install crush type connectors, 9 times out of 10 you see bare conductors sticking out of the back of the connector when you look under the dash of an old car. Trouble is they are cheaper and quicker than the proper connectors, and the crimping tools for the proper connectors are much harder to find.
    As RW1 has done, if you need to add any more connections for headight relays etc, it's always better to add some extra protection like heat-shrink tubing over the cable end and crimps.
    It's a good reminder to check things like live feed cables and fuel lines in the engine bay at regular intervals along with the things that can let you down less seriously like water hoses, sensor connectors and aux belts.
    my 1990 16v thread
  3. #23
    ⋆⋆ CF Donator ⋆⋆ Wullie's Avatar
    Join Date
    28th January 2009
    Location
    Paisley, Scotland
    Posts
    1,652
    Quote Originally Posted by MurdoMac View Post
    I would steer clear of powder to be honest while it is very effective at puting out a fire, it's dangerous for the health, yours and the car, the powder is extremly cancerous and will also quite likely kill your engine if ever used.
    Hmm, not that I know of, The most common powder is actually sodium bicarbonate aka baking soda, which is pretty innocuous in itself. There are however other powders used and one or two of these have a carcinogenic rating taken in combination with flow enhancers etc of 0.01 ppm. Powder is not exactly the most efficient of fire extinguishants as it relies a lot on the CO2 used to discharge the powder as an initial extinguising medium and the powder only to inhibit further ignition by absorbing and cooling the flammable substance involved. If an extinguisher was dangerous to health it would be banned as were for example CBF (Chlorobromodiflueroethane) Wullie Me, Graduate, Institute of Fire Engineers. The worst thing about powder is the bleedin mess it leaves behind which can be a pain in the A**se to get rid of. If it's dry hoover it up, or, as in most cases when used on an engine, pressure wash it away.
    Alpine White 1990 1.8 16v gone to a new home.
    Current mode of transport 2001 Megane Cabrio, apologies.
    The older I get the more I recall how little I knew when I knew it all.
  4. #24
    ⋆⋆ CF Donator ⋆⋆ dannyboy's Avatar
    Join Date
    27th June 2006
    Posts
    721
    Your right there Willie,nice quals you have too! I'm the SHEF at my place and have never really heard of carcinogenic fire extinguishers, heard lots on ozone depleting ones which have been taken out of service like halon was replaced with A.F.F.F
    I've set a 3kg powder off in my building before by accident while doing my monthly inspections,powder goes everywhere! Found it difficult to breath when suspended in the air as it happened so must work well in high concentration on localized fire. Perfectly honest as its an ABC cat is best for a car fire as damage has already occurred to your car,you don't care as long as it doesn't spread. I know about this because I've had a corrado die in a fire so been there done that!
    Anyone have any thoughts on using a mk3 cable as they'll still be available? Not checked mine yet but will do.What cable thickness is it again?
    Marders ate my corrado!
    1991 US G60 in tornado red
    1990 G60 red-Now 20vt....298bhp and 304lb/f on Aral 102 octance on 30 PSI boost and crazy timing!!!
  5. #25
    ⋆⋆ CF Donator ⋆⋆ Wayne2015's Avatar
    Join Date
    5th February 2015
    Location
    Windy Yorkshire!
    Posts
    1,893
    Does mine look ok????
    Upgrades
    LED Headlight Switch |OSRAM Dipped+Main+Fog Lights
    K&N Cone Filter | Heated Blue-tinted Convex Wing Mirrors
    SOLD:1994 Corrado VR6 | Luke (Mk3 Prelude 4ws)
    SOLD: Audrey (Mk2 Superb CR170) | Baby X (Mk2 JDM CRX 16v)
    SOLD: Scooby (Mk4 Legacy 242bhp on LPG) | Red (Gen4 JDM Celica Convertible)
  6. #26
    Can someone confirm what amp cable I need to replace this section please?
  7. #27
    take this advice seriously. I remember last year my brother's car had same problem and his friend saved him with an extinguisher.
Similar Threads
  1. Central locking not working - CHECK YOUR WIRING
    By daves16v in forum Exterior
    Last Post: 23rd August 2015, 7:08 PM
  2. **URGENT*** Lambda/ecu wiring
    By Critical_Mass in forum Engine Bay
    Last Post: 29th November 2009, 5:22 PM
  3. *Urgent wiring help needed!!!!!!! *
    By mic_VR in forum ICE 'n' Secure
    Last Post: 17th January 2009, 4:08 PM
  4. VR6 starter wiring.........Urgent answers PLZ
    By Dub Style in forum Engine Bay
    Last Post: 1st May 2005, 11:46 PM
  5. Diagnostic check today
    By Bora Bora in forum Engine Bay
    Last Post: 26th November 2004, 2:14 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
