Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
Thread: Steering Column Mod - Quick, Effective and Cheap!
  1. #11
    ⋆⋆ CF Donator ⋆⋆ stevef182's Avatar
    Join Date
    17th October 2006
    Location
    Guildford
    Posts
    938
    Nice! Will give this a go!
    1993 Aqua Blue VR6, Porsche d90s, Heated Black Leather, Ported & Polished Head, K&N, Miltek + de-cat, KW V1, 288mm mk4 turbo brakes, Lupo Wipers.
  2. #12
    Super Moderator CazzaVR's Avatar
    Join Date
    6th December 2002
    Location
    Wotton-under-Edge, Glos
    Posts
    7,527
    I'll give this a go too- cracking idea and saves so much hassle.
    'ave it!
    Corrado Club of Great Britain
    Gone, but not forgotten: Mystic Blue VR6 Storm
    Now: Avus Silver Audi S3 :: 1.8 20v Turbo :: BAM :: Recaro Leathers :: Bose :: Badger 5 v2 TIP :: Forge 007p :: 18" BBS RS2
    Gallery
    "Look Sir, Dubs,"
  3. #13
    Newbie
    Join Date
    4th January 2010
    Location
    waterford city ireland
    Posts
    59
    ya legend, gona do this tomorrow
  4. #14
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,842
    Did you do anything to stop the bolt chaffing the wiring?
    Nice work BTW
  5. #15
    ⋆⋆ CF Donator ⋆⋆ somersetdub's Avatar
    Join Date
    11th October 2009
    Posts
    384
    No need, as neither the bolt or the wiring moves at all. Obviously you could though if you were concerned about it.
    Cheers
    1993 Corrado Vr6
    Forged rods & pistons
    Stealth Turbo conversion
    330mm front discs, Porsche Brembos
    OBD2 conversion
  6. #16
    Enthusiast ProdigalSon's Avatar
    Join Date
    30th June 2007
    Location
    Oxford
    Posts
    695
    Tried and tested ;)
    So, my C failed its MOT due to excess play in the steering column (up & down), but CazzaVR pointed me at this topic so I got down to B&Q and bought some M6 x 100 bolts, M6 nuts and a coupla different size washers, and tried it out...
    Here's the steering column underside with cowling and steering wheel removed, you can see the tensioning spring to the lower left:
    Side on it looks like this:
    And here's how I took it out with a couple of pairs of molegrips (not sure how much compression it was under)!
    So now you can see the 'dome' that the far end of the spring sat on - this needs drilling to get your bolt through:
    To get a good start, I holepunched the middle of the dome, which also shows the path of the drillbit later:
    But that was a bit too close to the wiring, so I disconnected it and pulled it under the column and to the right (and also removed the column adjustment lever and the top cowling):
    When I first tried to drill the 6mm hole in the dome, I realised that the black plastic of the stalk switch housing would foul, so I moved them out of the way too:
    The hole was pretty tricky to drill and it made a LOT of swarf, so make sure you cover ALL of the switches and connectors, and either lay down some rags or be ready to bin your drivers mat afterwards! Having drilled the hole I cleaned up the edges with a Dremel and set the column at the right angle for me, as it will effectively be permanently set unless I want to undo all the nuts etc. to adjust the angle at a later date (unlikely!)
    I went for double nuts on both sides of both the pieces of metal that the bolt goes through, so that none of the nuts would slip (they are modestly tightened against their neighbours) and that the bolt would brace the column both up (in tension) and down (in compression). Yeah, it is belt and braces, but don't want to have to adjust it again, just set and forget:
    In this pic you can see the two larger (repair) washers at the front (right of pic) where the large hole is, and two regular M6 washers at the rear (left of pic) where there's a neat-ish 6mm hole, and double nuts to brace the bolt properly and prevent each other from loosening:
    I trimmed the last 15-20mm from the bolt (after I took these pics) so that I could get the lower cowling back on properly, so an M6 x 80mm bolt would be ideal.
    Parts:
    1 off M6 x 80mm bolt ideally
    2 off 6-32mm repair washers
    2 off M6 washer
    6 off M6 nut
    Labour:
    About 2 hours start to finish, with a bit of faff as I worked out where the steering wheel should be so that it was level when driving in a straight line!
    Result:
    WAY better, really solid, only slight up/down movement is due to the column moving the mounting point on the chassis!
    Hopefully that'll be an MOT pass now... Thanks for the idea somersetdub!
    Aqua Blue Pearl '91 G60, The Beginning
    Satin Silver Pearl '92 G60, The Return
    Uprated: Wipers, Charger, Induction, Hoses, Exhaust, Lights, Clutch, Coilies
    New: Brakes, Screen, Wishbones, Ignition, Fuelling, Paint!
    CCGB#2830
  7. #17
    Join Date
    11th October 2009
    Posts
    384
    Nice write up!
    Glad the idea has been of use to someone else, I couldn't believe the difference it made when I first tried it.
    I like the idea of having nuts in between to fix it further still, I shall probably revisit mine sometime as I did it using a few bits I had lying around rather than shopping for specific sized bolts etc.
    With your step by step guide, this little mod is made even easier to carry out!
    Cheers :-)
    1993 Corrado Vr6
    OBD2 conversion
  8. #18
    ⋆⋆ CF Donator ⋆⋆ boost monkey's Avatar
    Join Date
    27th July 2007
    Location
    Oxford
    Posts
    5,627
    I'll probably start selling these kits with an endorsement for only £50
    1990 Dark Burgundy Pearl Corrado 16v - Project Plum
    1989 Black Mark 2 Golf GTi 8v - Willow
  9. #19
    Join Date
    30th June 2007
    Location
    Oxford
    Posts
    695
    It passed the MOT retest (unsurprisingly, as that bolt could probably hold the entire weight of ther car) so I'm happy
    Thanks again to somersetdub and CazzaVR
    CCGB#2830
  10. #20
    CF-oholic! 24V Renshaw's Avatar
    Join Date
    27th August 2003
    Location
    Wilmslow
    Posts
    3,180
    Did this today. Worked really well.
    Just for a tip, drill the hole from the back, all you have to do is remove the dashboard undertray and you have easy access to drill the 6mm hole.
    Jay
    A sense of Deja vu!....
Similar Threads
  1. Mk2 steering column for non adjustable?
    By Erny in forum Drivetrain
    Last Post: 11th January 2012, 8:19 PM
  2. Steering column(same old, same old)
    By Oliver2 in forum Drivetrain
    Last Post: 5th October 2009, 6:26 PM
  3. Bolts in steering column
    By rmn in forum Interior
    Last Post: 19th June 2006, 10:08 AM
  4. Steering Column
    By julesz in forum Drivetrain
    Last Post: 7th October 2004, 12:26 PM
  5. Steering column
    By destructiv dave in forum Drivetrain
    Last Post: 1st October 2004, 2:06 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
