Quote Originally Posted by dbpvr6 View Post
Since the temporary fix a while back, the central locking and windows no longer work and the fuse blows instantly.
I’ve disconnected the window switches and they’re getting power (poked one of those probe things in that buzzes). Still won’t take a new fuse with those left off.
Had a ball ache removing the rear trim to find the module thing. How would I test if that works? All wires seem secure.
I’m not good at this stuff! Any pointers?
This was happening to my Corrado - the hidden fuse was blown. It MIGHT be that there's something insde the
door panel itself that's making contact with the window winder mechanism and shorting it out - this was the case with mine anyway.
The guy at the garage secured the offending object well away from the winder mechanism, and all was hunky dory. Hope that may help you.
