Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: electric window help.
  1. #1
    Enthusiast lion's Avatar
    Join Date
    26th November 2009
    Location
    NW London
    Posts
    480
    Any one know how to fix this problem
    Electric windows won't go back up, checked fuse box, they all fine,
    They was workin 10mins ago....
    LION_DUB
    blackberry AUQ 20VT...in progress
    helious blue g reg George RIP
    http://the-corrado.net/showthread.ph...5-20vt-Corrado
  2. #2
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,905
    Window control box...............?
    95 Classic Green VR6 - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  3. #3
    Join Date
    26th November 2009
    Location
    NW London
    Posts
    480
    Checked that.. all connections fine, is there a separate fuse that's not in the fuse box?
    LION_DUB
  4. #4
    ⋆⋆ CF Donator ⋆⋆ Wullie's Avatar
    Join Date
    28th January 2009
    Location
    Paisley, Scotland
    Posts
    1,648
    Thre's a 20 amp(I think) fuse above the relays. A bit difficult to see but it's there. Roughly central.
    Alpine White 1990 1.8 16v gone to a new home.
    Current mode of transport 2001 Megane Cabrio, apologies.
    The older I get the more I recall how little I knew when I knew it all.
  5. #5
    Join Date
    26th November 2009
    Location
    NW London
    Posts
    480
    Quote Originally Posted by Wullie View Post
    Thanks mate sorted now
    LION_DUB
  6. #6
    And fiddly it is to get to! Just had to change mine as window stuck down and central locking stopped as well. Will keep a spare in the car now!
  7. #7
    Since the temporary fix a while back, the central locking and windows no longer work and the fuse blows instantly.
    I’ve disconnected the window switches and they’re getting power (poked one of those probe things in that buzzes). Still won’t take a new fuse with those left off.
    Had a ball ache removing the rear trim to find the module thing. How would I test if that works? All wires seem secure.
    I’m not good at this stuff! Any pointers?
  8. #8
    ⋆⋆ CF Member ⋆⋆
    Join Date
    4th April 2015
    Posts
    1,370
    If the fuse blows instantly then you have a direct short. ... positive going straight to body earth. Not good.
    Try unplugging all the connections you can then replace the fuse. If it still blows, the fault is near the fuse box.
    If not plug the connections back in 1 at a time until it blows... getting close.
    Unplug all again and replace fuse . Now plug things back in but in a different order. Hopefully it will blow the fuse in the same area.
    You then need a multimeter to test the wiring. I hope the above method helps you narrow down where to look.
    A wiring diagram of the circuit will help to understand what colour wires are going where.
    Good luck.
    But keep posting
    Cressa
    Cress
    95 VR6
    One day she will drive out of my Garage
  9. #9
    Thanks. Think it’s all beyond my abilities, will see if I can get a quote from an auto electrician, or just sell it as is!
    The only time my mk2 gti broke down was after I’d changed the ignition leads causing one to catch fire and burn the end of the coil off!
  10. #10
    Enthusiast
    Join Date
    23rd April 2017
    Location
    Liverpool
    Posts
    331
    If you soldier a test light to the blown fuse (2 wires to a side light)when you put the test light into the fuse which keeps blowing it will be very bright,
    When you remove wiring,switches to find the dead short the bulb will go dim when you find the dead short
    Hope this makes sense bit hard to describe on here
Similar Threads
  1. electric window woes...
    By kitharrison in forum Interior
    Last Post: 23rd April 2007, 9:52 PM
  2. electric window
    By shephard in forum Interior
    Last Post: 14th January 2007, 11:13 PM
  3. electric window
    By shephard in forum Exterior
    Last Post: 7th January 2007, 5:21 PM
  4. Electric Window probs
    By russ360 in forum Archive
    Last Post: 16th September 2004, 5:52 PM
  5. Electric window
    By Rich in forum Archive
    Last Post: 6th February 2004, 2:05 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
