Page 6 of 6 FirstFirst ... 456
Results 51 to 59 of 59
Thread: TEVES 20 ABS system parts list?
  1. #51
    Regular Louis's Avatar
    Join Date
    6th February 2007
    Location
    Coventry
    Posts
    147
    Anyone had an issue with ABS ECU after fitting? I'm getting error code 1044 ecu incorrectly coded.
    I've read what I can find online and it seems this is because the ecu will be coded for a different vehicle, in this case a mk3 Golf. I believe I need to find out what code to use for a Corrado VR6 and then see if I can get it changed to that.
  2. #52
    ⋆⋆ CF Donator ⋆⋆ somersetdub's Avatar
    Join Date
    11th October 2009
    Posts
    384
    Mine worked straight away when I connected it. Haven't heard of having to code the ecu.
    1993 Corrado Vr6
    Forged rods & pistons
    Stealth Turbo conversion
    330mm front discs, Porsche Brembos
    OBD2 conversion
  3. #53
    Join Date
    6th February 2007
    Location
    Coventry
    Posts
    147
    Hmm, cleared it with a snap on diagnostic tool but it comes straight back. May be a call to Stealth tomorrow and see if they know what to do about it! No other error codes left now but abs warning light still on so presumably once this code is gone the light will go off.
  4. #54
    Join Date
    6th February 2007
    Location
    Coventry
    Posts
    147
    Sorted! The ecu was coded wrong. There are 2 codes for a mk3 Golf ecu and I didn’t realise until I bought the Bentley repair manual. Tried changing the code to the later version & then the faulty coded message was replaced with faulty rear right sensor. Was a brand new sensor it must’ve been faulty so I tried a known good one off my mk3 and the fault cleared. Just need the right warning light now unless I can modify a mk3 one to fit.
  5. #55
    CF-oholic! Sean_Jaymo's Avatar
    Join Date
    3rd June 2008
    Location
    Lincolnshire
    Posts
    2,913
    You can modify a mk3 one into a Corrado light and then you have to do a bit of electrical wiring to get it to work. Unfortunately I can't remember details as it was a few years ago now but I know it can be done!
    I have up looking for the passant light in the end, they are impossible to find.
  6. #56
    ⋆⋆ CF Donator ⋆⋆ stuarttaylor37's Avatar
    Join Date
    16th March 2012
    Posts
    739
    They come up regularly on German ebay, I’ve bought a couple of spares for mine, not silly prices either
  7. #57
    Join Date
    6th February 2007
    Location
    Coventry
    Posts
    147
    Thanks guys, I'm modifying a mk3 one as I have the loom to go with it. Offered it in today just to see if it works & it does. Just got to tidy it up so it fits nicely in the dash & looks original now.
    1. 1995 Flash Red Corrado VR6
    2. 1997 Mystic Blue Golf VR6
    3. 2016 Lapiz Blue Golf R Estate
    CCGB #4146
  8. #58
    Quote Originally Posted by Louis View Post
    I also went with the mark20 system. Do you have more info on wiring? I just plugged the abs to fuse box plug, connected/spliced the 1 wire to the other plug (blue/red) and fitted the warning light loom to the light. Might have wrong rear sensors but the light does not go off
  9. #59
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    19th January 2006
    Location
    South Manchester + Hazel Grove
    Posts
    118
    There is a document g3abs95on.pdf which is on RunJonny's google docs page:
    https://sites.google.com/site/rubjonny/ >> VAG Documents and have a rummage...
    The wiring to the ABS lamp - and the ABS lamp - need to be from the Golf3, too.
    Have you tried checking if there are any error codes in the ABS controller?
Similar Threads
  1. A List of Parts (updated)
    By Goldie in forum Wanted
    Last Post: 12th November 2013, 1:26 PM
  2. Replies: 2
    Last Post: 25th March 2012, 9:03 PM
  3. Replies: 69
    Last Post: 10th February 2012, 7:25 PM
  4. Parts list
    By robo22sri in forum Engine Bay
    Last Post: 1st August 2011, 10:18 AM
  5. Parts list and exploded views
    By Wullie in forum General Car Chat
    Last Post: 1st April 2011, 12:49 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
