Results 1 to 7 of 7
Thread: Guide : How to remove G60 Supercharger with pics
  1. #1
    Newbie
    Join Date
    28th April 2005
    Location
    Near Cardiff
    Posts
    90
    This week I had to remove my Charger for a service and the only guide I could find online was the Matey Matey on, which was very informative but not enough pictures as I find it easier to to understand than a load of paragraphs
    So I thought why not make my own guide for future reference and for other people to benefit from
    Right so I started off
    Pop open the bonnet and remove the drivers side Headlight and front grill
    Next remove the airbox/airfilter inlet pipe by 2x hex boltstop and bottom
    Next remove the radiator cover
    Next remove the 4 hex bolts on the side of the charger, theyre what hold the charger in the bracket
    Next remove the black plastic cover that sits on top of the charger by these 2 bolts
    Then on the right hand side of the charger there is a black plastic box ( the silencer box ), undo the jubilee clips and pull off the intercooler pipe
    Just underneath the black box you will see an oil feed cable, should be a silver braided hose , undo this and place up by the oil cap so I doesn't drip oil anywhere, there is also another oil feed pipe on the bottom of the charger on the side where the airbox was
    Unfortunately I didn't take any pics when I undid these but you can clearly see them
    Next to do is loosen and remove the tensioner bolt, and I tapped it off with a rubber mallet
    Then slip the belt off the charger pulley
    Next remove this pipe from the charger, its quite stiff so give it a good wiggle and a pull, I slipped a very small flathead screwdriver in and lightly levered it out
    Next remove the oil dipstick and then the 4 bolts holding the black silencer box together, I found this quite difficult as the bottom 2 bolts wernt easy to get to, make sure you get a spanner on there good and firm and don't round the bolts off, just slowly crack the bolts
    Next split the black box
    Remove the one half of the black box out of the bay and then remove this bolt holding the other half in
    Then you can access the last 2 hex bolts holding the charger in on the bracket
    Then remove the last bolt on the charger support bracket, watch the metal 3 holed bracket doesn't fall down
    Then I used a crowbar to slowly loosen the charger from the bracket, then with a bit of a wiggle the charger should lift out
    Now theres a big empty gap where your charger used to be, get the Gunk out and start scrubbing
    Then send your charger off to Matt at OCD for an overhaul and service
    And there you have it, I hope this helps people out in the future...Good Luck Steve
  2. #2
    ⋆⋆ CF Member ⋆⋆ loepan's Avatar
    Join Date
    15th September 2013
    Location
    devon
    Posts
    478
    great how to mate and I haven't even got a g60, surely a sticky???
  3. #3
    Administrator
    Join Date
    8th November 2002
    Location
    Coventry
    Posts
    23,502
    Great how to - thank you very much for sharing it with everyone!
    2001 BMW E39 530d SE Touring (Black) | 1999 BMW E39 523i SE (with Sport Pack) Saloon (Black) | Ex-Corrado Owner
  4. #4
    ⋆⋆ CF Donator ⋆⋆ dragon green's Avatar
    Join Date
    21st May 2008
    Location
    Nr.Tonbridge,Kent
    Posts
    3,994
    This needs put in the Wiki Submissions & Collaboration,
    It'll be easier to find there !
  5. #5
    Newbie
    Join Date
    8th August 2014
    Location
    Axminster
    Posts
    11
    Nice one, I'll use this when i take mine out for a service.
  6. #6
    CF-oholic! Tempest's Avatar
    Join Date
    20th January 2004
    Location
    Coventry, UK
    Posts
    2,669
    Couple of points:
    1. Use F-clamp to compress the tensioner for the supercharger polyribbed belt. No need to damage the thread of the stud protruding once the nut has been removed.
    2. Now is a good time to replace that dreaded black silencer box with an RS-outlet kit (easier to remove for future G-Lader removal jobs)
    3. Rather than using a long crow-bar to prise out the G-Lader, I tend to remove the console on the right hand side of the G-Lader (when standing in front of the engine bay). You will need a new seal for the engine block hole underneath when refitting.
    Tempest
    My Mk1 Rocco, Rado and 928
    Corrado Club of GB Events Manager
  7. #7
    Enthusiast
    Join Date
    23rd November 2005
    Location
    West Yorkshire
    Posts
    902
    Here is a good guide to complement this one,
    http://www.corrado-club.ca/forum/viewtopic.php?t=4107
    And a video how to remove the tension, so you can slip the belt off.
    http://www.youtube.com/watch?v=fpuk4IY0Urg
Similar Threads
  1. Replies: 7
    Last Post: 24th October 2011, 10:00 PM
  2. Replies: 6
    Last Post: 14th May 2010, 8:05 PM
  3. Replies: 162
    Last Post: 30th June 2009, 9:39 PM
  4. MoonlightVR Pics - Sad day - 26/2/06 - SOLD IT :-( Pics pg11
    By MoonlightVR in forum Members Gallery
    Last Post: 7th November 2006, 6:31 PM
  5. remove supercharger ?? Now out with pics???
    By 2_Door_fun in forum Engine Bay
    Last Post: 12th February 2006, 4:41 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
