Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
Thread: Sill repair panels
  1. #11
    Do you have a link for them? I'm going to tackle the repair myself over the winter, then probably put it to body shop to get the paint sorted. I have a small hole at the back end of each sill. Not cleaned the area up yet, but I'm hopefull I won't need to replace more than a few inches at the very end of the sills.
    I should try making the panels myself, but would be a lot easier if I had a repair panel to cut out what's needed.
  2. #12
    Quote Originally Posted by Keyo View Post
    From what I can see both are now obsolete .
    On heritage they have outer sill repair panels both sides but are listed the same as a golf MK 2 I have some at home they go about half way back on the floor pan not sure how good they are but I guess it’s something for your body shop to work with . I have two rust spots just under the a pillar underside of car so hope these will rectify that . Think your issues are the Rocker covers under the front door ?
    Do you know if the MK2 sill has the same profile as the raddo? Might get the profiler thing I have for tiling and go find a MK2 golf to measure the radius on sill to compare to the raddo...
  3. #13
    ⋆⋆ CF Donator ⋆⋆ Keyo's Avatar
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    1,376
    Not sure I'm just going to give the repair panels to my body shop and if they are no good they will have to make something up and Ill have some spares for my MK2 golf. I cannot see anything else on the market for a repair panel for that area.
    I believe the Corrado has the same floor panel and lip that rises but I think you need the panels that are on the outside of these ??
    Floor panel same for below models
    Corrado (09/88 - 07/95)
    position 2 at drawing 2
    Golf 2 Rallye (08/89 - 07/91)
    similar to position 2 at drawing 1
    Golf 2 Syncro (08/85 - 07/91)
    Golf Country (08/90 - 07/91)
    Jetta 2 syncro (08/85 - 07/91)
    https://www.vwheritage.com/191803207...-edge-vw-spare
    https://www.vwheritage.com/191803208...-edge-vw-spare
    The thing is a Rado has two panels on the outside of the edge of the floor panel so not sure these will be any good to you..??
  4. #14
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    1,376
    To be honest chap 90 % sure it will not have the same profile as a golf, you'll need to cut out from a breaker or someone that can fabricate the sill, the A pillar part of the sill that meets the wing is still available for one side, the whole sill panel is made up of the A pillar sill, the part that is obsolete and the rear quarter.
  5. #15
    ⋆⋆ CF Member ⋆⋆ vw rule's Avatar
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,524
    They're the inner sill panels in your attached links I think, which basically fit the MK2 Golf, but should fit the Corrado also. The main floor panels do fit the Corrado as well, but may need very slight fabrication as the Corrado floor pan was based on the MK2 Golf, but will differ in very small areas, hence slight fabrication.
    Unfortunately the outer sill panels have been obsolete for a while now, I think the left side one was only available up until very recently.
    Left outer sill for Corrado 1989 to 1995
    Part number 535 809 847 Obsolete
    Right outer sill for Corrado 1989 to 1995
    Part number 535 809 848 Obsolete
    Hope this helps
    Si
    Had MK2 1.8 Scirocco Scarla 1998 to 2002
    had it lowered on original wheels,
    K&N air fitler and Janspeed exhaust system.
    Now have 94 M reg Corrado 2.0 16v since 2002 still got it, been off the road now since early 2015
    hoping to get it finished this year.
    Also have a 2015 Seat Ibiza TSI i-tech as my daily driver. Plus I'm on The SEAT Forum.
    Link to 16v torque settings & ECU pin locations.
    http://the-corrado.net/showthread.ph...fuel-pressures
  6. #16
    Thanks for the replies. The knowledge on this forum is superb.
    https://www.tarostrade.com/body-part...1991-1995#menu
    Found this whilst browsing for parts. Not sure if it inner or outer sill, or what it is...
    Might be worth a punt.
    I am thinking that repairing these wee bits will be my first attempt at shaping panels.
  7. #17
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    1,376
    Such a shame you cant post pics on here, it's getting pretty difficult to communicate without them or for members to show their restoration work to give others inspiration or ideas.
  8. #18
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    1,376
    Quote Originally Posted by Bush View Post
    That looks promising looks like the right shape and if not correct maybe something you could make work with a bit of hokery pokery.
  9. #19
    Don't appear to be sided, which seems odd. I've ordered 1, hopefully it will be the right shape to make a couple of repair section
  10. #20
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    1,376
    What you might find is that there is more work to be done underneath, the drain holes are behind that area of the rocker covers , so you may well need the outer floor panels but at least they are available thanks to the Golf MK2.
Similar Threads
  1. Genuine centre sill repair sections
    By coullstar in forum Parts for Sale
    Last Post: 23rd July 2015, 2:08 PM
  2. Repair panels
    By beastofabug in forum Exterior
    Last Post: 11th May 2015, 8:27 AM
  3. Replies: 14
    Last Post: 29th October 2014, 1:14 PM
  4. Replies: 13
    Last Post: 13th March 2013, 4:31 PM
  5. Sill repair
    By leeeeshad in forum Exterior
    Last Post: 1st February 2010, 9:36 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
