Page 1 of 15 12311 ... LastLast
Results 1 to 10 of 147
Thread: Replacement Fuel Pump - VR6, 2015 and onwards
  1. #1
    Regular Storm Guy's Avatar
    Join Date
    5th January 2006
    Location
    Nottingham
    Posts
    203
    So VR has periodivally been making some rapid clicking noises over the past week or so on start up from cold.
    Relays seem all OK as well as battery and starter.
    Going to work and stalled this morning during rush hour, and then stuck, Turns out is the fuel pump.
    TPS say no longer available (VDO / Pierburg) and Classic VW / Heritage say NLA either. So what are the options nowadays - anyone changed to an aftermarket fuel pump recently.
    The part number seems to be 1H0919651Q.
    HAAS at £113, Bosch at £194 but does not sound like a correct fit from the description.
    Please can anyone help with a correct make that might be suitable. I have nt heard of the HAAS part.
    The following threads very useful in the replacement how tos but all make reference to part that are sadly now NLA.
    http://the-corrado.net/showthread.ph...cing+fuel+pump
    New Fuel Pump
    Fuel sender removal
    Replacing vr6 fuel pump
    Thanks in advance.
    Corrado History: Present: Classic Green Storm - RH ZW1s 1995 | Past: Blackberry VR6 1994 | Black G60 1991 | CCGB 4094 - Storm Album
  2. #2
    It's just getting harder and harder to keep these fecking things on the road
  3. #3
    CF-oholic! VAG-hag's Avatar
    Join Date
    1st June 2005
    Location
    Tarn!
    Posts
    5,721
    I got a walbro pump fitted at stealth. They could maybe quote you?
    95 Mystic Blue Storm - It's bound to cause disappointment.
  4. #4
    Join Date
    5th January 2006
    Location
    Nottingham
    Posts
    203
    Quote Originally Posted by Mccorrymark View Post
    Indeed it is...although after over 11 years trouble free motoring, bar the odd hiccup, I suppose I can't really grumble.
    Quote Originally Posted by VAG-hag View Post
    Thank you, will give me a call in the morning. Julian from VWHeritage also recommended them. Ta
  5. #5
    CF-oholic! Jon_vr6's Avatar
    Join Date
    18th September 2006
    Location
    Cheadle Hulme, Stockport
    Posts
    4,639
    Check ebay type in the part number.
  6. #6
    Join Date
    5th January 2006
    Location
    Nottingham
    Posts
    203
    Quote Originally Posted by Jon_vr6 View Post
    Thanks - The part number quoted in the OP was the number given by TPS. The actual part number on the pump top, underneath the cover which is held on by 3 screws, is 535 919 051D. It also has 228 225 moulded into it.
    I have not actually removed the part as yet so cannot compare with the images.
    The 1H0 919 651Q numbers does give some options, but its those compatability tables that seem to give confusing and conflicting answers. The VDO original however looks good - thank you.
  7. #7
    Join Date
    18th September 2006
    Location
    Posts
    4,639
    No worries i got mine through vw when mine went only to find there was one on ebay 70 quid cheaper.
  8. #8
    ⋆⋆ CF Member ⋆⋆ Jim Bowen's Avatar
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,963
    Did you get anywhere with this? Considering buying the Bosch pump from Eurocarparts as its easter sale, so about £120.
    Have not removed mine to look, but thinking if i order the bosch and it doesn't fit i can always get a refund
    Just like a golf................But better!!!
  9. #9
    ⋆⋆ CF Donator ⋆⋆ Keyo's Avatar
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    1,115
    Hi bringing this thread back alive guys.
    Part Number 1H091651Q
    Will this Bosch fuel pump fit a N reg corrado VR6 as it says it is compatible on the table and four bar. Just been reading a few threads off here and a bit confusing.
    https://www.ebay.co.uk/itm/SKODA-FEL...wAAOSwEBxZbSRq
    We are hoping the fuel pump housing and attachments are still ok and just changing the pump. The Bosch pump seems a good price.
    After my car has had all the work done its driving like a dream but unfortunately after doing all the exhaust and manifold gaskets, mas sensor,catalytic and 02 sensor (which were leaking or on the way out anyway) after deleting fault codes have reappeared on my V Gate displaying 00561 sporadic mixture adaption exceeded limit which has also triggered fault code 00537 sporadic O2 sensor regulation.
    There is no hesitstion or jultness in the engine what so ever and noticeable air leeks.
    This leaves us to think injectors which have never been changed or refurbished and there is no history of a new fuel pump. I do plan on going on long trips this year in the Rado so wont begrudge changing these parts.
    I take it sporadic means intermittent, basically meaning not so serious but on the way out and will get worse?
    Cheers.
  10. #10
    It's just a pump, so many different fuel pumps will work, they don't have to be Corrado specific. The issue tends to be the fuel level sender more than the pump since fitment can be an issue. As long as the pump housing fits in the bayonet (mine even floated in the tank for months), and can house the sender, it should work just fine. You can even just buy the pump itself and keep the original housing and so on. If yours is working, and not making noise, I'd leave it alone. However, if you do change it out you may want to have fuel hose from the top hat to the pump on hand, as those tend to fail over time. Often enough they get replaced with regular fuel hose, not designed to be submerged, and turn into a black messy goo.
Similar Threads
  1. Late VR6 fuel pump replacement
    By Thom in forum Engine Bay
    Last Post: 1st November 2015, 2:39 PM
  2. G60 fuel pump replacement.
    By Riley in forum Engine Bay
    Last Post: 18th July 2007, 8:01 PM
  3. Fuel Pump Replacement - How to guide
    By Stan 24v in forum Engine Bay
    Last Post: 7th July 2007, 1:43 PM
  4. Fuel pump replacement?
    By dirtytorque in forum Engine Bay
    Last Post: 12th June 2007, 8:26 PM
  5. Corrado 16v fuel pump and Golf Mk2 16v fuel pump....
    By alackofspeed2 in forum Engine Bay
    Last Post: 21st March 2006, 6:15 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
