Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Wanted
  1. #1
    ⋆⋆ CF Member ⋆⋆ GazG60's Avatar
    Join Date
    9th August 2008
    Posts
    61
    Wanted
    94/95 Dash panel, where the radio fits. Must be good condition. Also VR6 abs lamp , part number 535919285BA, the one with two plugs tia
  2. #2
    Join Date
    9th August 2008
    Posts
    61
    Bump
  3. #3
    ⋆⋆ CF Member ⋆⋆
    Join Date
    4th April 2015
    Posts
    1,260
    I don't have a spare mate, but am aware that on this model the lamp inside it fails. I soldered a new bulb in and it worked perfectly. Others too have done that. The bulb isn't anything special, I gone one that looked similar from an autospares shop...cheap as chips repair if you can use a soldering iron.
    Cressa
  4. #4
    Join Date
    9th August 2008
    Posts
    61
    Thanks for the reply. Sadly I have nothing inside the lamp casing. I need a working lamp. Thanks
  5. #5
    ⋆⋆ CF Member ⋆⋆
    Join Date
    4th April 2015
    Posts
    1,260
    Oh damn. Well the little 2 pin red plug does nothing. ... so I don't see why any other switch wouldn't work !!
  6. #6
    Join Date
    9th August 2008
    Posts
    61
    I've read that as well. I've seen a lamp with a slightly different part number. I might take a gamble on it.
  7. #7
    ⋆⋆ CF Member ⋆⋆
    Join Date
    4th April 2015
    Posts
    1,260
    If mine packs up again that's what I'll do. Let us know how you get on.
    You could always swap out the back of the switch casings so the red plug clips in somewhere.
  8. #8
    Join Date
    9th August 2008
    Posts
    61
    Yes will do. Do you know if the centre dash panel where the radio and heater controls sit are the same one early and late cars? I've just bought a '95 VR6 and need that panel. And a few other bits. Sun visors for one. Tia
  9. #9
    ⋆⋆ CF Member ⋆⋆
    Join Date
    4th April 2015
    Posts
    1,260
    They are different, so you need a late panel. Difficult to find. . especially without any damage/broken tab fixings. Although if repaired the fixings aren't seen.
    I have a good drivers sun visor with the sliding part at the mirror of you can't get sorted.
    Contact lillfuzzer on here as he normally can help with parts
  10. #10
    Join Date
    9th August 2008
    Posts
    61
    Thanks. I'll double check on my driver side visor. How much is it should I need it please ?
Similar Threads
  1. Replies: 3
    Last Post: 10th June 2013, 1:31 PM
  2. -WANTED - Dash ABS warning light wanted
    By STORM 2 in forum Wanted
    Last Post: 5th May 2013, 3:14 PM
  3. vr6 or 2.0 16v WANTED
    By jez m in forum Wanted
    Last Post: 17th April 2011, 8:57 PM
  4. Wanted Corrado Shell / Cheap Project Wanted
    By TheDubFather in forum Wanted
    Last Post: 25th January 2011, 7:59 PM
  5. help wanted!
    By STORMv6 in forum General Car Chat
    Last Post: 9th July 2009, 9:16 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
