Results 1 to 7 of 7
Thread: OEM plugs and connectors
  1. #1
    ⋆⋆ CF Donator ⋆⋆ captainredeye's Avatar
    Join Date
    16th May 2009
    Location
    Calne, wiltshire
    Posts
    762
    I'm looking for somewhere that sells the original plugs and connectors for all the different sorts of looms, I can buy more modern types on eBay but would like to stick with the original style plugs, any one know where I can get hold of them? Also any idea in the part numbers as I can't find any on any diagrams that I have seen.
    Cheers
    CCGB 3172
    88 Silver Mk2 Golf / NEW HOME
    94 Dragon Green Corrado VR6
    03 Jazz Blue Lupo 1.4, named Efole
  2. #2
    Join Date
    16th May 2009
    Location
    Calne, wiltshire
    Posts
    762
    Oh and any ideas on a tool for dismantling the old plugs from the connectors.
    CCGB 3172
  3. #3
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st December 2004
    Location
    Roma,Italy
    Posts
    1,902
    You can get the proper tool off ebay or Amazon, it's round with multiple blades of different sizes For different types of terminal.
    If not i use tiny precision screw drivers that flatten the locating tab, you then pull out the terminal.
  4. #4
    ⋆⋆ CF Member ⋆⋆
    Join Date
    4th April 2015
    Posts
    1,203
    I still get my plugs from TPS as all I order always seem available. Thankfully most plugs have been used on other VW vehicles.
    The connectors I get from ebay, searching under 'vw timer connectors".
    And the tool I use to remove the connectors is a VW laser 3932 terminal tool. Bloody fiddly, not always successful and requires patience. I suppose it depends on the connector.
    The plug aren't cheap for a piece of plastic !
    Good luck tho
    Cressa
  5. #5
    Join Date
    16th May 2009
    Location
    Calne, wiltshire
    Posts
    762
    https://www.autoelectrical.parts/pro...er-connectors/
    well i found this site, although i think all the locating grooves are different on the car but all the ones are the same on this site,
    CCGB 3172
  6. #6
    Join Date
    16th May 2009
    Location
    Calne, wiltshire
    Posts
    762
    Ok I have found a couple of good sites that sell male and female connectors, I'm now left wondering what amp wire should be used when replacing any of the old and corroded wiring?
    CCGB 3172
  7. #7
    ⋆⋆ CF Member ⋆⋆
    Join Date
    4th April 2015
    Posts
    1,203
    Look at some of the wiring diagrams as it states what size cable goes to which plug so that is really handy. Also tells you what colour the cables are. Not much seem to be bigger than 1mm unless it's battery/starter motor/alternator big use items.
    This will certainly keep you busy,
    Cressa
Similar Threads
  1. Vw connectors from where?
    By Cressa in forum Wanted
    Last Post: 6th October 2016, 1:27 AM
  2. Need some connectors
    By jakedidier in forum Wanted
    Last Post: 17th January 2016, 12:31 AM
  3. Iso connectors
    By Gavin A in forum ICE 'n' Secure
    Last Post: 22nd September 2015, 5:53 PM
  4. Replies: 3
    Last Post: 9th July 2006, 3:16 PM
  5. Plugs and Connectors for Sub and Amp
    By Not_Aircooled_or_Taxfree in forum ICE 'n' Secure
    Last Post: 27th June 2005, 2:15 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
