Results 1 to 6 of 6
Thread: Drivers door lock issue
  1. #1
    Enthusiast Ray1965's Avatar
    Join Date
    5th February 2013
    Location
    South Yorkshire
    Posts
    866
    Been trawling through the posts on door lock problems, but have not found a solution.
    My issue is when I lock the car all the doors lock, boot and the petrol cap. The issue is with the drivers door the central locking is moving the button down on the door but the door is not locking, but will lock perfectly ok with the key. I have looked at all the wiring as it was mentioned it could be a loose/ broken wire behind the membrane. The wiring seems ok and i do have movement on the button as i mentioned, so it is ponting towards a faulty lock? or could it be a deeper problem.
    Daily Drive 1995 BLACK VR6 Vee Reihenmotor. Headlight loom upgrade. Magnex Exhaust.
    http://the-corrado.net/showthread.ph...hlight=Ray1965
  2. #2
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    Witheridge, Tiverton
    Posts
    5,736
    More likely the rod/mechanism not engaging properly, or the plastic linking part.
    95 Classic Green VR - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|BBS RX228s|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  3. #3
    ⋆⋆ CF Donator ⋆⋆ robrado974's Avatar
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    5,890
    As Sean says . The plastic clip that connects the door rods a has probably broken. I think you can still get these. Cheap as chips .
    92 VR6 . DBP. She will never be a show car ..... But will be up there with the best of em .
    The bmw seems invincible in isolation . But along side the corrado - a modern classic , we think- it has its work cut out . Autocar 1992.
  4. #4
    Join Date
    5th February 2013
    Location
    South Yorkshire
    Posts
    866
    Cheers for your help guys I'll have another look when I get chance.
  5. #5
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    5,890
    I'm sure the problem will become apparent , when you remove the door card.
  6. #6
    Join Date
    5th February 2013
    Location
    South Yorkshire
    Posts
    866
    Quote Originally Posted by robrado974 View Post
    Cheers Rob,
    I checked every thing apart from the rod part.
Similar Threads
  1. Drivers door handle disconnected from door lock.
    By Brunty's Dad in forum Exterior
    Last Post: 20th April 2016, 2:35 PM
  2. Drivers side door mechanism (lock)
    By robrado974 in forum Wanted
    Last Post: 20th September 2014, 9:56 AM
  3. Drivers door lock barrel with key
    By larceny fink in forum Wanted
    Last Post: 12th July 2012, 3:14 PM
  4. Replies: 1
    Last Post: 22nd May 2011, 7:58 PM
  5. HELP!!!DOORS Lock but drivers door doesn't unlock!!
    By kasman21 in forum ICE 'n' Secure
    Last Post: 24th February 2007, 10:49 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
