Results 1 to 6 of 6
Thread: Wishbone bushes help
  1. #1
    Having a nightmare trying to fit the rear wishbone bush, every time I press it in it goes in crooked and bends. Anyway I was considering fitting poly flex bushes as they appear to be easier to fit, can anyone cofirm this?
    Many thanks
  2. #2
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st December 2004
    Location
    Roma,Italy
    Posts
    1,899
    Did polys on mine about 10 years ago. The poly versions went in without a struggle but obviously they cost more than the normal o/e versions. It sounds like your changing the old ones with the back axle dismantled?
    If so, try heating the axle housing first the pressing in the o/e bushes, smear some grease on the outer metal casing first then press them in slowly, they should go in straight.
    If your doing it with the axle still in place, use a length of threaded rod and washers and slowly force them in that way.
  3. #3
    Oh sorry just realised I worded that bit wrong, I ment the rear bush on the front wishbone. Don't suppose you fitted front ones too?
  4. #4
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st December 2004
    Location
    Roma,Italy
    Posts
    1,899
    Yep, every one I could find except the steering rack, thanks to c&r enterprises who never sent them..
    Same thing, try pushing in the first few mm's so that the Bush's are in square in the wishbone then press them in using a socket.
    Put some grease on the wishbone's hole first and then press.
  5. #5
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,371
    I just tap them in with a hammer, top, bottom, left, right before going around the outer of the bush clockwise, once they start in squarely its 30 seconds before they're fully home
  6. #6
    Thanks guys just ordered some
Similar Threads
  1. Wishbone bushes
    By tony_ack in forum Drivetrain
    Last Post: 31st May 2015, 9:53 PM
  2. Wishbone Bushes
    By andy in forum Drivetrain
    Last Post: 28th March 2007, 12:19 PM
  3. wishbone bushes
    By h100vw in forum Drivetrain
    Last Post: 28th March 2007, 12:06 PM
  4. wishbone bushes
    By olly elworthy in forum Drivetrain
    Last Post: 5th May 2006, 9:29 PM
  5. Wishbone bushes
    By randal in forum Drivetrain
    Last Post: 1st April 2005, 10:41 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
