Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: Sunroof stopped sliding - easy fix Also a grease question
  1. #1
    Enthusiast timmaaah's Avatar
    Join Date
    1st July 2005
    Location
    Reepham Norfolk
    Posts
    461
    Well the other day I got the dreaded tilt but won't slide issue with my sunroof. After doing a bit of research and head scratching I found an easy fix.
    Part of the mechanism consists of a small wheel that sits in a slot in the runners. There is a little rubber that sits on the end, and it would appear that over time, this loses its thickness, so when that part is pushed back, instead of the wheel riding up and over the groove, it pushed downwards, and stops the mechanism from moving back. Research would show that this usually happens on the passenger side, and was the case for me.
    One way to fix it, I guess, would be to find a rubber oring that is thick enough to make the resting position of the wheel a tiny bit higher. I didn't have any o-rings, but I did have some od 4.8,, id 3.0mm plastic pipe that is the perfect size to fit on the metal part and lift it up enough that it works every time.
    Tilt your sun roof, then gently tap back the fabric cover, lower it and push it back out of the way. Now - CAREFULLY try sliding your mech back. See if the wheel digs in. Now try a fingernail under the rear of the wheel and try again. It should lift up correctly this time. I took off the rubber bit, and cut a short piece of my plastic tubing, slipped it on and it works like a charm. Slide back the fabric cover and gently press back into place. Pics below - any questions, just ask.
    The piece I cut was about 5mm or so long. I do have about 1.5 meters of the pipe left, so if people need some I'm happy to post these out (just cover postage).
    Now - a grease question. I have some Klüber Klübersynth UH1 64-2403 silicone based grease specs:
    DIN EN 377 Class D
    DIN-DVGW-Reg.-No. NG-5162BN0547
    NSF H1-registred
    Full data sheet here http://roghankar.com/new/statics/upl...H1_64_2403.pdf
    Any good for the sunroof, or should I just buy this from the bay I can get the Klübersynth foc
    Many thanks
    Driver's side showing the little rubber end
    Passenger side with modification
    Last edited by timmaaah; 23rd August 2017 at 8:02 AM. Reason: Because Photobucket is ****
    You'll have to speak up, I'm wearing a towel....
  2. #2
    ⋆⋆ CF Member ⋆⋆
    Join Date
    4th April 2015
    Posts
    1,370
    I think you've hit on a little miracle cure. One of my previous cassettes was bent on the frame at this point due to the rubber being off.... and broke. I'll happily take a piece of you let me know how to pay you.
    As for the grease, I got mine off of ebay that was recommended on here. Only around £8 for the tube, but free is better
    Cress
    95 VR6
    One day she will drive out of my Garage
  3. #3
    CF-oholic! fla's Avatar
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,420
    That's exactly what i did on my mechanism. Although i used a blue silicone tube! Time will tell how effective it is...
    Hasan
    VR6 Auto to manual conversion, beige leather, aircon, TT comps, blue dash lights & switches, Koni TA/Nothelle springs, OBD2, 264 cams, Schrick
    my car
  4. #4
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    11th March 2009
    Location
    West Midlands
    Posts
    4,229
    tidy fix well done
    the liqui moly stuff you linked is the one i used & is recommended on here
    Bramber metallic VR6 bring on the grins as the VR sings!!!!
    Stealth head rebuild, 263's, BMC CDA, Roose M/Sport hoses, VT engine mount, KW V1s
    KUR2Y loom, daves16v short shifter, 2.5" Longlife SS exhaust with sport cat, lots of shiny bolts & 210bhp
    Alpine White 1.8 16v, Kamei skirts, Powerflow SS exhaust, back on my drive April 2014
  5. #5
    Join Date
    1st July 2005
    Location
    Reepham Norfolk
    Posts
    461
    OK, I'll order up the moly stuff as it's tried and tested.
    I should add I removed the old black rubber before fitting the new bit!
    Cressa, pm me your address and I'll pop a few bits in the post. I'll do a couple of different lengths to ensure you get the right fit and for when you drop one and lose it (ask me why I thought of that possibility lol)
  6. #6
    ⋆⋆ CF Member ⋆⋆
    Join Date
    4th April 2015
    Posts
    1,370
    The moly stuff is good. Cheers mate
    Cress
    95 VR6
  7. #7
    Enthusiast
    Join Date
    16th April 2006
    Location
    Bucks
    Posts
    887
    I also glued a small slither of plastic under the hole into which the wheel drops - has the same affect of stopping the hammer dropping so low that it wont come out - I thought it might stay in place a bit longer than the rubber band - could be belt'n'braces to do both
  8. #8
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,420
    Good idea. I was thinking of different options as a long term solution but thats a good one
    Hasan
    my car
  9. #9
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,420
    Quote Originally Posted by Geeba View Post
    Ive just removed the tube on mine and replaced with two strips of plastic cut from a tie wrap. Its actually working far better than the tube i had used before. Fantastic suggestion Geeba, i'll post some pics of mine shortly.
    Hasan
    my car
  10. #10
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,420
    Here you go. And aftet greasing the gearbox and output gear its a LOT smoother now. Slides back but doesn't want to come back I think the whole mechanism needs to be stripped and greased properly. But at least the fix suggested by Geeba works well. Let me know if any explanation of the pics is needed. Btw the gearbox needs a t20 torx bit
    Attached Images Attached Images
    Hasan
    my car
Similar Threads
  1. Sunroof Grease - these any good?
    By Jamie in forum Exterior
    Last Post: 12th August 2017, 5:42 PM
  2. Sunroof Grease
    By swiftkid in forum Wanted
    Last Post: 31st January 2012, 8:24 AM
  3. LM Grease for Sunroof?
    By nlau1 in forum Interior
    Last Post: 20th March 2011, 7:24 PM
  4. non sliding sunroof
    By C.P in forum Interior
    Last Post: 18th May 2009, 12:47 PM
  5. Sunroof sliding
    By Oakley in forum Interior
    Last Post: 20th October 2004, 9:55 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
