Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Sunroof stopped sliding - easy fix Also a grease question
  1. #11
    ⋆⋆ CF Member ⋆⋆
    Join Date
    4th April 2015
    Posts
    1,391
    Looks a good idea too
    Cress
    95 VR6
    One day she will drive out of my Garage
  2. #12
    This is what you need bud, just a tiny amount though and it will glide along
  3. #13
    ⋆⋆ CF Member ⋆⋆
    Join Date
    16th December 2002
    Location
    Ireland
    Posts
    873
    Brilliant ideas guys! Thanks for posting.. :-)
    I remember the day mine stopped working! Ironically enough it was just after I had cleaned and greased the sunroof mechanism. It was a nice summers day & I called over to my mates house. I had the sunroof wired to close when I locked the car. When I came out to the car again I noticed the sunroof hadn't closed properly & there was two scratched at the passenger side :-( I managed to get it closed and it hasn't been slid open since although the tilt still works. Hopefully it will come back into action again when I try both your methods (fingers crossed)
    Satin Silver VRG
    ccgb 1667
    Quality never goes out of Style!
  4. #14
    Hi Guys
    If you speak with JMR, John will tell you that grease is the devil on these mechanisms so I cleaned all of the grease away and just use the spray pictured above. No issues ever since
  5. #15
    CF-oholic! delfinis38's Avatar
    Join Date
    24th February 2006
    Location
    Muckle Flugga & Fastnet Rock
    Posts
    3,368
    Thanks just cleaned all the grease out of mine... even works a bit quicker...
    Corrado VR6 - Aqua Blue LC5U - 96 'N' Plate
    Black Leather - Heated Seats - Air Con
    Totally Standard and intend to keep it that way !
    Hibernation for Winter ! SORN
  6. #16
    Enthusiast
    Join Date
    16th April 2006
    Location
    Bucks
    Posts
    910
    Quote Originally Posted by fla View Post
    Here you go. And aftet greasing the gearbox and output gear its a LOT smoother now. Slides back but doesn't want to come back I think the whole mechanism needs to be stripped and greased properly. But at least the fix suggested by Geeba works well. Let me know if any explanation of the pics is needed. Btw the gearbox needs a t20 torx bit
    Thats it! exactly what I did... two strips cut from tie-wraps, a small dab of mitre-fix/superglue and its great. - you dont get the nasty snapping sound as the hammer slides back anymore.
    If you whip the cover plate off the gearbox you'll see that all the grease put there by VW has moved off the gears and is surrounding them rather than on them, all I did was push the existing grease back over the gears and reassembled it, bit messy and make sure the gears all go back ok, works a treat thou.
  7. #17
    Enthusiast
    Join Date
    16th April 2006
    Location
    Bucks
    Posts
    910
    Quote Originally Posted by delfinis38 View Post
    Hmmmm - I used silicone grease on the cable and track... seems ok, not breaking any speed records opening and closing but seems smooth....
  8. #18
    Hi, I think my sunroof could "hopefully" be fixed by this method.
    When I try to slide it back (and forward) it will go, but only about 5mm per push of the buttom and will then stop, so I push the button again and it will go, etc. etc. - does that sound the same as what was happening with yours before the fix?
    Looking at the rubber stoppers, they have deformed over time, so with any luck, if I replace them with some wider tubing, it should all work ok?
    Cheers.
  9. #19
    Thats a great idea. I always use silicon base grease such as molykote to fix these problems
  10. #20
    the last time I took a great advice about silicon grease at http://roghansanat.com
Similar Threads
  1. Sunroof Grease - these any good?
    By Jamie in forum Exterior
    Last Post: 12th August 2017, 5:42 PM
  2. Sunroof Grease
    By swiftkid in forum Wanted
    Last Post: 31st January 2012, 8:24 AM
  3. LM Grease for Sunroof?
    By nlau1 in forum Interior
    Last Post: 20th March 2011, 7:24 PM
  4. non sliding sunroof
    By C.P in forum Interior
    Last Post: 18th May 2009, 12:47 PM
  5. Sunroof sliding
    By Oakley in forum Interior
    Last Post: 20th October 2004, 9:55 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
